1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
more VIN numbers
Old Sep 22, 2013 | 09:29 PM
  #271
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Fasterskis
Welcome to FTE
F10 = F100 2WD
J = 223 1V I-6.
K = Kansas City MO Assembly Plant.
321450 = 1962, assembled August 1962.
114" Wheelbase.
B = Caribbean Turquoise.
F100 2WD, 5,000 lbs. GVWR
F = Borg Warner T-98 4 Speed Manual Transmission.
12 = Ford 9" Rear Axle / 3.89-1 / No Limited Slip / 3,300 lbs. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
114 net HP @ 3,600 RPM
51 = Denver CO Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Sep 23, 2013 | 08:26 AM
  #272
Fasterskis's Avatar
Fasterskis
Thanks to NumberDummy!
I appreciate your knowledge! You confirmed what I already suspected. Thank you.
Old Oct 5, 2013 | 03:41 PM
  #273
1961UNIGUY's Avatar
1961UNIGUY
Thumbs up New here.
I discovered this forum early this morning and have been excitedly reading and learning more about my '61 Unibody. I need to finish my garage with better information and will do so soon.
Using the information in this feed(?) I have decoded my VIN but have only partially figured out all the information on the plate on the inside of the glove compartment door, it gives the Model as F10C and have not seen anything about what this might mean, I also don't know what the 6 trailing numbers of the VIN mean (*****110594), any info would be greatly appreciated.
My VIN info:
F10CD110594
I believe the code translates as follows?
F10 = F100 2 wheel drive
C = 292 2
D = Dallas
and the 6 numbers that follow, I've no clue.
The plate on the glovebox door reads as follows:
Wheel base = 114
Color DM = D Indian Turquoise M Wimbledon or Corinthian White
I read Wimbledon White was no available until later?
Model F10C = I do not know what this means.
Trans A = Ford type 3.03 3 speed manual all synchromesh
Axle 11 = Ford 9" 3.70-1 non-limited slip 3300 pound capacity
Max GVW = 5000
Certified Net HP = 135 3800
Most of the information above no longer means a whole lot, other than satisfying my curiosity, because the pick-up's drive train has recently been replaced from the radiator to the rear end, but I'd sure like to know anyway. I couldn't afford an old 30's 3 window coupe, so I ended up with this beautiful old pick-up that my bank account will only let me slowly finish, but part's are readily available and I will have a blast playing with it.
Thanks, now I believe I will spend another few hours looking at everyone else's picture's od their pick-ups....
Old Oct 5, 2013 | 03:58 PM
  #274
NumberDummy
Originally Posted by 1961UNIGUY
I discovered this forum early this morning and have been excitedly reading and learning more about my '61 Unibody. I need to finish my garage with better information and will do so soon. My VIN info:
VIN: F10CD110594 / Warranty Plate: W.B. 114 / COLOR: DM / MODEL: F10C / TRANS: A / AXLE: 11 / MAX GVW LBS: 5000 / CERT NET HP: 135 / RPM: 3800
Welcome to FTE
Fixed it for you.
F10 = F100 2WD
C = 292 2V
D = Dallas TX Assembly Plant.
110594 = 1961, assembled November 1960.
114" Wheelbase.
DM: D = Light Blue / M = Corinthian White.
F10C = F100 2WD, 5,000 lbs. GVWR
A = Ford Medium Duty 3 Speed Manual Transmission (non syncro 1st gear).
11 = Ford 9" Rear Axle / 3.70-1 / No Limited Slip / 3,300 lbs. Rear Axle Capacity.
135 net HP @ 3,800 RPM
Ford type 3.03 3 speed all syncro trans introduced in 1963, Wimbledon White introduced in 1964.
Consider joining FTE's AZ chapter. Bill W is the chapter leader, posts in the 1961/66 forum, lives in Tucson.
btw: I can afford a '32/34 coupe, have wanted a '33 for many years, but I haven't a ghost of a chance in fitting in it.
There's an all original '33 3 window coupe and a mostly original '33 or '34 fordor sedan at Early Ford Store in San Dimas.
I didn't look close at the sedan to see what year it is. Slant of the grille, one ('33) or two ('34) hood handles per side are the major differences.
Old Nov 11, 2013 | 06:20 PM
  #275
62UniFORD's Avatar
62UniFORD
I've got one that I have been trying to figure out. It is suppose to be a 62 but the grill and all is pointing to 61 can you please tell me.
Old Jan 9, 2014 | 03:07 PM
  #276
Oldschool1962's Avatar
Oldschool1962
New Oldbie
need additional help
Post deleted
Last edited by Oldschool1962; Jan 9, 2014 at 03:14 PM. Reason: didn't realize thread was in the "Unibody" sub forum
Old Jan 9, 2014 | 05:34 PM
  #277
99F150's Avatar
99F150
looks to be a 1961 Monte Carlo red short box.
223 six , built in Mahwah NJ in march.
trans code A is 3 on tree axle code 11 is the 3.70.
Old Jan 22, 2014 | 04:20 PM
  #278
NumberDummy
Originally Posted by 99F150
looks to be a 1961 Monte Carlo red short box. 223 six, built in Mahwah NJ in march. trans code A is 3 on tree, axle code 11 is the 3.70.
F10JE154159 / W.B. 114 / COLOR: J / MODEL: F100 / TRANS: A / AXLE: 11 / MAX GVW LBS: 05000 / CERT NET HP: 114 / RPM: 3600
F10 = F100 2WD
J = 223 1V I-6.
E = Mahwah NJ Assembly Plant.
154139 = 1961, assembled March 1961.
114" Wheelbase.
J = Rangoon Red (J = Monte Carlo Red: 1957/60).
A = Ford 3 speed manual non syncro 1st gear.
Old Jan 30, 2014 | 06:32 PM
  #279
tripleframe's Avatar
tripleframe
B 5 axle code?
The '64 F 100-F 350 shop manual does not list this code New midyear option? Is this the rare spicer 60-2 instead of the spicer 44? Ratio?
Old Jan 30, 2014 | 07:38 PM
  #280
NumberDummy
B5 axle code?
Originally Posted by tripleframe
The '64 F 100-F 350 shop manual does not list this code.
Depends on...if it's an F100 (Spicer/Dana 60.2) or F250 (Spicer/Dana 60). "Locking" refers to Limited Slip.
Old Jan 30, 2014 | 08:53 PM
  #281
tripleframe
Thanks for posting the axle chart NumberDummy. In this case, it is actually a 4X4 F100. Very clean survivor. Ford F 100 Base | eBay
Old Jan 30, 2014 | 09:06 PM
  #282
NumberDummy
1964 F100 4WD production figures:
Cab & Chassis: 330 / Flareside Pickup: 802 / Styleside Pickup: 2,922.
Old Jan 30, 2014 | 09:26 PM
  #283
kjvforme's Avatar
kjvforme
That B5 code has got to be a rare one.
Old Jan 31, 2014 | 08:50 AM
  #284
BarnieTrk's Avatar
BarnieTrk
In the ad comments the seller is claiming,
"This truck has a heaver frame than the F-100."
I wonder where/how he determined that?
BarnieTrk
Old Jan 31, 2014 | 05:50 PM
  #285
tripleframe
BarnieTrk
Yours truly! That 120" wheelbase is a beast!
