1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
more VIN numbers
Old Nov 8, 2012 | 06:43 AM
  #241
ztagator's Avatar
ztagator
Tinsmiths made and repaired items of tinplate. No professional tinsmith would have accepted being called a tin-tapper. Tin-tappers were roaming metal workers that repaired dented or broken metal ware and did not create such items on their own.
To NumberDummy : What would be the first upgrades you would do with my stock 223?
Old Nov 8, 2012 | 07:14 AM
  #242
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
To NumberDummy: What would be the first upgrades you would do with my stock 223?
FoMoCo referred to the 223 as the Mileage Maker Six. There's not much you can do with it, cuz its get up and go, got up and went!
Change oil/filter, tune it up, rebuild carb, consider adding dual exhausts.
When you said tin tapper was from Vegas, I thought tin tapper had something to do with entertainment. Red Norvo was a tin tapper of sorts, played the xylophone.
Old Nov 8, 2012 | 09:20 AM
  #243
jacks61ford's Avatar
jacks61ford
put a Clifford intake , cam and exhaust oh ya
Old Nov 8, 2012 | 09:29 AM
  #244
NumberDummy
Clifford became famous for his speed equipment for the "Fabulous Hudson Hornets" with 308 cid L-head 6 w/Twin H Power that dominated NASCAR 1952/54.
Old Nov 13, 2012 | 01:29 PM
  #245
ztagator's Avatar
ztagator
Number Dummy ,,, What is the bolt pattern of the 2 intake plenum studs on the 1962 223 ? is it 2-11/16 or 2-15/16 ?
Old Nov 13, 2012 | 09:00 PM
  #246
garbz2's Avatar
garbz2
Originally Posted by Rod63Uni
Bill, can complete nut and bolt sets for different parts of the truck be ordered? My 63 uni project I got has the front sheet metal loosely bolted on with a few bolts. I looked at the hipo book, looks tough to find all the different part numbers. Rod
Complete bolt sets are available here. Great company.
http://www.totallystainless.com/2010.../catalog38.pdf
Page 65 66.
Garbz
Old Nov 14, 2012 | 03:19 PM
  #247
Rod63Uni's Avatar
Rod63Uni
Number Dummy, what is a 16412 or 16A550? It i on page 823 of hipo book. Big square thing that goes behind right inner fender? Looks like it has a bracket too, 16C568. Do I need this on my 63 UNI? Thanks, Rod
Old Nov 14, 2012 | 07:17 PM
  #248
NumberDummy
Couldn't find 16412. 16A550 is the basic part number for accessory splash (mud) guards that fit behind the dual rear wheels on 500 series and larger trucks, 16C568 are the brackets used to retain them.
These splash guards won't fit any pickup.
Old Nov 21, 2012 | 01:44 AM
  #249
Ianmattf100's Avatar
Ianmattf100
WOW!!! I think I just found out that my truck is a 1962 and not a 1963. I just bought it two days ago and was told it was a 63 but just ran vin and its saying sep 62 for the model. here it is... f10jr331231
Old Nov 21, 2012 | 07:45 AM
  #250
NumberDummy
Originally Posted by Ianmattf100
WOW!!! I think I just found out that my truck is a 1962 It's not, it's a 1963.
I just bought it two days ago and was told it is a 1963 but just ran VIN and it's saying Sept 1962 for the assembly month/year.
It's a 1963 that was assembled in September 1962. I decoded your VIN/Warranty Plate codes in your other thread, said the same thing.
New vehicle introduction time begins in September of the previous year, so...new vehicle production begins in August.
1963 serial number range: 325,001 - 445,000.
Notice the 2013 Escape in my sig. Purchased 10/15/2012, assembled 9/12 (September 2012).
And, btw: You posted this in the 1961/63 Uni forum. Your truck is not a Uni which has the bed welded to the cab. You have a short Styleside 1957/60 "wrong bed."
Old Nov 21, 2012 | 11:11 AM
  #251
Ianmattf100
Thanks Bill, yes I posted that just prior to seeing your first answer. I wasnt sure what defined a unibed and if I had one. Let me ask you is the term "wrongbed" just a nickname? Or is my bed from another model truck?
Old Nov 21, 2012 | 05:00 PM
  #252
NumberDummy
Thanks Bill, yes I posted that just prior to seeing your first answer. I wasnt sure what defined a unit body and if I had one.
Let me ask you is the term "wrong bed" just a nickname?
Or are these beds from another model truck?
Ford installed 1957/60 Styleside beds on the following 1961/66's:
1961/65 F100/250 4WD / 1961/66 F350 (9' Express) / 1962/63 F100/250 2WD / 1966 F250 4WD.
Called the "wrong bed" by enthusiasts, because the bed lines don't match up to the cab lines.
Old Dec 9, 2012 | 07:31 PM
  #253
HillBillyBuddha's Avatar
HillBillyBuddha
I'm mostly interested in the axle code "24" But I would like it decoded if you guys wouldn't mind?
I've figured that it was made in San Jose, TuTone Springtime yellow ? Wimbledon white. It's a 1966 Camper Special F250 w/ Custom Cab.
Last edited by HillBillyBuddha; Dec 9, 2012 at 07:36 PM. Reason: used wrong image code
Old Dec 9, 2012 | 10:16 PM
  #254
Ianmattf100
Has there been guys in the past to correct the wrong bed line match up? Can I drop the bed a bit with ease? Also I want to add that i TOTALLY FOUND A 9" CARRIER WITH A 3.25 AT THE YARD TODAY!!!! I spend abut two hours trying to get it pulled. Both brake hubs were stuck...pried those off after a longtime, then both axles were stuck...another one of prying and then finally got all the stuff off the punkin and got it out. I have never done this before and I have to say i am seriously proud at the moment. It came off alreally cool 72 ford shorty van. This thing still had the bubble windows in tack and all. heres what the tag says off the pumpkin.
wev-g / 2DC / 3.25 / 9 / 730A
Can someone decode all that? I for sure know its the 3.25 and 9 inch and i counted the spline...28! perfect.
Old Dec 9, 2012 | 10:43 PM
  #255
kjvforme's Avatar
kjvforme
I'll take a crack at it.
F25YR844517
F25 2 Wheel Drive 3/4 ton
Y= 352 CID, 2V carb
R= Assembled at the San Jose, Ca plant
844517 Assembled April 1966
129 Inch Wheel Base
8m Sprintime Yellow, Wimbeldon White
F250
D81: D = Light Beige Crush Vinyl & Medium Beige Ladder Pattern Woven Plastic // 81 = 81B Custom Cab.
Trans G Cruise-O-Matic Automatic transmission
Axle 24 = Dana 60 Rear Axle / 4.10-1 / non Limited Slip / 5200 lb. Rear Axle Capacity.
GVW 7500
172 HP
4000 RPM
71 Ordered by the Los Angles, CA District Sales Office, two digits, most likely bought of a dealers lot.
