The New Sled Puller.
Old Mar 3, 2010 | 07:56 AM
  #271
strokin'_tatsch's Avatar
strokin'_tatsch
Originally Posted by DZL JIM
Cuz then you can hang a sheet load of weight way out front where you really need it.
mainly b/c cody has always wanted a single cab 4wd dually 5 speed and then they started getting into sled pulling. now i think he wants to have one for the street too, but don't think he will be getting another for a little bit. LoL. longer wheel base usually has more leverage going to the front and do better pulling, but i have no clue why b/c the single cabs you can hang more weight out front being that they weigh less.. so in the end i still don't know which would be better, a single cab or an extended cab or crew cab. LoL
Old Mar 3, 2010 | 08:30 AM
  #272
CampSpringsJohn's Avatar
CampSpringsJohn
I would think that the farther away from the hitch you can hang the weight the better. So, wouldn't the longest truck you can run be the best?
Old Mar 3, 2010 | 08:47 AM
  #273
strokin'_tatsch
yes, to a point, but the longer trucks also weigh a heck of a lot more than the regular cab. a crew cab can easily be over the 8K pound weight limit. LoL. so with the regular cab there is a lot more weight that can be put up there, but the longer truck probably still better.
Old Mar 3, 2010 | 11:08 AM
  #274
Talyn's Avatar
Talyn
You trying to say there is a weight limit Travis?
So with the short truck, you can hang more weight out front than a long truck to meet the weight limit.
Old Mar 3, 2010 | 02:30 PM
  #275
strokin'_tatsch
yeah the weight limit is 8000 lbs, but the longer truck would have a more leverage than the shorter truck. the leverage would probably do more than the extra weight on the front of the short truck, but length does nothing if you don't know how to set up a truck and i assure you all that the C O D Y's truck is going to be set up damn good when he gets done!!
Old Mar 3, 2010 | 03:48 PM
  #276
Talyn's Avatar
Talyn
Well, you put leverage by hanging weight out front.
If you set it up right, you'll get better distribution on the front wheels with a SWB and weight out front.
Thats just my thoughts anyways.
While leverage is good, I think the same principal will apply with a properly setup truck with weights up front.
And perhaps work better.
Just as long as your not in reverse when you take off.
Old Mar 3, 2010 | 03:54 PM
  #277
foxracing0934's Avatar
foxracing0934
I don't know to much about sled pulling, but I know that when it comes to plowing snow the longer the wheel base is the better traction you get, to a certain point. On of the other guys that plows for me has a cc lb srw and that thing out pushes mine all day and he's running a fatter tire, which is worse in the snow.
Old Mar 4, 2010 | 10:16 AM
  #278
cowmilker08's Avatar
cowmilker08
All I know is that JD tractors (older farmstock) weigh less than IH and that gives them a distinct advantage in the flexibility of how to weight the tractor.
Old Mar 4, 2010 | 11:59 PM
  #279
RubberDuck's Avatar
RubberDuck
I just love the single cab 4x4 dually's. And since you can't get one with a bed on it, it makes it unique. And I gotta be different. Not to mention, the just look bad ***. Rockee did real well pulling, but I wanted a puller only, so that's what I'm building.
Anyway, here's an update. Today we got back on the chassis. But we had a "delayed" start so to speak. On the way to the shop, I was racing one of our Dodge guys, Gary. Well, I grabbed 4th apperently too hard and fast. The motor hit red line and no more forward or backward motion. LOL So I grenaded something. Probably an input shaft, or tail shaft. But we'll have to wait to see what. So I'll be drivin' my F150 for a while. LOL
But not to be sidetracked, we loaded Rockee on a trailer and proceeded to the shop. I took pics of the progress, but we should be done tomorrow, so I'll wait. I promise, it will be worth the weight, cuz it's turning out so AWSOME!!! So I'll have an update this weekend.
Old Mar 5, 2010 | 12:53 AM
  #280
foxracing0934
AHHHHH the suspense is killin me Cody, can't wait to see this suspesion that your cooking up. Sux to hear about Rockee, but now you can get a cryo'd one in there. Travis was telling me about a great place to get stuff cryo'd, they were pretty cheap IMO and they had a different proccess than most of the other company's that I was reading about. I believe the companies name was 300 below
Old Mar 5, 2010 | 06:06 AM
  #281
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
There are different schools of thought on the long wb vs short wb.
One is that the long wheel base gets you greater leverage on the rear tires. Air them up good cuz a lot of the weight will be on them, and not a whole lot will be on the front. Or run duallys, like most of them.
The other is that the short wb (lighter truck) allows you to put a ton of weight over the front axle to get lots of traction with the front tires that you don't get with a long wb. There are tricks in setting up short wb for sure.
I have seen Ext cab short bed trucks with hanging weights pull very well against the cc long bed trucks that can't hang weight due to limits.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Mar 5, 2010 | 08:05 AM
  #282
Talyn's Avatar
Talyn
I'd go with weights and traction.
When I watch sled pulls, it seems like you want to keep all 4 on the ground unless its tractors, then who cares, only turning 2.
Bummer on Rockee Cody.
Old Mar 5, 2010 | 06:31 PM
  #283
strokin'_tatsch
He knows about it, but i doubt he will do that. LoL. i just got done talking with them. they have a minimum $100 limit. so if you send them 10lbs of stuff it will be $100 or you could send them 28lbs and it will be $100. they charge $3.50/lb so they can do 28.5lbs for the minimum $100 limit so once you get over 28.5lbs it will get more expensive. they sent me the price list. $400 to do a block. $75 for a set of rods. Also, they gaurantee 50% stronger.
Old Mar 5, 2010 | 07:32 PM
  #284
foxracing0934
that is fricken awsome. I'm seriously considering having my heads done after I get them ported.
Old Mar 7, 2010 | 10:04 AM
  #285
RubberDuck's Avatar
RubberDuck
Okay, I'm not gonna post all my pics, but here's some in order....
Broken Rockee
Building the chassis.
