Cummins Conversion Update
It really means a lot to me that you all have been following along with me and interested. It's been enjoyable to give updates throughout this and see excitement from others too.It's been a long road getting this done. I figured it up and I've got somewhere around 225-250 hours in this conversion since the beginning of July. After getting to drive it, even if for only a little while tonight, the long hours and late nights have been well worth it. No smoking or racing going on yet, since the engine is just breaking in and there's no aftermarket programming on it. As it sits, it's probably only 300 RWHP or so.
Edit: Kris, yes the hours have most definitely been worth it!
I got about 10 miles in...keep reading.
Well, the drive report is going to be a short one. First the good. This thing sounds bad *** when driving. The rumble from idle is pretty dang cool and it just sounds mean going through the gears. I don't know if it's the cam, turbo, exhaust manifold, or the combo of them, but the raspy sound that some say the common rail has simply does not exist on my truck. It almost sounds like the old 12V trucks.
Now the not as good news. It's going to be stationary for a few days. I was about 4 miles from home when I heard something under the hood pop, then it was suddenly really hard to steer and brake. The pressure line going from the pump to the hydra boost blew the hose off the fitting up by the hydra boost. It made quite a mess with power steering fluid (ATF actually) everywhere on the driver's side of the engine compartment. I've already got that cleaned up though with some simple green and the garden hose. I'll take the blown fitting and hose to the shop tomorrow to have them take a look at it. Perhaps it was a bad crimp and they can make a new one quickly, or maybe I'll have to look into other options. I've got a backup plan using a stock hose extended with some stainless hardline if necessary.
Second bit of something I need to get figured out is why it won't rev over 2000 RPM. Even in park or neutral, foot to the floor, it won't go over that. Two possibilities are a bad sensor or a SKIM (security) code in the ECM. I pulled codes with AE and none showed up for any sensors, so I'm thinking it's the SKIM code. The fix for that is basically getting a Smarty (programmer/downloader) to clear the unlock code. I wanted to get a Smarty anyway, but was going to wait a few months.
I'm going to double check the connections for the air sensors in the AM and see if that helps at all. It's almost like it's not reading boost and simply not providing any more fuel.
@Jtharvey, would a dodge dealership have this tool? They may be willing to help you.
It has a positive stop at WOT, and it's hitting that for sure. I need to check with Kai tomorrow to see what his voltage is at WOT and see if it's close to mine. However, when I talked to Kai earlier this evening about the 2K thing, the SKIM code was the first thing that came to mind.
Ian, I'm also going to check with the Dodge dealership tomorrow and see if they can help. Since they're only a few miles from home, if they can unlock it, I could easily drive there. If I have to buy a Smarty though, that's alright, since I planned on getting one anyway.
The SKIM code in the ECM basically needs to be unlocked or overwritten so the ECM acts as if there is no SKIM code in it. I'm not sure the Dodge dealership will be able to help due to legal reasons or if they even have that ability. However, the Smarty (MADS Electronics - Smarty - CaTCHER - Smarty06) has the ability to overwrite or unlock that code. Of course, the Smarty will also be the programmer that will unlock the additional 250 HP in my engine.
Does that make any sense?
