I have a 2003 F350 crew DRW and I was wondering after reading all of the posts, I have a #4 injector contribution fault and I was wondering if the FICM can cause this or if it is a injector only problem. I get a surging at cruising speed in normal drive mode, if I use tow haul and the RPM"s are higher there is no surging.
I was thinking that my transmission was going bad but now after reading here I think otherwise. Any input would be great, and by the way it sounds like everyone one here are some stand up guys. Thanks in advance!!
From what I have read, a dieing FICM can cause those problem. Most of the time the injector needs to be replaced. The only way to know is to pull out a voltmeter and check the voltage output of your FICM.
A surging problem on a 2003 is most likely an ICP sensor problem. There is a repair procedure in the tech folder for that. I would start testing there and then move to the injector. Normally with a FICM you have multiple injector "failures" but they don't show as contribution balance codes, they show as circuit codes. A C/B code "usually" indicates a bad injector.
brickie...awesome write up. I get everything you were saying...just hate to say it...I can't make out the good from the bad solder joints you were referring to. I think its great that here is another example of how we can take care of our own corrective mantenance of our trucks...without spending a small fortune paying someone else to DIFM.
Hi, good solder connections are usually shiny, bad ones dull, just apply a hot soldering iron, sometimes add just a bit of solder to fix them.
I had to replace the number 4 injector and tested the FICM and there was a few bad spots in it. I did the connections on the FICM and the tested the voltage and everything runs great again. Thanks for the support guys!!!
If the injector voltage is over 35 volts, they run OK, although not as well as when it is 48 volts.
If the voltage drops below around 24 volts, the injectors cannot fire.
While most scan tools will display the FICM voltage, they do not always show the correct value.
For instance, AutoEngenuity can only display voltages between 40 to 56 volts, so if the voltage is 35, it will display 40.
5a. Have an assistant cycle the key and measure the voltage during the initial key-on buzz test. Voltage should not drop below 46 volts.
6a. Next measure the voltage while cranking the engine. If voltage stays at or above 45-46 volts, the FICM is fine. Abnormally low battery voltage can give a false low FICM voltage reading, so make sure your batteries are good.
If the voltage is above 46 volts in all the tests, your FICM is in excellent condition.
If it is between 36 and 45 volts its OK, but not great. If it is between 25 and 35 volts, you have serious FICM problems.
CORRECTION!!
I wish I could edit the first post, but this will have to do for now ......
Your FICM should be over 45V at all times or it is time to replace it. Personally, from what I read, I would be replacing it if it were under 46V.
Also, if the voltage is low, it needs to be replaced. However, even if the voltage checks good - the FICM could still be bad (components failed other than the DC/DC converter board).
Great info! I 've been having a starting problem with my '04 6.0 - to the point where it won't start, so I justed tested the FICM and got a reading of 19. From what I've read on here I have a serious FICM issue but the good news is that I've diagnosed the problem. I'll be shipping my FICM out this afternoon. I just hope it's not too far gone.
Reason: mis-spelling
Does the FICM only act up for starting or can it affect performance when all warmed up on the road?? stock 2005 6.0L staggers and surges at all speeds, starts easily but rough, noisy injectors till warm, Idles great, but then on the road (intermittantly starts stalling, stuttering. new oil and fuel filters, tried disconnected ICP, fuel pressure rock steady at 60 PSI. Nothing has worked. No Codes on my reader. maybe this is a topic for a different thread but I'm desperate!!
Reason: update
I just checked mine this weekend. 48.7v (key on/engine off), and 48.3v while cranking. My test probe accidentally touched the FICM housing and sparked. I thought for sure I fried it, but I tested it 3 more times after, and got the same results. Fingers are crossed.
A dying FICM can indeed cause those issues, but I tend to agree that the likelihood is that it is injector and not FICM related. You can check the voltage with the volt meter as suggested, but a Scan Gauge II is a handy and easier way to test it while giving a wealth of other information and preventing the possibility of shorting the leads to the case.
Mark is correct that 'just' because you have 48 volts doesn't mean that you have a good FICM, but low voltages are the #1 problem with them. Remember also that bad connections cause heat and heat kills or minimally shortens the life of electronics. I'd replace the board level components myself rather than simply re-solder and hope that things stay working for the long haul.
I checked my voltages which were great, 47.9V while cranking, 48.6V otherwise. I took my FICM apart just to check it with a magnifing glass, it looked perfect, put it back in and connected it and my problems were gone. Either a connection was loose or taking it apart cleared its memory and capacitors or something. No issues since... how's that for weird??
