FICM testing procedure
Old Feb 17, 2025 | 01:44 PM
  #361
bismic's Avatar
bismic
That is why I posted about using WiFi a few times, not BlueTooth. I don't think OBDLink MX+ can work with BlueTooth on an iphone.
Old Feb 17, 2025 | 01:48 PM
  #362
alicejoe1!'s Avatar
alicejoe1!
How the hell do I go Wi-Fi it says Bluetooth I’ll see if it will link up with wifi
Old Feb 17, 2025 | 02:40 PM
  #363
bismic's Avatar
bismic
On the iphone:
First you must have downloaded FORScan Lite.
Then plug the OBDLink MX+ into the OBDII port and turn the Key to "ON"
Go to settings
Go to WiFi
Turn on WiFi
Choose the OBDII network
Touch the FORScan Lite Icon to start it.
Touch the word CONNECT so the FORScan on the phone will communicate through WiFi with the PCM.
Old Feb 17, 2025 | 03:20 PM
  #364
alicejoe1!'s Avatar
alicejoe1!
That’s ll I have no place is OBDLINK
Old Feb 17, 2025 | 03:24 PM
  #365
alicejoe1!'s Avatar
alicejoe1!
Thanks for all your help but I can’t do it anymore when I can get someone over here with a reader that they know how to use then maybe I’ll get an answer I’m sending the OBDLINK back f@#$ing place that sells them has no tech service so up theirs
Old Feb 17, 2025 | 03:27 PM
  #366
bismic's Avatar
bismic
The OBDII adapter must be plugged in with the key on for the phone to find it. That said, I hear you and wish you well in whatever direction you choose.
The OBDLink MX+ works very well for me.
Old Feb 17, 2025 | 03:31 PM
  #367
alicejoe1!'s Avatar
alicejoe1!
Yup had it plugged in Bluetooth recognizes it tried to plugged in Keon. I don’t know maybe it’s my truck. I’m not stupid. This is absolutely ridiculous. Thank you for your time.
Old Feb 17, 2025 | 03:46 PM
  #368
bismic's Avatar
bismic
Did you load the OBDII app that came with the adapter? If so, then that is the issue (it is only BlueTooth I believe). You want to ONLY use the FORScan app (not the app that came with the adapter). If it isn't that, then I'm out of ideas.
Old Feb 17, 2025 | 09:00 PM
  #369
TooManyToys.'s Avatar
TooManyToys.
I won't go out to my truck while waking up my wife, so this will be abbreviated for now.
Get into the truck and plug in your OBD2 adapter. I always turn to key-on - wait to start.
Go to settings on your phone.
Go to Wi-Fi.
Turn the Wi-Fi off.
Turn Wi-Fi back on. As it populates, you should see your OBD2 as one of the choices. Tap that. Then, you can back out and click on ForScan.
Click on Connect. It will take a few sweeps.
Old Feb 17, 2025 | 10:17 PM
  #370
alicejoe1!'s Avatar
alicejoe1!
I took a nap I just woke up and saw your post about the adapter app yes I did download it I I just removed it and I will try again in the morning thank you !!!
Old Feb 18, 2025 | 09:55 AM
  #371
alicejoe1!'s Avatar
alicejoe1!
Go to Wi-Fi.
Turn the Wi-Fi off.
I tried it WiFi will not recognize it it will connect through Bluetooth and sys connected but nothing on the screen on any of the choices on FORscan I give up I’m sending back OBDLINK maybe try another OBD or just tear it down when the weather warms up hopefully end of next month and try to see the problem with my eyes and not diagnostics
Old Feb 18, 2025 | 10:12 AM
  #372
alicejoe1!'s Avatar
alicejoe1!
I have someone coming over with a good ficm to try and a computer to see if we can get Hpop pressure so thanks to all that have tried so hard to help me should have an answer late today again thank you guys
Old Feb 18, 2025 | 10:43 AM
  #373
TooManyToys.
Then it seems it's not a Wi-Fi, or the Wi-Fi is not working out of it.
The two adaptors I use are no longer available, and they were $20 and $25.
This one may be worth a try.
Old Feb 18, 2025 | 11:25 AM
  #374
alicejoe1!'s Avatar
alicejoe1!
Thanks I ordered it give it a try tomorrow 👍
Old Feb 18, 2025 | 04:51 PM
  #375
alicejoe1!'s Avatar
alicejoe1!
tried ficm no dice going to do air test in the next couple days weather will dictate that thanks for all the help you have given me wouldn’t be so bad if it was 40 degrees instead of 15
