Cummins Conversion Update
Old Oct 10, 2008 | 06:20 PM
  #676
Tenn01PSD350's Avatar
Tenn01PSD350
Git er done. Good luck with it Jeremy. I'm working this weekend.
Old Oct 10, 2008 | 06:34 PM
  #677
ron's power stroke's Avatar
ron's power stroke
your going to work and had a half a day off today and the rest of the weekend off..im sleeping in...
good luck Jeremy..you been waiting a long time for this..you have earned it for sure....
Old Oct 10, 2008 | 06:39 PM
  #678
That_Guy's Avatar
That_Guy
I really want to see that thing in action, congrats Im jelous lol
Old Oct 10, 2008 | 06:44 PM
  #679
Tenn01PSD350
Touche Ron. Look to see you about 0530 after you have "slept in" then sir?
I'll be taking some time off myself here in 3 days. Got a lot to do. Don't plan on getting much of it done either but the time off is nice.
Sorry Jeremy, back to the thread.
Old Oct 10, 2008 | 07:59 PM
  #680
xgatorx1976's Avatar
xgatorx1976
2 hours since Jeremy's last post, and still no post if its running above 2k. The pressure is on. The suspense is killing some of us.
Old Oct 10, 2008 | 08:05 PM
  #681
Tecman's Avatar
Tecman
Well if its been 2 hours since his last post im sure its working then!
He is probably out killin fords, dodges, and chevys! LOL
Old Oct 10, 2008 | 09:04 PM
  #682
zack7.3's Avatar
zack7.3
Yeah, hopefully he is making that new video. I have been looking forward to this for a long while.
Old Oct 10, 2008 | 09:08 PM
  #683
That_Guy's Avatar
That_Guy
So have I...
Old Oct 10, 2008 | 09:09 PM
  #684
Tecman's Avatar
Tecman
Me too and to think its not even ours! LOL
Old Oct 10, 2008 | 09:11 PM
  #685
zack7.3's Avatar
zack7.3
Yeah, I was thinking the same thing. Funny, isn't it.
Old Oct 11, 2008 | 12:07 AM
  #686
jtharvey's Avatar
jtharvey
Sorry guys, no dice. Had some trouble getting the Smarty to connect to my computer, but finally got it connected. Loaded the recovery file, updated the ECM, went for a test drive, still have the 2K rev limit. Frustration ensued.
I took a break from it after that because I was just getting more frustrated and needed to leave it alone, went to help Jeff clean up the lot where he's building his new house and was burning all the scrap wood, and made a few phone calls. Got some promising info.
Kai was stumped, but made a call to Scott at Destroked. After thinking through things for a bit, Scott wondered if I had Vehicle Speed Sensor hooked up to the ECM. I do not. Apparently some years of the Cummins need a VSS signal to the ECM in order for them to be able to rev. No VSS, and revs are limited. The '03 engines don't need one, and it was sometime in '04 that the change was made. Kai remembered people telling him he needed to hook up a VSS, but he didn't have to because he's got an '03 engine. It's been 2 years since he did his conversion, so I can't fault him for forgetting about that, especially since he didn't have to do it.
So I've got my wiring diagrams back out and plan to hook up the VSS to the ECM in the morning and hope for the best. I'm ready for this thing to work right.
Old Oct 11, 2008 | 12:42 AM
  #687
RubberDuck's Avatar
RubberDuck
FOR THE LOVE OF ALL THAT IS SMOKEY AND FAST!!!!!!!! The suspense is killing me! LOL Be patient brother, it will all come together and you can take out your anger on the tires. Maybe we should all pitch in for a set of burnout tires!!
Old Oct 11, 2008 | 01:38 AM
  #688
HighOctane's Avatar
HighOctane
PMS: an obsession
Positive love sent your way brother! I can't wait for the post where you spread the good word! Best of luck getting her rolling right real quick.
Old Oct 11, 2008 | 08:33 AM
  #689
Lead Head's Avatar
Lead Head
I seem to remember something that Dodges have this thing programmed into the ECM that if it detects that the revs are going up but the truck is not moving, it will limit power to protect the transmission from over heating. Like you were trying to do a burnout or something.
Old Oct 11, 2008 | 02:35 PM
  #690
jtharvey's Avatar
jtharvey
She's going now!! Took trying a couple different VSS wires, but it's all good now.
Tried the one on the output shaft of the trans first, and it revved just fine, but limited the speed to 20 MPH. I'm guessing the signal out of that was telling the ECM it was going way too fast and hit the speed limiter.
Next I need to try hooking up the wire up to the VSS signal out of the PCM. That required removal of the inner fender to get to it. Did that, hooked up the wire, tied up things temporarily, and went for a test drive. Houston, we have lift off!!
Came back, soldered the connection and buttoned everything back up. Just waiting for the Smarty to update now with some new programming. I'm not going to run the full power setting on it, because I don't want to wash down the cylinder walls with too much fuel while the rings are seating, but I'm going to add a little power and some timing for throttle response.
I'm definitely pleased about this.
