Cummins Conversion Update
Old Sep 22, 2008 | 09:35 PM
  #406
jtharvey's Avatar
jtharvey
Originally Posted by parkland
I see an issue with one battery being cold all the time, and the other hot- maybe i'm overreacting though...
Theoretically the one under the hood will degrade quicker, and then suck power out of the remaining good battery.
or else i'm just being a worry bug
I think you're just a worry bug. The battery under the hood won't degrade any quicker than it would with a 7.3 in there. Also, after logging a lot of data about underhood temps in that basic area (IAT sensor, about 6" away from the battery), I don't find them to be that much higher than ambient. About 10-15 degrees higher when under motion. Also, those data logs were taken with the 7.3, where there was an exhaust manifold on both sides. With the Cummins having the exhaust completely on the passenger side, there won't be nearly the amount of radiant heat on the battery than what used to be there.
Originally Posted by Smokin'
You should be. Sharp dressed, AND he has a cummins! Thats a score 9!
What would be necessary for me to have a 10?
Originally Posted by strokin_it7.3
Cummin will get ya in trouble
Not necessarily. Is it you or her?
Old Sep 22, 2008 | 09:38 PM
  #407
Smokin''s Avatar
Smokin'
Smokin
Cummin will get ya in trouble, but the ladies love it when a guy has a nice stroke...
(copyright 2008 i just made that up)
Hey, did you guys hear that?
I think...I think that was the sound of thousands of women rolling their eyes simultaneously.
  #408
Tenn01PSD350's Avatar
Tenn01PSD350
Oh boy, I see this one headed in a very productive direction.
Old Sep 22, 2008 | 09:42 PM
  #409
Smokin''s Avatar
Smokin'
Smokin
Sorry Mike. Kris started it.
Originally Posted by jtharvey
Plus, I wanted to keep one battery up in the engine bay for easy access, just in case I ever needed to provide a jump start, need one myself, or needed to temporarily access battery power for something else, like an inverter, air pump, etc...
Jeremy, just a thought...the only time I have ever jump started a diesel successfully, we had to jump both batteries at the same time. May have been just my particular situation. I'm not sure if it would be wise to plan to have access to both batteries if necessary.
Oh and the 10 question, you already know the answer to that.
Old Sep 22, 2008 | 10:08 PM
  #410
jtharvey's Avatar
jtharvey
I hadn't thought about that, but at this point, I think I'm just gonna go with it as I have it planned. If I get into a situation where both need to be jumped, I can get to the second battery, it just won't be easy. However, I know of at least one guy with a CR conversion who only ran on one battery for several months. I'm hoping that if I ever needed a jump, the one battery would be enough. If it's not, the batteries are probably shot and will have to be pulled for replacement anyway.
Old Sep 22, 2008 | 10:16 PM
  #411
UP_There's Avatar
UP_There
I've never had to jump this truck, but on my 97 7.3L I jumped it with only using one battery. I think it will work fine, just might have to let it sit on there for a few minutes and let it trickle across to the other one thru the cable a bit....
Old Sep 22, 2008 | 10:39 PM
  #412
Smokin''s Avatar
Smokin'
Smokin
I do think that a Cummins' heating cycle (coil) is a tad bit more efficient than a 7.3's glow plug and relay. Perhaps it won't ever be an issue.
I know my dad's 5.9 would start in cold weather without even a cough, even with crap batteries...no comparison to the cold-sensitive 7.3.
Old Sep 22, 2008 | 10:45 PM
  #413
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Do you know how fast electricity actually moves? When you add voltage to one, they both see it instantly because they are wired in parallel, with larger gauge wire than the actual jumper cables. It's just the amperage load they can handle that takes some "time" to build up.
Old Sep 22, 2008 | 10:59 PM
  #414
jtharvey's Avatar
jtharvey
The Cummins grid heater (that's all they have, no GP's) may be more efficient than the GP's in the 7.3, but I won't ever find out as I have removed my grid heaters. I do still have the grid heater though should I find the truck too difficult to start in the winter and need to put it back on the truck.
I'll find out soon enough, with winter approaching. I'll leave it plugged in most of the time, but I imagine I will to a test on a cold day and not plug it in just to see if it will start on its own. I won't make a habit of doing that, but it will be good to know so that if I'm ever somewhere where I don't have access to a plug in, I'll know whether it will start or not.
Old Sep 22, 2008 | 11:16 PM
  #415
farmdad's Avatar
farmdad
There's always ether.
Old Sep 22, 2008 | 11:30 PM
  #416
jtharvey's Avatar
jtharvey
I think that would actually work just fine for me. The biggest problem with it on most diesels is the heat from the intake heater or glow plugs igniting the stuff when it's not supposed to. Without any kind of heating device in my intake or cylinders, I should be ok if it came to that.
Old Sep 23, 2008 | 12:51 AM
  #417
4inchlovin's Avatar
4inchlovin
Ya but my 7.3 is at running temp by the time i get to the freeway, my buddies 5.9 isn't warm till he gets half way to work...
Old Sep 23, 2008 | 11:13 AM
  #418
farmdad's Avatar
farmdad
I always fear finding out how to replace head bolts.
Old Sep 23, 2008 | 12:01 PM
  #419
8tsixt's Avatar
8tsixt
I'm jumping in here late but want to say your project looks great! I always have wondered about doing this to mine when the engine has a stroke.
Old Sep 23, 2008 | 03:43 PM
  #420
parkland's Avatar
parkland
I'm paying attention, if theres anything I know about projects like this is that getting everything bolted in is the easy part - getting everything fine-tuned and running proper is the time eater.
