Offroad & 4x4
Dillins Build Thread
Old Apr 5, 2010 | 09:55 PM
  #406
crazyredneckanyhow's Avatar
crazyredneckanyhow
I cut the arm off. I measured 10" back from the inside of te c. They are not done yet. I plan on drilling a 1" hole through the new part and the old arm to put a 1" od piece of tube all the way through. If that makes sense.
Old Apr 5, 2010 | 10:04 PM
  #407
crazyredneckanyhow
Paul i talked to the guy at stonecrusher awhile back. They come with a 3/4" or 7/8" heim.The same **** youd use for steering. Compare that to the 3" ballistic joint that is greaseable and rebuildable. I talked to Dr.vic at Ballistic and they have had the 3.0 on there diesel drag/hauler for 4yrs of r&d time and have yet to rebuild them.
Old Apr 5, 2010 | 10:12 PM
  #408
crazyredneckanyhow
A little comparision of the Ballistic 3.0 vs a 3/4 heim. Thats a regular size can of engine enamel.
Old Apr 5, 2010 | 10:56 PM
  #409
captain p4's Avatar
captain p4
That's a big ****in joint cheet-hoe.
Old Apr 6, 2010 | 12:09 AM
  #410
fatdan460's Avatar
fatdan460
way to show off how manly it is by putting it on a frilly fu fu table clothe
Old Apr 6, 2010 | 06:15 AM
  #411
kjett's Avatar
kjett
The real questionis what are you worried about running the smaller joint for? It's not like you need the 3.0 joint for cruzing the local mall trying to pick up family members.
Old Apr 6, 2010 | 07:44 AM
  #412
alpha/omega's Avatar
alpha/omega
Originally Posted by captain p4
Most people recommend that you box in the rockcrusher extentions after you thread and weld it on.
Originally Posted by dillinewton
oo ok just didnt know what you ment by boxing it in because his was already a box, diditn know you were talking about the buying one option.
Mmmm, box!...its whats for dinner. Hopefully it will be on the menu again tonight
Old Apr 6, 2010 | 11:08 AM
  #413
crazyredneckanyhow
I just cant see puttin a joint thats the same as for steering to hold up the weight of the truck. Alot of load on that 3/4" shank. Big truck like he wants with 44s on it will put alot of stress on a heim that small. Plus they cant be rebuilt. Cant even grease them to get some life out of them.
Old Apr 6, 2010 | 12:23 PM
  #414
captain p4's Avatar
captain p4
I've been planning on running that joint when I get around to extending the arms, but that comparison shot is making me reconsider. Though even the weakest 3/4 heims are rated for something like 40k lbs, and I think the $$ ones can go up to what 70-80? I've seen one guy on FSB run the rock crusher extensions.. he didn't box them and just moved his stock brackets back further on the frame without even bracing them and as far as I know he never had any problems. IIRC, he was running something like 35s and was fairly mildly built. I'll have to see if I can find him over there and see how it's holding up.
Old Apr 6, 2010 | 05:14 PM
  #415
crazyredneckanyhow
IIRC the ballistci joints are rated at 126k psi.
Old Apr 6, 2010 | 05:26 PM
  #416
dillinewton's Avatar
dillinewton
i was just looking on ballistic and the 2.63 joint said the yeild stregnth was 208,000?
Old Apr 6, 2010 | 05:32 PM
  #417
dillinewton
i know im not to my front axle yet but i was wondering. which route should i take make my own with a nice huge joint or should i get the extension? i dont like that little joint, but on makin im afraid of not making them completely perfect so i dont dick my my front end up.
Old Apr 6, 2010 | 05:54 PM
  #418
alpha/omega
If I were building my own Id use the same joints Cheeto bought and build them like he did except put a slight bend in them about where the tire should hit.
Dillin...
your new name is Cheeto Jr. I will take you under my wing and guide you along the path of the neverending build samurai
Old Apr 6, 2010 | 07:27 PM
  #419
crazyredneckanyhow
Yeah we talked about the bend but im not doing it until i get the front under my truck with the factory arms then ill put the extended arms in. When i start im gonna do the basics first and upgrade as i go. If i try to do it full tilt right off the bat it will be a 4 year project like the crew
Old Apr 6, 2010 | 07:36 PM
  #420
kjett's Avatar
kjett
Originally Posted by alpha/omega
Dillin...
What, has Dillan tried to jew you out of every nut, bolt, washer, hood, body panel, and anything else you have too, and then try to sell it back for 3 to 4 times what it's worth?
