FICM testing procedure
Old Jul 26, 2011 | 05:24 AM
  #271
npccpartsman's Avatar
npccpartsman
Originally Posted by james oden
Thanks Guys
I did the FICM test and repair this weekend and now my truck is back to normal. Before repair 48 volts key on and 29 volts started. After repair 48 volts key on 41 volts running.
The FICM voltage should NEVER fall below 45V. Your FICM still isn't up to snuff. Have you had a complete charging system test? Batteries load tested, alternator output, etc?
Old Jul 26, 2011 | 08:04 AM
  #272
davidkstyler's Avatar
davidkstyler
Originally Posted by Pitchinfool
I cleared the codes and ran it over the weekend. I pulled the codes today and now I am getting 1 code,
P123;
Anyone know what this is?
I have attached a pdf file of codes.
Not sure what it means!
File Type: pdf
Old Jul 26, 2011 | 03:30 PM
  #273
Pitchinfool's Avatar
Pitchinfool
P123;
Looks like it has something to do with the fuel pump. I have been leaving the key on for a cople of minutes before starting and it will start right up. Before I was having to mash the throttle about half way. I am going to clear the code again and see if it re-apears. Thanks.
Old Jul 26, 2011 | 04:10 PM
  #274
davidkstyler
So you are seeing a P1230, and not a P0123 code?
You do need to leave the key on until the glowplug indicator in the instument cluster goes out before you start.
Old Jul 27, 2011 | 03:58 AM
  #275
npccpartsman
FYI--mashing the throttle will do absolutely NOTHING on startup. It doesn't open a butterfly or give more fuel. The throttle is fly by wire--all electronic. Startup is all by PCM commands.
Old Jul 27, 2011 | 02:03 PM
  #276
Pitchinfool
The code actually read "P123;"
I looked in my Super Chip code book and P1230 thru P1239 deals with the fuel pump.
I tried to start it normally this morning and it fired right up then died. I turned the key back on and waited a minute before trying to start and it fired up but I had to work the accelerator pedal a bit before it cleared up and idled fine. It seems like it is not getting enough fuel for it to start and idle normal. Any ideas would be appreciated. I don't want to start replacing unnecessary parts.
Old Jul 27, 2011 | 02:14 PM
  #277
bpounds's Avatar
bpounds
Those codes are for gassers. Not valid for diesel. The 6.0 doesn't have a fuel pressure sensor, so it has no way of knowing if your fuel pump has a problem.
I think you either read the code wrong, or your reader does not properly read diesel codes.
All codes need to start with a letter, followed by 4 alphanumeric digits.
Old Jul 27, 2011 | 03:27 PM
  #278
davidkstyler
Installing a fuel pressure gauge would be useful, Amazon has one that is not too expensive. Amazon.com: Tinted 7 Color 100psi Fuel Pressure Gauge: Automotive
As stated above there is no fuel pressure sensor so you have to install the sensor in filter body. You will need an adaptor such as this DieselManor - Accessories and a 45 deg elbow.
<TABLE style="BORDER-COLLAPSE: collapse" borderColor=#111111 height=1 cellSpacing=0 cellPadding=0 width="99%" border=0><TBODY><TR><TD vAlign=top align=middle width="16%" height=28></TD><TD vAlign=top align=left width="81%" height=28>ISSPRO Metric Adapter
M12x1.5 (male) x 1/8" NPT (female) <TABLE id=table23 width=504 bgColor=#ededef border=0><TBODY><TR><TD vAlign=top width=273>Part #: R7962 Price $6.95</TD></TR></TBODY></TABLE>
Here is a link to a thread that covers some of the options, some people like to use a short hose to get the sensor away from the engine.
https://www.ford-trucks.com/forums/1...-question.html
IIRC the minimum pressure you need is 45 psi under full load. There is a blue spring kit that you can install that will help raise fuel pump pressure. Running with low fuel pressure will damage your injectors which can be very expensive ($2-3k). The gauge is very useful!
Old Jul 28, 2011 | 09:42 AM
  #279
Pitchinfool
<TABLE style="BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 borderColor=#111111 cellPadding=0 width="99%" height=1><TBODY><TR><TD height=28 vAlign=top width="16%" align=center></TD><TD height=28 vAlign=top width="81%" align=left>ISSPRO Metric Adapter
M12x1.5 (male) x 1/8" NPT (female) <TABLE id=table23 border=0 width=504 bgColor=#ededef><TBODY><TR><TD vAlign=top width=273>Part #: R7962 Price $6.95</TD></TR></TBODY></TABLE>
I will check out the fuel pressure guage. Where do I buy the blue spring kit you mentioned that will boost my fuel pressure? Thanks for your help.
Old Jul 28, 2011 | 09:52 AM
  #280
Pitchinfool
The code has me stumped as well. Codes I have pulled in the past were always as you mentioned above. This is the only time I have ever seen a letter, 3 alphanumeric digits, and a semi-colon (P-123. I cleared the code and will check it again in a couple of days. I am thinking about changing out the fuel filters to see if that makes a difference. Thanks for your help.
Old Jul 28, 2011 | 10:54 AM
  #281
davidkstyler
Here's one option for a Ford kit, you can also search eBay, you may find a better offer.
www.partsguyed.com
It's best to have a fuel pressure gauge in place before you start changing fuel pressure because over pressure can blow out injector "o" rings!
Do a quick search for Blue Spring on the forum and you will find lots of threads.
Some people have placed a BB pellet behind the old spring, but without a pressure gauge you don't know what the new pressure is.
Take a look in the Tech Folder
https://www.ford-trucks.com/forums/9...-pressure.html
Minimum at wide open throttle - 45 psi
Maximum - 75 psi
Old Jul 28, 2011 | 11:02 AM
  #282
Pitchinfool
www.partsguyed.com
Maximum - 75 psi
That makes sense. I am glad you pointed that out. I will work on getting a fuel pressure guage first. Thanks again.
Old Jul 28, 2011 | 01:52 PM
  #283
davidkstyler
There's a long discussion on Blue Springs in this thread and the International part # is on the first page. IH parts are typically less expensive than Ford.
Old Jul 28, 2011 | 03:05 PM
  #284
Pitchinfool
What thread are you referring to? I check this one and nothing came up.
Old Jul 28, 2011 | 04:30 PM
  #285
davidkstyler
Sorry, I forgot to paste the link https://www.ford-trucks.com/forums/1...it-or-not.html
See post #6 in this thread for the IH part number.
