Would one of you be willing to tell me what you can about my "new" purchase please?
Thanks
Sheldon
66595A
66595 =Serial number
A= load rating
4662522-L
4= Ford V8
66 =Unibody
25= F250
22= 122 In WB
L= Left Hand Drive
Trim 202 sorry nothing on that one, 1 might be Standard cab, 2 Delux cab
1TT= Sultana Turquiose
Axle Ration 4.56:1
Series F-F250
GVW 5400 Lbs
R= engine 292?
4 Spd manual trans
Most of this information is hit and miss, this is what I have managed to collect so far. Heck have more questions than answers, what engine?
And it is indeed the 292. The door has custom cab written on it. Perhaps that is the trim code?
Originally Posted by kjvforme
66595A
A= load rating
4662522-L
4= Ford V8
66 =Unibody
25= F250
22= 122 In WB
L= Left Hand Drive
Axle Ration 4.56:1
Series F-F250
GVW 5400 Lbs
R= engine 292?
4 Spd manual trans
You posted this question in the wrong forum, this is for 1961/63 Ford F100/250 Uni pickups.
Ask further questions in the 1968/2013 Full Sized Van (Econoline) forum.
E38 = E350 Cut-Away.
A = 460 4V
H = Lorain OH Assembly Plant.
BA2110 = 1978.
Cut-Away: FoMoCo cuts the Econoline van body off behind the front seats so that aftermarket body makers can install a box van, people mover, ambulance and etc bodies.
Th color code is m .thanks for the info I bought the truck from the second owner. It also has the 3 on the tree and looks like it had factory air and no radio holes .
Factory installed A/C was not available for these trucks, it was only available dealer installed.*
Domestic Special Order: 4 digit DSO:
Some type of special equipment was installed on the truck after it left the assembly line that was not an RPO (Regular Production Order).
Or if the truck was ordered with a non standard color, there would be no COLOR code stamped on the Warranty Plate.
Special equipment could be a 4WD conversion. Or some sort of "back of cab" equipment like a Utility Bed, for an example. But obviously this wouldn't apply to a Uni.
*It could also be the A/C that this truck has.
The problem is, there is no way to discover what type of special equipment was installed, because the IDIOTS at FoMoCo THREW AWAY all the records decades ago!
