1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
more VIN numbers
Old Aug 20, 2010 | 04:26 AM
  #76
Old_Crow's Avatar
Old_Crow
Hey Bill, they're still making the toppers today:
Sportz Tent III by Napier at StylinTrucks.com
Litte pricey if you ask me.
Old Aug 20, 2010 | 04:53 AM
  #77
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
This isn't what I was refering to, this is a tent.
Ford offered a Pick-up Convertible Top in black or white for short/long bed Styleside pickups.
This was basically a camper shell made out of vinyl, could be folded flat when not in use.
Had two porthole and two rectangular side windows, fold up/down back window made out of plexi-glas that faded away and turned brown within a few years that automakers once used for the back windows of ragtops.
Illustrated in the 1966 Full Line Accessory Catalog:
"A handsome new edition for Ford Styleside Pick-Up Trucks . . . for all weather cargo protection . . . converts up or down in minutes . . . available in white or black."
Short Bed $154.50: C6TZ-8150103-A (white) / C6TZ-8150103-B (black).
Long Bed $159.50: C6TZ-8150103-C (white) / C6TZ-8150103-D (black).
Recently I saw a new Tundra with something similar, so someone is making them.
Old Aug 20, 2010 | 01:43 PM
  #78
gangstakr's Avatar
gangstakr
[quote=ocbp1981;9226799]Hi all, I just purchased a 1966 F250 Camper Special and would like some help, I know it has a 1964 grille on the front and I would like to make it stock for 1966, how much would this cost to get a new grille installed?
Are you interested in a grille? Upper and lower valance? contact me when possible. 951-306-7805 or robert.regina@verizon.net
Old Aug 20, 2010 | 04:34 PM
  #79
Alexanderm's Avatar
Alexanderm
Thank you, Bill. Can you recommend a book that shows me the parts in my truck and how they fit together?
Old Aug 20, 2010 | 05:01 PM
  #80
NumberDummy
The 1964/72 Ford Truck Parts Catalog is available on a CD from hipoparts.com for $22.00.
A coupla years ago, I loaned my CD to Don (camperspecial65), he downloaded it into his computer, so he may be able to "burn" you a copy.
I'd loan you my CD, but garbz2 borrowed it recently to do the same thing, but hasn't returned it yet. AirHarley also took advantage of my largess.
Old Aug 20, 2010 | 05:31 PM
  #81
Alexanderm's Avatar
Alexanderm
OK, I'll pick it up. Thank you.
Old Aug 27, 2010 | 11:17 PM
  #82
ocbp1981's Avatar
ocbp1981
Truck not starting
I have had the 1966 F250 for a few days and wanted to change the gas cap from a plastic black one to a bright stainless cap. I went to unscrew the old gas cap and "unexpectedly"gas comes spraying out from the filler tube like a volcano all over the place. The truck had been parked in the sun a while if that matters??? I quickly put the cap back on and went to drive home but then the truck sputtered and would not start it turns over and dies. There is gas still in the tank.
I had to have it towed to a repair shop in Escondido CA. Does anyone know what could of caused this? The truck was running fine before the gasoline eruption. Does anyone have any mechanical shop recommendations in San Diego area I guess I will need one on retainer
Old Aug 27, 2010 | 11:55 PM
  #83
NumberDummy
How hot was it today in Escondido, 100 plus? It was at least 100 here in Hacienda Slights.
The fuel expands when it gets hot, you prolly had a full tank, so what you experienced is rather common.
NOTE: The In Cab fuel tank is not vented...so...make sure you have a vented fuel cap.
The original fuel cap was steel, painted body color. Ford also offered a chrome steel fuel cap.
There was no such thing as a plastic fuel cap...so whatever you have is in-correct, and may not be vented.
If the fuel cap is not vented, this could the cause of your problem and the fuel tank might collapse. Not pleasant!
FTE member AirHarley lives in Escondido, is a partsguy at a local chain autoparts store (I dunno which one).
C & G Obsolete Parts (in Escondido) prolly has the chrome version (B6TZ9030A) since it fits all 1948/69's, 1970/72's without Evap Emission.
Old Aug 28, 2010 | 12:31 AM
  #84
ocbp1981's Avatar
ocbp1981
Gas Cap
Thanks Bill, Funny you mentioned C & G that is where I was when I was replacing the gas cap with the B6TZ9030A. Now I just need to find out why the truck will not start.
Old Aug 28, 2010 | 12:48 AM
  #85
NumberDummy
I'll betcha the problem is related to vapor lock.
The steel fuel line routes from the In-Cab tank along the left frame rail, then to the pump.
V8: Another steel line routes from the pump, passing by the red hot left exhaust manifold on its way to the carb.
If the fuel in the line vaporizes (also common on a very hot day), the starter will grind on and on and on till the battery goes dead, but the truck will not start.
In the old days, people tried all sorts of cures for vapor lock, some worked, most did not. The most popular home remedy was to clip wooden clothes pins onto the fuel lines. No...I'm not kidding.
Another fixum was to pour ice water on the lines and the pump. People found out real quick that if ice water was poured on red hot cast iron exhaust manifolds by mistake, the manifolds could...and did CRACK!
People also wrapped the lines with asbestos, cuz they didn't know any better...about what we know today...about the perils of breathing asbestos fibers.
Old Aug 28, 2010 | 01:01 AM
  #86
ocbp1981's Avatar
ocbp1981
Vapor Lock
After the truck and gas cools over night should it start in the AM if it is Vapor Lock?
Old Aug 28, 2010 | 06:31 AM
  #87
gangstakr's Avatar
gangstakr
I have not heard from you. If your interested in these items, call or email. If not interested, call or email. At the very least respond to this thread. Others have asked for the grille.
<!-- / message --><!-- sig -->
Old Aug 28, 2010 | 06:42 AM
  #88
NumberDummy
Correctamundo....vapor lock goes bye bye when the temperature drops.
If the temperature was 90/100 degrees when you were parked on the hot asphalt at C&G, the temp under the hood could easily have been twice that...plus.
The second you turned the engine off, the fuel began vaporizing.
Old Aug 28, 2010 | 02:16 PM
  #89
SixtySix Ford's Avatar
SixtySix Ford
Heres my vin numba.... F10YK777484
Old Aug 28, 2010 | 02:23 PM
  #90
NumberDummy
F10 = F100 2WD / Y = 352 2V / K = Kansas City Assembly Plant / 777484 = 1966, assembled November 1965.
