Sponsored by: Real Truck
Gas vs PSD
Old Jun 16, 2011 | 08:57 AM
  #12136
LSchicago2's Avatar
LSchicago2
Originally Posted by dkf
With the upcoming mpg regs I highly doubt it. Concept vehicles, rumors and etc often never make it to production.
Class 2 and up trucks are not subject to mpg regs yet.
Old Jun 16, 2011 | 09:37 AM
  #12137
'89F2urd's Avatar
'89F2urd
Originally Posted by Krewat
Untrue. The engine doesn't push "air" out.
and, if you quoted my entire post, anyone could see that i didnt stop there. the engine DOES push air out (try building a motor that closes the exhaust valve without allowing the piston to have a complete "up" stroke, it will run awful or not at all because there would be too much exhaust left). but thats beside the point. the point was, the air alone that the engine pushes out is far less than what the turbo can push in. so, if you included the rest of my post in your quote, it could be easily seen that i was makin the point that THERE MUST be something besides air driving the turbo. i.e. thermal energy from combustion.
The intake charge contains oxygen, which is used to burn the fuel. The result of that oxidation is MUCH MORE exhaust volume than intake.
The exhaust is very compressed while still in the cylinder. As the exhaust valve opens, that gas continues to expand. (the combustion is still taking place) Creating sound as it pushes out the exhaust port rapidly. Which is why open pipes are so freakin' loud
you just said thermal energy drives the turbo, and didnt even know it
A turbo or supercharger is a positive-feedback loop. Push slightly more O2 into the cylinder, get a LOT more power. More power than is used up to push the turbo (or supercharger).
a turbo doesnt rob much hp from the motor. it harnesses energy that would otherwise be wasted. a supercharger has nothing to do with wasted energy, and gets its energy directly from the crankshaft. the energy to drive the supercharger has already been converted from thermal energy to mechanical energy. it doesnt take much hp for the pistons to push against 40-60 lb's of drive pressure (the combustion helps push it out also). it takes massive amounts of hp to drive a supercharger at high rpm. the fact that turbo's dont take much hp from the motor is just another indicator that it operates off of thermal energy. a turbo is a thermodynamic device, a supercharger is not.
responses red
Old Jun 16, 2011 | 09:40 AM
  #12138
dkf's Avatar
dkf
Like I said upcoming. Fleet mpg and CAFE are still affected.
Old Jun 16, 2011 | 09:57 AM
  #12139
'89F2urd's Avatar
'89F2urd
Originally Posted by physmanics
I see carbon dioxide and water, not oxygen gas after the reaction
H2O is not a different form of oxygen. Its a different compound in which elemental oxygen can exist.
Don't confuse the conservation of mass as amounts of each compound staying the same. There is oxygen gas present in the intake, but much much less oxygen gas in the exhaust
That did help me notice I mistakenly said consumed however.
the point he was trying to make, which is a valid one, is that there is the same amount of oxygen present before and after combustion. it just changes forms. assuming his compounds are correct (ive seen them before and they do look right) there are 50 atoms of oxygen present before and after combustion (for gas). elements, like energy, cannot be created nor destroyed. they can just change forms (change what they cling to to make different compounds).
Old Jun 16, 2011 | 10:12 AM
  #12140
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Which creates the heat, which drives the turbo, which makes the PSD a far more thermodynamically efficient power plant than the V10.
Old Jun 16, 2011 | 10:48 AM
  #12141
BigF350's Avatar
BigF350
FTE Emeritus
Originally Posted by exiled
I want to understand this. How do you have same amount of o2 after combustion? To have combustion/flash you have to have 3 things. Heat/energy, a fuel source and o2. If you remove any one of the 3 you don't have a flash. O2 is burned. Take a candle light it put it under a jar and it will burn out. Why? It burned all of the o2. I do not understand your claim you have same amount if o2 on both sides.
Perhaps I was being a little pedantic.
Oxygen gas (O2) is used in the combustion process, but Oxygen atoms are still present as the result, in the form of CO2 and H2O
I probably could have explained it better. The point I was trying to make is that no elements in the process are lost, or gained. (i.e. you put the same mass of fuel/air in - as you get C02 and H20 out).
The only difference between what is coming in, and what is going out is the temperature, which generates the greater pressure/volume.
Old Jun 16, 2011 | 11:00 AM
  #12142
BigF350's Avatar
BigF350
FTE Emeritus
Which is a good point
Even before turbocharging, diesel engines are more efficient than a gas engine
Old Jun 16, 2011 | 12:39 PM
  #12143
parkland's Avatar
parkland
Just reading about the 6.4 ,
exhaust at full throttle appears to only be close to the 3x intake CFM.
Thats a lot less than I though, and thats only into the manifolds.
Old Jun 16, 2011 | 01:12 PM
  #12144
krewat's Avatar
krewat
Originally Posted by IB Adrian
The engine is an airpump, and it does The exhaust contains the same about of Oxygen as the intake, its just in different form.
Aw geez... the exhaust is hardly "air".
It's a "gas", yes, but certainly not "air".
The pressure and/or volume difference is purely due to the temperature change during combustion.
So when I cool exhaust gas back down to ambient, it turns back into a liquid?
I'm beginning to think you're playing with me
Old Jun 16, 2011 | 01:24 PM
  #12145
krewat's Avatar
krewat
You're leaving out all the energy that was locked into the molecular bonds in the hydrocarbon (oil or gasoline) molecules. When those bonds are broken, the liquid turns into a gas.
Old Jun 16, 2011 | 02:31 PM
  #12146
BigF350's Avatar
BigF350
FTE Emeritus
Nope. But the overall volume of what is there at the start of the process, and what is there at the end of the process if the temperatures won't be hugely different.
It might change state. It doesn't change in mass.
Old Jun 16, 2011 | 05:59 PM
  #12147
Super08's Avatar
Super08
Not in mass, but it will change in volume.
Old Jun 16, 2011 | 06:02 PM
  #12148
exiled's Avatar
exiled
The temputer change on the intake is by disign. Which hurts your equation even more. You forced the air thru the CAC to cool it down to get more o2 molcules into the combustion chamber. When it combusts the mocules spread cause of the heat if there is any o2 left over. Co2 and h2o is not the samething as o2. H2o is water. I don't want to breath water.
Old Jun 16, 2011 | 07:47 PM
  #12149
PorchFarms's Avatar
PorchFarms
i really like your pic now. that is a really sharp truck and i am not a fan of colors. (prefer white till i saw yours)
Old Jun 16, 2011 | 07:54 PM
  #12150
Super08's Avatar
Super08
Thanks. Their are some full sized pics in the 6.2 forum if you wish.
Post 344.
https://www.ford-trucks.com/forums/1...-truck-23.html
and now back to your regular programming.....
