1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
more VIN numbers
Old Apr 20, 2011 | 03:47 AM
  #196
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
If the truck was tu-toned Wimbledon White/Rangoon Red, the Warranty Plate COLOR codes would be MJ, not just M.
Old Apr 20, 2011 | 10:07 PM
  #197
Tobys351.9's Avatar
Tobys351.9
3rd Paint job?
The steering column and wheel are red (actually the wheel has been
worn thru its red outer coat revealing a turquoise coat which is again worn to a black color.)
there is a coat of red paint beneath its current paint, only seen at the front fenders in engine bay. I was assuming that it had only one repaint until now.
Thanks Man!
Old Apr 21, 2011 | 08:16 AM
  #198
Oldschool1962's Avatar
Oldschool1962
New Oldbie
I've done some searching through the posts and couldn't find or missed some of the info about my VIN. I appreciate any info you could provide. Thanks.
F10AL783076
129 J F101 581 C 09
04200 129 4000 210142
Old Apr 21, 2011 | 08:32 AM
  #199
NumberDummy
F10AL783076 // 129 J F101 581 C 09 04200 129 4000 210142
F10 = F100 2WD
A = 240 1V I-6.
L = Michigan Truck Assembly Plant.
783076 = 1966, assembled November 1965.
129" Wheelbase.
J = Rangoon Red.
F101 = F100 2WD. 4,200 lbs. GVWR
581: 5 = Red Crush Vinyl & Red Wicker Pattern Vinyl // 81 = 81A Standard Cab.
C = Ford type 3.03 3 Speed Manual all Syncromesh Transmission.
09 = Ford 9" Rear Axle / 3.70-1 / non Limited Slip / 3,300 lb. Rear Axle Capacity.
4,200 lbs. Gross Vehicle Weight Rating.
129 net HP @ 4,000 RPM.
210142:
21 = Atlanta GA Ford District Sales Office, where the original selling dealer ordered the truck from.
0142 = Domestic Special Order number. The truck was special ordered by the original purchaser, not "bought off the lot."
Old Apr 21, 2011 | 08:41 AM
  #200
Oldschool1962
New Oldbie
Bill,
Didn't expect a reply so soon. Thanks for the info. I had some of the numbers covered you filled in the blanks.
Later,
Joe
Old Apr 29, 2011 | 11:07 AM
  #201
dj88deer's Avatar
dj88deer
Need help decoding VIN
Can someone help me decode this VIN? F75FUC87634
I've looked in different places, but hard to decode the bigger trucks. I think it's a 1976 F750 built in Louisville, KY with a 361? The engine size is what I'm really trying to make sure of.
Thanks for any help.
Billy
Old Apr 29, 2011 | 11:41 AM
  #202
NumberDummy
Welcome to FTE
F75 = F750
F = 391 4V // (E = 1966/78 361 2V / E = 1976/78 361 4V / D = 1966/78 330 2V H/D / C = 1966/78 330 2V M/D)
U = Louisville KY Assembly Plant.
C87374 = 1976.
Old Apr 29, 2011 | 11:47 AM
  #203
dj88deer's Avatar
dj88deer
Thank you for your help with this!
Old Jun 5, 2011 | 02:05 PM
  #204
golden beagle's Avatar
golden beagle
Yet another decode
Hi all - new to the forum, and to Ford trucks for that matter. Please help me with the following:
VIN F25YR803833
Warranty plate
129 F F250 281 A 24
07500 172 4000 72 DSO is blank
Thanks in advance.
Todd
Old Jun 5, 2011 | 02:50 PM
  #205
NumberDummy
F25YR803833 // 129 / F / F250 / 281 / A / 24 / 07500 / 172 / 4000 / 72 = DSO code.
Welcome to FTE
F25 = F250 2WD
Y = 352 2V
R = San Jose CA Assembly Plant.
803833 = 1966, assembled January 1966.
129" Wheelbase.
F = Arcadian Blue.
F250 2WD, 7,500 lbs. GVWR
281: 2 = Medium Blue Crush Vinyl & Medium Blue Wicker Pattern Vinyl // 81 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Tratmsmission.
24 = Dana 60 Rear Axle / 4.10-1 / non Limited Slip / 5,200 lb. Rear Axle Capacity.
7,500 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 RPM
DSO 72 = San Jose (NorCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
Beagles are 'nervous nellies.' Yip yip yip. I prefer Basset Hounds, have 4 of 'em. Howoooooo
Old Jun 6, 2011 | 07:12 PM
  #206
Royal Uni's Avatar
Royal Uni
FJ10K190555 122JM F100
Trans A Axle 11 5000lbs Cert 114 3600
New guy here---I had to leave town, but I had my buddy text me info from the tag in the glove box, I apologize if its not all there. Thanks for any help you can give me. Title say 1961 Unibody, its definately a long bed.
Old Jun 7, 2011 | 12:19 AM
  #207
kjvforme's Avatar
kjvforme
Your VIN looks messed up should be F10JK190555
F10= F100
J= 223 CID
K Kansas City Assembly Plant
190555= Jul 1961 Assembly date
122= Wheel base
JM= Rangoon Red/Corinthian White
F100 2wd 1/2 ton
Trans A= Ford Type 3.03 all Syncromesh 3 speed manual transmission
Axle 11
= Ford 9" Rear Axle / 3.70-1 / non Limited Slip / 3300 lb. Rear Axle Capacity
5000= GVW
Cert 114= Horsepower rating for the 223CID
3600= RPM
Hope this helps.
Rob
Old Jun 7, 2011 | 12:49 AM
  #208
Royal Uni's Avatar
Royal Uni
Thanks!
Thanks for all the info!! Nice to know the 'ol girl will turn 50 in July. This forum is amazing. Can't wait to get movin on my new ride!
Thanks
Old Jun 7, 2011 | 02:03 AM
  #209
NumberDummy
A = Ford 3 Speed Manual Light Duty Transmission. No syncro 1st gear.
Ford type 3.03 3 Speed Manual all Syncromesh Transmission introduced 1963.
Old Jun 7, 2011 | 09:18 AM
  #210
kjvforme's Avatar
kjvforme
Yep forgot the date.
