Sponsored by: Real Truck
Gas vs PSD
Old Oct 23, 2009 | 03:33 PM
  #2521
ToaDisco's Avatar
ToaDisco
Originally Posted by phillips91
This was in response to someone recommending the timesert and where I got my post from.
Some one recommended this solution to a guy who asked how to fix the problem.
Hmmm, so going to a head with more threads should fix the problem?? I thought you said that the problem isn't with the older heads only having 4 threads? If the problem is with installation error how then how is having more threads going to help them? If you can't screw it in 4 threads then you're not going to do any better with 8.
Here is another that had an insert blow out. According to his research it won't stay in because it's stainless and the head is aluminum.
So where am I not reading what other members post and how am I spreading false information? I am taking my info straight from our fellow FTE members that YOU say have never had this problem. I can find more of these all day long.
I'm with krewet on this one. I've currently got a insert installed(that I installed in a parking lot with the head still on) and have put close to 50,000 miles on. Maybe I'm lucky, but I'm pretty confident in the repair.
Granted I did install it myself, and followed the directions to the tee, but I don't consider myself a expert mechanic.
All of the posts you referenced said they paid a "shop" to perform the repair. I'm sure they were reputable shops, but you can never tell. Also, what "inserts" did they use? From what I remember the timesert kit wasn't cheap, so maybe they used another insert?
Who knows?
All I know is I'm confident in the insert I put in, and I haven't had any other plugs shoot out in the 60,000 or so miles I've put on the truck since then.
(I'll probably have a plug shoot out tomorrow after I've bragged about the repair)
Old Oct 23, 2009 | 03:49 PM
  #2522
phillips91's Avatar
phillips91
Originally Posted by bucci
I can only speak from experience from one diesel. A friends 2000 7.3l F450 Dump truck. When I used it once in the winter, it took alot longer for the engine to come up to temp and a lot longer for it to throw hot air. Big difference between that one and my gas pickups.
I'm not going to argue too much about that because you probably have experience with more than one diesel and are familar with that issue, but now you know how I came up with that; it did come from an experience I had, I didn't take it from hear say or make it up.
I must also say that this V10 in my '09 is the quickest engine to reach operating temp that I ever owned.
I only notice that problem with our bigger diesels. On a cold morning our interational big rig takes forever to warm up. But it's trying to heat up more fluid than most trucks hold gas lol.
I also only notice the cold start up problems on our older, bigger diesels. The ones without glow plugs. A little bit of ether or some gas on a rag and they fire right up though. Then we have to let it idle for God knows how long before it's ready to go pick the load up.
I won't argue with you on that last part. In that 5 minutes to the main road my 5.4 is already at the RM on "NORMAL" and my others are right around the N. They are all blowing hot air by then, but the 5.4 is the only one thats at full operating temp.
Old Oct 23, 2009 | 04:06 PM
  #2523
phillips91's Avatar
phillips91
Who knows?
Of course you agree with krewat, you v10'ers have to stick together Just curious, but what caused your plug to shoot out? The two guys I quoted mentioned what kind of insert they used. I may not have posted it though. I had to edit out a lot of useless stuff they said that took up half a page. One said he used a heli coil and the other said timesert.
Several other people mentioned having to pay over 4 thousand dollars to have theirs fixed at the dealer. If you take the 6.0 and the v10 to the dealer, both problems can rup upwards of 4k dollars. If both of them are fixed at home, it's going to be in the hundreds. Most of the v10 guys I talk to though give the price to fix the v10 as what it would cost them at home and then quote the 6.0's price at the dealer, so it looks like a $250 problem vs a $4,000 problem.
Old Oct 23, 2009 | 07:13 PM
  #2524
ToaDisco's Avatar
ToaDisco
I believe the plugs were originally over torqued by the previous owner, and those specific threads were damaged. The plug worked itself loose over time(I could hear it ticking, I thought it was an exhaust leak). All this happened within 10,000 miles of me owning it, and was the reason I found FTE.
If I didn't find this site, I doubt I would still own the truck. To say I was pissed off at the truck and Ford in general is a understatement. Nothing like working in a parking lot in 30 degree weather installing one of those inserts
I agree about the repair costs. Ford is awfully proud of their parts, regardless of engine.
Old Oct 23, 2009 | 10:40 PM
  #2525
bill11012's Avatar
bill11012
Modular motor junkie
Originally Posted by 95_Dually
Bill, did your create that thread too?
No, go read my reply on that one.
Old Oct 23, 2009 | 11:19 PM
  #2526
bill11012's Avatar
bill11012
Who knows?
I was talking to a ford mechanic yesterday at O'reillys.
He told me they use an air gun for the heads, plugs every thing on the motor but the bottom end.
I think that ones done by a shop should not be counted.
You have no clue what the shop did.
Old Oct 24, 2009 | 09:57 PM
  #2527
phillips91's Avatar
phillips91
I got my 5.4 with only 12k miles on it, so it hadn't had any work done to it at all. It's only at 35k miles, so it still has a little ways to go before needing plugs, but I have been seeing all sorts of horror stories in the modular section about them. So it does have me a bit concerned. The only problem I have had with it so far is that I am on my third air conditioning condensor. Each one lasted about a year until I just gave up and started riding with the windows down lol.
Old Oct 24, 2009 | 09:59 PM
  #2528
phillips91's Avatar
phillips91
Don't worry Bill, I posted your reply to it
Old Oct 25, 2009 | 09:29 AM
  #2529
bill11012's Avatar
bill11012
I saw that after I put that post up.
Thanks.
Old Oct 26, 2009 | 10:55 AM
  #2530
95_Dually's Avatar
95_Dually
Bill, I was teasing you. I hope you took it that way. LOL
Old Oct 29, 2009 | 11:55 PM
  #2531
bill11012's Avatar
bill11012
I know you were.
this thread has all but died, I still want to see a 6.4 vs 3v V10 test .
Old Oct 30, 2009 | 12:42 AM
  #2532
95_Dually's Avatar
95_Dually
I keep looking for more "information" here on the subject. And more humor as well.
Old Oct 30, 2009 | 06:29 AM
  #2533
Tom's Avatar
Tom
This thread has all but died, I still want to see a 6.4 vs 3v V10 test .
I tried! Nobody with a 3V wanted to come out and play!
Old Oct 30, 2009 | 11:08 AM
  #2534
alchymist's Avatar
alchymist
"Mifflin Clay"
I know you were.
This thread should have died a long time ago, but my V10 is still running with all 10 plugs!
Old Oct 30, 2009 | 01:38 PM
  #2535
transferred's Avatar
transferred
169 posts....who cares? Be happy with what you've got. Both are fine engines and wear the blue oval so quit already
