FICM testing procedure
Old Jun 16, 2011 | 09:22 PM
  #256
FICMrepair.com's Avatar
FICMrepair.com
Former Vendor
It's very common to find one of the three connectors not fully seated. Perhaps that's what happened here. All three must click into place. Any less and things could work their way loose over time causing all sorts of issues.
Old Jul 17, 2011 | 12:13 PM
  #257
Snowalex_53's Avatar
Snowalex_53
Ok my volts when just key on was 36 for the first screw and 13,.5, 4 in the order of screws from drivers side to passenger. Then when starting the first screw was 60 then 14,.1,.6 so does this mine is shot?
Old Jul 17, 2011 | 01:39 PM
  #258
FICMrepair.com
Former Vendor
Not shot, perhaps, but definitely in need of service.
Ed
Ed@ficmrepair.com
Old Jul 17, 2011 | 01:48 PM
  #259
bismic's Avatar
bismic
Since I started the thread, I guess I can hijack it!
Ed - my repaired FICM has been working great (not in my truck, but I loaned it to a friend). Thanks!
Old Jul 17, 2011 | 08:38 PM
  #260
FICMrepair.com
Former Vendor
I'm very glad I was able to help out, Mark! Thanks for the kind words!!
Old Jul 19, 2011 | 09:26 AM
  #261
Pitchinfool's Avatar
Pitchinfool
This is a great post. My problem started Sunday morning. Went out to start my truck and it didn't start right up. It started after a cranking it for a short bit. Ran and started fine rest of day. It has done the same thing Monday and this morning. I am getting the FICM checked Thursday. It is throwing two codes, P2284 and P2291. Could a weak FICM cause the codes? I have a March 03 build F250, 6.0, remote starter and Super Chips Tuner. I put it back to stock last night and cleared the codes. Thanks for any responses.
Old Jul 19, 2011 | 02:10 PM
  #262
FICMrepair.com
Former Vendor
The P2284 code is typically the ICP sensor, not the FICM. The P2291 code is definitely related as it is indicative of too low a pressure while cranking. I'd have the ICP sensor changed out and see if that takes care of you. The other option is that the STC fitting came apart or that the high pressure oil rail port plug o-ring decided it didn't want to live anymore. Regardless, it doesn't sound like the FICM (as much as I'd like to take care of you if it were... ).
Ed
FICM Repair.com - Your Source for FICM Repair
Old Jul 19, 2011 | 08:07 PM
  #263
Pitchinfool
Ed
The thing is that I am not having any of the symtoms related to a bad ICP sensor (from what I read). After the truck starts, it runs great and starts fine the rest of the day.
Old Jul 20, 2011 | 04:44 AM
  #264
npccpartsman's Avatar
npccpartsman
Pull the IPR and see if the screen is compromised. P2284 and P2291 are a little different to diagnose but you definitely have a HPO problem not a FICM problem.
Old Jul 20, 2011 | 01:34 PM
  #265
DougThePilot's Avatar
DougThePilot
Cool Help!
I have a 2006 F350, 6.0, 107,000 miles. I have codes P0264, P0267, P0270, P0273, P0276, P0279 and P0282. All codes read "Cylinder Injector Circuit Low" for all respective cylinders. I DO NOT have code P0611. I have tested the batteries, both read 12.4 volts. When testing the FCIM:
While turning the key on: 48.2 Volts
With the key on: 48.2 volts
While cranking: 20.4 volts
All tests were done with the negative side of the tester on the negative side of the battery and the positive side on the screw closest to the drivers side of the vehicle.
I have been unemployed for 10 months and can not afford to take this to the dealer nor can I afford to fix something that isn't the problem. If anyone can clarify that the problem is indeed the FCIM I would be eternally grateful.
I have more time than money. If this is the problem perhaps you could suggest a place that can repair the FCIM in a reasonable amount of time for a reasonable price?
If a repair is done, will the dealer have to do anything to the FCIM/Truck for it to run properly?
Old Jul 20, 2011 | 01:40 PM
  #266
bismic's Avatar
bismic
$225 at FICMrepair.com - 1 yr warranty
Your FICM is indeed bad. After repairing it, nothing is needed at the dealership (assuming you can remove it and re-install it yourself - which is pretty easy).
Old Jul 20, 2011 | 01:48 PM
  #267
DougThePilot
Help!
Thank you very much for your response. The reason I questioned it was after reading many posts regarding this issue, most say that I should also have the code P0611, which I do not.
I see the four bolts/nuts holding the unit to the vehicle but from where I stand I can't see any electrical plug(s). Is it on the bottom of the unit and will I be able to see how to disconnect once the four bolts/nuts are removed?
Old Jul 20, 2011 | 03:12 PM
  #268
william_04_x's Avatar
william_04_x
Yes, there are 3 connectors attached on the bottom of the FICM. Here's a link to the ficmrepair.com site.
Here's a link to a thread with testing and removal videos.
Old Jul 25, 2011 | 08:12 PM
  #269
Pitchinfool
Ed
I cleared the codes and ran it over the weekend. I pulled the codes today and now I am getting 1 code,
P123;
Anyone know what this is?
Old Jul 25, 2011 | 09:26 PM
  #270
james oden's Avatar
james oden
Thanks Guys
I did the FICM test and repair this weekend and now my truck is back to normal. Before repair 48 volts key on and 29 volts started. After repair 48 volts key on 41 volts running.
