FICM testing procedure
Old Mar 2, 2025 | 11:41 AM
  #391
alicejoe1!'s Avatar
alicejoe1!
Originally Posted by bismic
Very possible.
hi me again put new Hpop j tube all that stuff I broke a couple of injector plugs I have replacements but my question is I left 2 brand new batteries hooked up while I did this now have to totally dead batteries took ground cables off both batteries ( I had recharged them) don’t have an amp meter I hooked up volt meter to ground post on battery and other end on ground cable I’m showing 12 volts on either battery I test I unhooked alternator nd still get 12 volts am I right that I have a short?
Old Mar 4, 2025 | 12:48 PM
  #392
Piper180C's Avatar
Piper180C
7th Gear
-> Bismic
Apologies I have to write my question to you in the wrong thread but I can't directly message you because my account is new but I know you could help me with my issue. I'll try to explain and make it short. I lost an engine, pulled the cab, got seriously injured and a year later I dropped it back on with the "new" motor. When it was out I cleaned all the cab connectors and marked them. Marks disappeared and I replugged them in incorrectly (I'm fairly certain of that). Powered the cab and with a key turn, heard the injectors buzz but no fuel pump no tail lights either. Revisited the plugs and realized I had a couple wrong (90% sure of that). Matched the wire colors from male to female and had to switch 2 around (grey ones). Hit the key, no injector buzz, no fuel pump, ignition rotation leads to relay clicks in cab and in junction box under brake system. I also cannot access the obd2, no communication, verified with 2 different devices that work on another vehicle. As per another post you helped with, I unplugged the fan plug, egr valve plug, then finally the transmission connector (at pcm) and middle plug (engine) no pcm communication. Also before that, no pump/starter in neutral or park and no backup lights after I switched the cab connectors but all other internal electrical items now work post connector swap(heater fan/seats/window/radio etc).
So I'm stumped. I feel like I have the cab connectors correct. I don't have reverse lights, no fuel pump and my gut tells me this is not the harness to the engine (all fuses are good too) . I was very careful to install all grounds after thorough cleaning. The starter works when triggered by the passenger side wire junction, so it's good. Connection at the fuel pump are good. I removed the Pcm and noticed a slight burn smell at the cab to pcm plug location, I'm thinking maybe I accidentally fried an internal component when I hooked the cabin connections up incorrectly. FWIW, the dash cluster lights up, shows mileage, glow plug light cycles, abs light is on, fuel guage works, spun the engine over with the wire as I mentioned with key on and oil pressure guage came up after the prime.That's where I am at currently. Could really use some advice. Pcm toast?
Happy to pay for your time as well. Just want to get this truck running again.
​​​​​If preferred, you can DM me. 🙂
Sincerely, Michael
Old Mar 4, 2025 | 02:07 PM
  #393
TooManyToys.'s Avatar
TooManyToys.
@bismic
Old Mar 4, 2025 | 02:13 PM
  #394
bismic's Avatar
bismic
I am going to have to pass on helping. Just not my "bailiwick"
Old Mar 4, 2025 | 02:16 PM
  #395
Piper180C's Avatar
Piper180C
7th Gear
Thumbs up Thank you
Thank you.. BTW, I have watched so many of your videos, super helpful. You are the kind of person I love to follow because you are such a fact based, seriously meticulous mechanic. :-) Awesome workmanship!
Old Mar 10, 2025 | 06:21 PM
  #396
alicejoe1!'s Avatar
alicejoe1!
Here we go again
I put Hpop in truck ran ok no boost I pulled the turbo took it apart ring was bad took 1 off a parts truck I have checked it out cleaned it put it on went for a test drive had good power but kept blowing turbo hose off passenger side took the hose and pipe off cleaned it good went out for test great till it hits around 2800 cuts out stays running and will go up to around 3200 when not just going wot and runs fine then coming back shut down won’t turn over wait a few minutes and starts I put my hand on ficm and it was very hot is that supposed to be like that only showing one code p132b I ran it a couple of days it ran fine but turbo wasn’t doing anything I’m totally confused HELP PLEASE
Number21
Nov 4, 2013 10:09 AM
JonArmy
Apr 27, 2013 10:19 AM
1957F100
Feb 9, 2013 07:38 AM
dakotajeep
Jan 28, 2012 12:04 PM
hndacr
Mar 15, 2010 07:35 PM
