Cummins Conversion Update
Old Sep 1, 2008 | 10:45 PM
  #346
jtharvey's Avatar
jtharvey
I'm gonna stockpile what I can right now, since prices will be going up. Good point, Steve.
I think it would be a riot to see what the UOA's reaction would be to the first drain. All the metal, silicon from the seals, who knows what in the cam lube, etc... It would make for an interesting reaction, for sure. I'll see how I feel about spending $25 bucks on it when the time comes.
The welder stopped by this morning, and if the pipes Kai is making for me don't work, he's pretty sure he can make something that will work, probably using a lot of the stock Ford IC pipes. Hopefully Kai's will arrive soon, so I can see if I'm going to have to modify them or what not.
Got the OBD II port wired up today. Pretty simple really. Hooked up the 3 wires from the Cummins that I ran through the firewall, then tapped the wires on pin's 4, 5, & 16 of the Ford OBD II port, which are grounds and power. Put the Cummins OBDII port right where the Ford one was located under the dash, and relocated the Ford one to just behind the dash panel under the steering wheel. I wanted to keep the Cummins one convenient, since I plan on getting a Smarty programmer and it uses the OBD II port for the programming. I'm going to have to call either AE or ITP to find out about upgrading my AE to the enhanced Dodge bundle though, so I can read the Cummins stuff. The Ford OBD II port is only to read chassis codes now.
After that, I hooked up the wires to the PCS for my OD button and OD OFF light. The most difficult part of that was actually getting to the Ford wires. I only had about 3" of wire to mess with, right up agains the top part of the dash. It was a tight fit to get even my smallish hands in there, but was able to do it with a little contorting of my body. BTW, the wires that PCS's tech guys told me to use on the Ford harness where spot on...of course, I had to verify the wires myself with the DVM. Having to add a wire to the PCS harness had me a little worried, but the directions that came with the controller were very precise and it wasn't nearly as bad as I had thought.
I also started to run the radiator hoses, but stopped when I looked at the lower one. I'm not sure of the location & routing of the hose for the bottom of the coolant reservoir and I didn't want to route the main lower hose only to have to move it later. So, until I get the coolant reservoir, I don't want to do anything there.
Well, I'm now pretty much at a standstill point until I get the rest of my parts in. I'm going to check with Kai in the morning and see if he has any updates on progress for me. Until then, I guess I could always hand wash and wax the truck to put a shine back on it.
Old Sep 2, 2008 | 10:24 PM
  #347
jtharvey's Avatar
jtharvey
Talked to Kai today about the IC piping, and sent him a bunch of pics and vids of the cold side stuff, so he can hopefully make me some out of stainless. Not sure about the coolant tank, and he said Scott at Destroked should have all the throttle cable parts together. They know time is getting tight, so they're working to make sure I can take the truck to Indy.
I could use a few opinions though. I got my Cummins badges in today, and am having trouble deciding on where to place them. Three places come to mind: on the door where the Powerstroke badge is now, on the fender under the F-350 badge, or on the front fender where the early 99 PSD's have their V8 badge and where the 03-05 Dodges have their Cummins badge. I have had it in my mind this whole time that the door would be the place for it, but after holding it up in several places this evening, I don't know. The front of the fender looks kind of out of place, and under the F-350 seems to make things too busy right there. Jeff thinks under the F-350 would be the place for it, but I'm still leaning toward the door. I wanted to see what you guys thought.
By the way, here is the badge I have, from the 06-08 Dodges:
Edit: Here are a couple pics of Kai's truck, with them on the doors, where I'm thinking would look the best.
Old Sep 2, 2008 | 10:34 PM
  #348
jdecker88's Avatar
jdecker88
For that badge I am kinda partial to putting it on the front fo the fender where the early 99s have them. The door location that is pictured on Kai's truck looks pretty darn good though.
Old Sep 2, 2008 | 10:37 PM
  #349
nhill2090's Avatar
nhill2090
Jeremy, I like them on the door like Kai's. However, I think it would look sharp if you upgraded to the 05-07 f350 badges that are all chrome and stuck the cummins one right under it. That way it looks like they match and are supposed to be like that. They are fairly cheap from the dealer and I'm sure a sponsor on here could hook you up even more. Just an idea.
Old Sep 2, 2008 | 10:42 PM
  #350
jdecker88's Avatar
jdecker88
Maybe you could get a nice custom badge from billetbadges.com?
Old Sep 2, 2008 | 10:54 PM
  #351
willeo6709's Avatar
willeo6709
I have always been a fan of the stealth look.... I'd put one on the dash on the inside....leave the outside plain. I would vote the door since you did ask for options for the outside. Ultimately up to you...
Old Sep 2, 2008 | 11:02 PM
  #352
jtharvey's Avatar
jtharvey
I was actually thinking of getting some '08 badges for the fender...Edit: nevermind about the '08 badges. I forgot they say Powerstroke on them.
Thought about that too. They're definately nice, but spendy. Not sure I want to spend that much on badges. Edit: may have to look a little further into this one. Maybe get the '08 style and put "Destroked" where the stock one says Powerstroke.
It crossed my mind, but part of me says I've put a lot of long sweaty hours into this conversion, and I want people to know what's in it.
Old Sep 2, 2008 | 11:22 PM
  #353
SpringerPop's Avatar
SpringerPop
Anybody that cares can take one listen and KNOW what you did.
Not much else sounds like that engine.
"Badges? We don' need no STEENKIN' badges!" :-))
Pop
Old Sep 3, 2008 | 12:08 AM
  #354
parkland's Avatar
parkland
Pop
How would they see the badges anyways, behind the black smoke clouds?
Old Sep 3, 2008 | 08:55 AM
  #355
Smokin''s Avatar
Smokin'
Smokin
The door, definitely..right where it is on the truck in the picture. I don't like the idea of putting it under the F350..too crowded.
Old Sep 3, 2008 | 09:02 AM
  #356
mueckster's Avatar
mueckster
I vote for the door, also.
Old Sep 3, 2008 | 09:27 AM
  #357
Kwikkordead's Avatar
Kwikkordead
Putting it on the front corner is too "Dodgy" and would look copycat to me.
I vote for the door as well.
Old Sep 3, 2008 | 09:34 AM
  #358
zack7.3's Avatar
zack7.3
I would go for the door. It is a real attention getter. I would notice that a mile away.
Old Sep 3, 2008 | 10:06 AM
  #359
farmdad's Avatar
farmdad
Door too. Ford put the emblem there, doesn't matter which engine. Final choice is up to you, Jeremy.
Old Sep 3, 2008 | 10:10 AM
  #360
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
i would put it on the door, right behind the 350 badge.
