Offroad & 4x4
Dillins Build Thread
Old Mar 29, 2010 | 06:14 PM
  #346
kjett's Avatar
kjett
You will need to go closer to 9" to get them right with the huge coils. The only other way would be for you to fab up a 4 link setup. That's the down fall with trying build big with stock components. Kris is showing you 2 different types. The brackets in the pics are the drop brackets that re-use the stock bracket. The ones in the link actually replace the stock and have the drop built in. So, if you have the spacer block (the yellow bracket in the pic) and then get the ones in the link, you should be right on.
edit: Forgot to mention the more you have them angles down, the more apt you are to tearing the rear bushing to crap with the hanger in the stock location. Also the stess that every bump will put on them, pushing in a rearward direction, will eventually try to rip the rear hanger from the frame. This is the reason you want it as parallel as possible.
Old Mar 29, 2010 | 06:15 PM
  #347
alpha/omega's Avatar
alpha/omega
right but its only moving the bracket down 3-4"
Old Mar 29, 2010 | 06:17 PM
  #348
dillinewton's Avatar
dillinewton
ok sounds good that what i was thinking of doing, should i support run some support for them?
Old Mar 29, 2010 | 06:19 PM
  #349
kjett's Avatar
kjett
Not necessary. The drop spacer is supported by the tranny crossmember, and the extra drop should be good by itself. There is really no inward flex, just front to rear stresses.
Old Mar 29, 2010 | 06:21 PM
  #350
alpha/omega
werd again.
Old Mar 29, 2010 | 06:24 PM
  #351
dillinewton
ok sounds good ill start there and see what happens. thanks
Old Mar 29, 2010 | 08:00 PM
  #352
kjett's Avatar
kjett
Front leafs on the old trucks, ask Kris. Coils and radius arms, come see me!
Old Mar 29, 2010 | 08:11 PM
  #353
dillinewton
ok sounds good, but kris hasnt steered me in the wrong direction ever so i beilive you both. so with 13" of lift you think if i get it dropped 9" i should be fine?
Old Mar 29, 2010 | 08:14 PM
  #354
fatdan460's Avatar
fatdan460
should work. you can get away with a 4 inch on a stock truck without drops so it should be fine
Old Mar 29, 2010 | 08:31 PM
  #355
alpha/omega
Go back and look at the pics I posted.
that truck has 9-10" of lift and the radius arm brackets are only dropped about 3-4".
I wish I still had the truck to give you some measurements.
Old Mar 29, 2010 | 08:34 PM
  #356
dillinewton
ok sounds good they sell the 3" and 4" then the one you gave me the link to i already have the 4" and with the other from what you guys are telling me i should be good to go. or very close thanks
Old Mar 29, 2010 | 09:54 PM
  #357
captain p4's Avatar
captain p4
wtf are you talkin about Kris? If you lift the truck 9inches you need 9" of drop to keep factory angles. 4 -> 4, 6 ->6.. see a pattern here? :flipoff2:
That said you can use degreed bushings to make up for some of the angle that you get if you don't drop the brackets ALL the way. So you can use some 6" drop brackets and degreed bushings to make up for the rest. Not ideal, but it should work decently (especially if you use some rock crusher extensions with heims on the ends so the stock setup isn't binding with the extra angle on droop). You also have the ability to make up for some of the angle when you're welding your c wedges to the axle (the whole reason for degreed bushings is to correct caster.. but you can take care of this with careful consideration and placement of your c wedges on your shiney new d60).
Old Mar 29, 2010 | 09:57 PM
  #358
kjett's Avatar
kjett
Spoken from the guy that had someone else do his 60 swap. Lazy, water pump stealing, *******!
Old Mar 29, 2010 | 10:03 PM
  #359
fatdan460's Avatar
fatdan460
somebody got a fire lit under their @$$! post away massa, isa good boy, i'll listen
Old Mar 29, 2010 | 10:13 PM
  #360
kjett's Avatar
kjett
Nah, I steer Paul to another site for a stock replacement water pump, and he's trying to steal the aluminum high flow one I want.
