Cummins Conversion Update
Old Aug 20, 2008 | 09:24 PM
  #226
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Awesome. Im not planning on doing this anymore as there are other things someone in my position should be spending their money on, but one day soon when i have the funds set aside for something like this, im going to make a commonrail race truck YOU better remember all this stuff, cause i wanna do it just like you are!
Old Aug 20, 2008 | 09:39 PM
  #227
Tenn01PSD350's Avatar
Tenn01PSD350
We've heard this sort of talk from you before Kris
Old Aug 20, 2008 | 10:08 PM
  #228
bdrummonds's Avatar
bdrummonds
Jeremy, Make sure you contact Pete and get a filter cover for the AFE 6637.
I am sure he still has the pattern from when he made my cover. His cover for the AFE version does have the indention for the inverted cone on the end of the filter. I know he could add a DeStroked graphic for you too.
Old Aug 20, 2008 | 10:13 PM
  #229
jtharvey's Avatar
jtharvey
Thanks Brandon. I'll give him a shout and see what he's got to say. I know the AFE cover really helped a lot to keep my AFE II clean.
Old Aug 20, 2008 | 10:18 PM
  #230
bigsteve1969's Avatar
bigsteve1969
jeremy it sounds to me that your not far away at all!!! i guess its gettin bout time to take that 5 gal. yellow jug to the fuel stop and get some start up juice! i think i can already smell the fumes down here in MS. btw great job i'll get reps your way soon as i pass um around
Old Aug 20, 2008 | 10:57 PM
  #231
jtharvey's Avatar
jtharvey
LOL...funny you say that, because I actually did just today, went and filled up the yellow jug! Man, it was good to smell some diesel fuel again.
Old Aug 20, 2008 | 11:24 PM
  #232
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Looks killer Jeremy. I relay admire the work you do and how you take your time and get it done right it looks like the factory installed it
Old Aug 21, 2008 | 02:18 AM
  #233
jtharvey's Avatar
jtharvey
Thanks Nick. It's a lot of extra work that's not absoutley necessary for just a conversion, but I think it will be well worth it once I'm done. I hope to have something that I'm proud of and glad to say I did myself.
Driveshaft is in now. It's been raining lightly, so I could work under the truck and not get too wet, but the rain never let up so I couldn't get anything else done. I really wanted to get the power steering hooked up tonight, but it wasn't in the cards. I've been really lucky having good weather to work on this project, so I guess a couple days of poor weather are ok.
Old Aug 21, 2008 | 02:27 AM
  #234
ron's power stroke's Avatar
ron's power stroke
doing one hell of a job Jeremy nice and clean and looking sharp but damn..get some sleep.....
Old Aug 21, 2008 | 02:58 AM
  #235
jtharvey's Avatar
jtharvey
I'm gonna spend a few weeks catching up on rest once this thing is done. I'm actually off to bed now after grabbing a bite to eat.
Old Aug 21, 2008 | 03:23 AM
  #236
ron's power stroke
sure hope you do..going to make your self sick..it is hard to sleep when you got some thing like this to do..its all you think about and makes for sleeping hard to do..i would be mind boggled for a few weeks as well...get some sleep is easy to say..but to do it is a differnt story.... cant wait to hear this thing prrrrrr..
Old Aug 21, 2008 | 08:04 AM
  #237
farmdad's Avatar
farmdad
Jeremy, I see in your sig that your truck is a 4X4. When you moved the transmission back and shortened the rear driveshaft, did you have to lengthen the front driveshaft or was there enough splined shaft to compensate? Just curious.
I hope you realize that the rest of us are getting excited right along with you about the initial test run of 5.9. Thanks for keeping us up to date on the progress.
Old Aug 21, 2008 | 08:33 AM
  #238
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Mark, he shortened the front drive shaft around 1/2".
Sounds like you need to build a shop next Jeremy. Tuff working outdoors doing this. Keep up the good work, can't wait to watch the vid of the first start up.
Old Aug 21, 2008 | 10:51 AM
  #239
strokersace's Avatar
strokersace
From what I understood, he shortened the front section of the rear driveshaft assembly, between the transfer case and the carrier bearring. I think Mark was asking about the 4x4 driveshaft from the transfer case to the front axle. That's a great question, as I didn't think of that till you asked!
Old Aug 21, 2008 | 12:17 PM
  #240
jtharvey's Avatar
jtharvey
Mark, There is plenty of spline left. I actually had the transmission sitting back about 1" further while I was setting the engine in place and the front shaft never came out of it's splines. There are however less splines in the slip joint now, so I don't think I would want to do a lot of heavy wheeling until I had a chance to put the lenght back in the shaft. It may not be an issue at all though. There's lots of guys with conversions who have never done a thing with their front driveshafts and they aren't breaking them. Even through drag racing and sled pulling.
Rick, I'd love to have a shop. There's even the perfect spot beside my house to build a 30'x40' shop. Until I'm done paying for the truck though, I won't be able to swing anything extra. I have no idea what it would cost me to build a shop though, but I'm thinking $12-$15K? I don't want anything fancy, just a concrete slab, 4 walls, a roof and electricity. I can do a metal sided building, so I wouldn't have to shingle and side it to match the house. Insulation would be nice, but that can come later. Pole barn, steel building, 14' ceilings so I can put a lift in later. One of these days.
Ryan is correct. The rear driveshaft was shortened overall by taking a small amount of the front portion of the rear driveshaft.
