Cummins Conversion Update
Old Oct 12, 2008 | 03:02 PM
  #721
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
How does another gear help put down a better number on the dyno?
lol
Old Oct 12, 2008 | 03:12 PM
  #722
guzzle92's Avatar
guzzle92
Originally Posted by jtharvey
I'm actually working on getting something together. One of our admins, IBAdrian, asked me to make an article out of this thread, to be posted up here on FTE.
Jeremy, try and get them not to require you to relinquish all rights to it so it can be published on other sites (DESTROKED.COM, etc).
Old Oct 12, 2008 | 03:17 PM
  #723
jdecker88's Avatar
jdecker88
Isn't all about the dyno numbers . Sometimes its nice to have things for better drivablity.
lol
Old Oct 12, 2008 | 03:53 PM
  #724
twags6's Avatar
twags6
Could the gear vendor's unit even hold up under all that power? I can picture something that looks like a beer can thats all twisted up.
Old Oct 12, 2008 | 06:25 PM
  #725
RubberDuck's Avatar
RubberDuck
Yes, they are rated for over 1200hp. Even with only close to 400hp, I can shift mine with no clutch and it doesn't even blink. They can hold the hp, but they will not increase hp#'s on a dyno. It just allows you to keep the RPM's in the sweet spot pulling heavy, or keep the rpms low at cruising speed.
Old Oct 12, 2008 | 07:48 PM
  #726
jdecker88's Avatar
jdecker88
Thats what I thought I know I have seen a few high horsepower trucks sporting the gear vender ODs, it would be alright to be going 80 at under 2K anyways sorry for the hijack.
Old Oct 12, 2008 | 08:05 PM
  #727
Orezona's Avatar
Orezona
Originally Posted by guzzle92
I don't think there is enough web servers in the world with enough free space to hold that much data...........
He!! I'd buy it on DVD!
Old Oct 12, 2008 | 08:17 PM
  #728
jtharvey's Avatar
jtharvey
Hey give me your address, i have two front covers now, one that has a coolant temp sensor i won't use. If you want it, let me know, it's yours.
Thanks Kris. I'll be sending you a PM here in a bit. I tried a different sensor today, but still not working. I'd like to have a good, known working sensor to help me diagnose this thing.
I'll be starting a new thread here in a bit too, because I don't think this problem has anything to do with the conversion.
I had forgot you didn't put the Dual CP3s on there they run about 2400-2700K don't they? ... Have you thought of adding a gear venders OD for a 5th gear?
I'll be going with a kit called the Evil Twins. It's a complete kit, minus the pump. The Evil Twins kit runs about $1600. Then the other cost is an additional CP3 pump which I would supply. I've been keeping my eyes out for a CP3 pump, but haven't found one yet. I'm trying to find one for $300-$400, but am only looking at new pumps, not used.
I haven't given any thought at all to a OD unit. At this time though, I don't think it's something I'll be doing. Perhaps sometime in the future though. This engine can definitely pull hard down low.
Old Oct 12, 2008 | 08:21 PM
  #729
SolidGround's Avatar
SolidGround
You'll have to update your You Tube 'rolling coal' video to a new 'really rolling coal' video.
BTW, I've got a modified Duramix CP3 (don't ask), it won't be around $300-$400, but it is 'new.'
Old Oct 12, 2008 | 11:40 PM
  #730
PowerstrokeJunkie
Diesel Power has/had a 2wd Dodge CCSB truck that has a Gear Vendors OD in it, and they drag race it. I'm sure it's well over the out put of jeremy's truck.
Old Oct 12, 2008 | 11:41 PM
  #731
PowerstrokeJunkie
Do you also happen to have a front cover for a 7.3 that accepts it?
Old Oct 17, 2008 | 10:02 AM
  #732
Toyman's Avatar
Toyman
Alright Jeremy, I was hoping you would post after the week driving and not having issues. How is the truck performing, have you cranked up the smarty?
Also I have a gas engine truck how much more crap would I have to go through to do a conversion on it?
Congrats again, we are all as glad as you are that you got it running the way you want.
Toyman
Old Oct 17, 2008 | 11:32 AM
  #733
jtharvey's Avatar
jtharvey
Well, I really don't have much to say yet, other than I've come to the conclusion that this truck should have definitely come with this engine from the factory! It flat out rocks. Power is very smooth, sound is awesome, and it's just more fun to drive than the 7.3 was.
I haven't cranked up the Smarty yet, because I'm not taking the chance on washing out the cylinders with fuel, diluting the oil with fuel and risk potential damage to rod or main bearings. The Smarty does have some extra fuel put to it over stock, but the turbo is still able to clean it up. I've got about 700 miles on the motor so far, and I'm not yet ready to put more fuel to it. So Kris can say what he wants, call me names, etc...and that's fine. I've put too much time and money into this project thus far to risk permanent damage to the engine just to have a little extra fun. I am patient enough to wait for that.
My coolant gauge is still not working properly, but I haven't had time to get the pinpoint test out yet and see where the problem may lie. Not a big deal though because it's not affecting the way it runs and my Autometer gauge tells me the actual temp. I'll get it figured out though.
Also, there's something with the VSS wire I used, taking a little bit to get signal to the ECM on first start, limiting RPM to 2K for a few seconds. It only happens when I start the truck though, and after that it's fine. I'm not sure why that happens, but Bean told me to use a speedometer output wire on the PCS and that it works perfectly, so I'll change that over this weekend.
I got the AC lines made yesterday as well, but haven't charged the system yet, since a buddy is doing that for free. I've got to wait on his schedule to get the system charged.
On the electronic tach box, Scott (Destroked) received the test unit from PCS, found some issues with it, and has sent it back to PCS for revision. So, my tach is not functioning now, but that was by choice to wait for the PCS box rather than put a tone wheel on it.
Otherwise, all seems well.
Toyman, I don't think you'd have to go through too much more. Main things I'm thinking of is a couple items you'd have to add such as a hydraboost system and an intercooler. Also, I'm not sure if the radiator is of a different size and if the diesel one might be larger, which you'd want to get. Aside from that, none of the diesel stuff is used in a conversion.
Old Oct 17, 2008 | 12:55 PM
  #734
Toyman's Avatar
Toyman
I have been searching for a donor truck cheap but haven't stumbled accross the right deal as of yet. Actually looking for something in the late 90's.
Toyman
Old Oct 17, 2008 | 02:39 PM
  #735
stangclassic66's Avatar
stangclassic66
Nice work! Any idea on the fuel consumption?
