Superchips 6.0 Microtuner Thread
Old Dec 15, 2004 | 12:05 PM
  #1291
Fieldday's Avatar
Fieldday
Two Questions
I had a SC in my 04 F3 and loved the performance. If there was anything that could have been better it was the cruse control. When ingaged and the brake was depressed the engine just cut out like you turned it off. It wasn't a smooth disengage like the stock file. It's a jolt to the drive train when loaded and comming off a freeway.
Question two. My 04 was wrecked (rearended) and is gone (6 months old).
I was able to get the stock file back in. An 05 should be here around X-mas. What do I need to do to get the SC to work with the 05?
Thanks in advance.
Old Dec 15, 2004 | 12:28 PM
  #1292
Vic_Ferrari's Avatar
Vic_Ferrari
Thanks in advance.
There was a TSB (Ford) on the cruise control issues.
As for the 05.....hang in there. Work is in process.
Dunno what the policy will be for your existing tuner, but you may be able to pay to have it updated for 05, rather than have to buy a new tuner for an05...not my dept =o)
Call customer service if you have questions.
There is a cost involved in updating hardware/software/firmware to make a tuner work on a vehcile other than what it was originally released for. The 05 has different files sizes than 03-04.
Old Dec 15, 2004 | 09:09 PM
  #1293
Fieldday's Avatar
Fieldday
Thanks Vic. I'll just sell this tuner and order another when the 05 is issued.
At least I was able to get it back to stock files...
Old Dec 16, 2004 | 01:34 AM
  #1294
mlb4966's Avatar
mlb4966
I guess I will have to see how it does with the ice and snow once it gets here. The only time I really step on the pedal is to pass. I usually drive around in 4x2 most of the time. Right before I pass I just throw the floor lever into 4-high. That way I wont start to slip and spin. Will see what happens after the install.
Old Dec 16, 2004 | 06:38 AM
  #1295
t_j82's Avatar
t_j82
On my '02 I ran around in the 100 hp mode and found that as long as you were aware of the power it wasn't a problem, it's all about your foot. During the longest part of the ice/snow season I would set it back to tow safe since A. I didn't REALLY need the power and B. It took less "finesse" of the throttle.
Since it is so easy to change I didn't see a problem with jumping between power settings. I did notice that in perf mode if I stood on it while rolling down the highway the back end would want to do the watusi which can be quite interesting.
Old Dec 16, 2004 | 09:08 AM
  #1296
Tekrep's Avatar
Tekrep
I’m not sure about this, but you may want to check your Ford manual- mine says not to switch into 4WD over 50 MPH. And if you are doing it on dry pavement, it is even more damaging. If you don’t have auto hubs, you’re not going into 4WD anyway- the front diff and axles are just spinning. I’ve never had a problem with traction unless I induced it myself- I’ve driven miles on snow-covered road in 4X2 with no problems- that’s with the Banks Six-Gun in 150 HP mode. Granted, I did not pull out and pass anyone. I now run the SCMT in 150 HP mode, and the first half of throttle travel is much more civilized than the Banks was. Of course, if you are taking about driving at low speeds on snowy roads, you can disregard this. All just my opinion.
Old Dec 16, 2004 | 02:27 PM
  #1297
mlb4966's Avatar
mlb4966
Check and the only thing I saw (Page 146) was not to switch from 4WD to 2WD at speeds over 55. I usually keep it in 2WD and here and there throw it into 4WD. Last month I had about 150 miles of ice so I kept it in 4WD while going down the highway. When the roads are in that condition I drive conserative (at or below the speed limit). Most of the time I am passing someone is because they are driving 40-50 mph so I'm not throwing it in 4WD at high speeds. I try to be nice to my 4WD system. Unfortunally due to the nature of were I live it does get abused more than most trucks down in the lower 48.
Back to the 1704. I was kinda on the same thought process of leaving it in tow mode. My winters are from 1 Oct till 1 May with an ocassionaly snow in May-Oct. Summer time the roads are dry so that is when I get to play. I just will have to give both a trail and see what is what.
After I install gauges I will experiment with the Performance mode.
Another question: When setting it back to stock do you need to go through a series of cold starts so the tranny relearns the original shifting?
Old Dec 16, 2004 | 06:13 PM
  #1298
Tekrep's Avatar
Tekrep
I set mine back to stock to take it to the dealer last week and it shifted fine, whether low acceleration or high.
Old Dec 18, 2004 | 10:09 AM
  #1299
Planecrazy's Avatar
Planecrazy
2005 Performance?
Hey Vic,
Based on your work with the new 2005's, any predictions on how they'll perform with the SCMT when compared against the strong 2004's and the stronger 2003's? I know the new units aren't ready yet, but since I'm about to buy an '05 I was curious as to whether you had a sense what the difference will be?
Thanks,
Steve
Old Dec 19, 2004 | 11:25 PM
  #1300
Vic_Ferrari
Originally Posted by Planecrazy
Hey Vic,
Thanks,
Steve
Overall performance will probably similar to 04, but we'll see =o)
Old Dec 20, 2004 | 03:04 AM
  #1301
Ford2504x4SD's Avatar
Ford2504x4SD
Why and when would you ever need this system?
I know this is really cool. However, what advantage does this give you over the original settings? Why would someone want to change the settings in the first place?
Old Dec 20, 2004 | 07:09 AM
  #1302
Vic_Ferrari
What advantage does what give over whose original settings?
=o)
Old Dec 20, 2004 | 08:39 AM
  #1303
Daryl Hunter's Avatar
Daryl Hunter
Do you mean the SCMT?
If so, then you might want to change the factory settings to gain more torque and HP, and see some improvement in fuel mileage while towing - and maybe even unloaded.
If you are satisfied with the truck in stock trim then there's no need to change it, but if you are one of those folks who like to turn it up to 11 now and then, then the SCMT might be just the ticket.
Old Dec 20, 2004 | 09:40 AM
  #1304
Vic_Ferrari
What he said....but once you driven a tuned 6.0, you'll never go back to stock.
I had a friend who parked his truck for a week because he didn't want to drive it stock anymore. When I had a tune for him, he was driving it again everyday....
Old Dec 22, 2004 | 12:48 PM
  #1305
Customz's Avatar
Customz
Vic-
What is the greatest mileage (from your experience) you have seen a tuned 6.0 operate? What setting were the trucks on? What issues/problems have come up i.e. tranny, motor, rearend, cooling, tires, tickets, etc.?
