Superchips 6.0 Microtuner Thread
Old Jun 11, 2004 | 12:46 PM
  #646
jdadamsjr's Avatar
jdadamsjr
Originally Posted by supernewguy
I also have difficulty understanding how my factory settings on another truck will drive like mine when it has been stated over and over that every truck is different.
I also thought you said that every truck is different - how can u know how to special tune it on another truck ????
just see how it does on another truck and soften the shift a bit and trust that it is right for his ???
I'm cornfused... which doesn't take much
Old Jun 11, 2004 | 09:18 PM
  #647
Vic_Ferrari's Avatar
Vic_Ferrari
I will flash another truck with the same stock and modified files his truck has.
I will then attempt to duplicate the issue with his specific codes.
If I can duplicate it, I can make the necessary changes.
Even if I can't duplicate it, I still know how to solve the issue.
Old Jun 11, 2004 | 09:25 PM
  #648
Vic_Ferrari
Originally Posted by RJB1
Vic
Although my truck says DAXO on the computer it has been reflashed to "3U7A FTC" in Jan. How does this one do with the 1704??
Bob
TEC2 and later flashes are fine =o)
Well....it's Friday night and I'm out the door =o)
Old Jun 12, 2004 | 04:33 AM
  #649
Deuce33's Avatar
Deuce33
Vic how do we know what flash we have tech 1 or tech 2 ? I have the 1704 and it works with my truck , but still would like to get the tech 2 by the way you put it just in case i ever go back to the stock file .
Thanks for all your time and great information you have given to this thread , really like the support you give the 1704
Old Jun 12, 2004 | 11:14 AM
  #650
eharman's Avatar
eharman
Originally Posted by Vic_Ferrari
The magic date for flashes is 9/29/03.
If you have a flash earlier than this, you need to update your flash before using the tuner.
Also, this is a bit weird and out of sequence on Fords part:
DAX1 processors will need to be updated to DAX0.
DAX1 still uses pilot injection and these stock files are a serious problem.
If you have a PCM labeled DAX1 (PCM is wedged between battery and driver side fender), please check your records and make sure you have been updated to a DAX0 or another code other than DAX1.
So my Oct flash will work with the 1704 Tuner?
Old Jun 12, 2004 | 11:52 AM
  #651
Choctaw Bob's Avatar
Choctaw Bob
Vic just announced that the DAXO flash is no longer supported so the post you quoted is no longer valid.
Old Jun 13, 2004 | 04:59 AM
  #652
Deuce33's Avatar
Deuce33
Does any one have the part number on this tech 2 or just go to the service manager and ask about the tech 2 flash, I am not sure which on i have casue they did not put any sticker to my knowledge in my truck .
So if we are having problems with firm shifts and hanging around the 30 to 35 mph that is normal with the SCMT ? How long does it take to send back and get the tuner updated. cause it would be terrible to with out my tuner for a long time.
Thanks once again Vic.
Old Jun 13, 2004 | 06:16 AM
  #653
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
All of what you have asked is in this thread, if you do not want to wait to call them on Monday...
Old Jun 13, 2004 | 09:30 AM
  #654
fmtrvt's Avatar
fmtrvt
Originally Posted by Choctaw Bob
I think I will stick with my tune. There is no way to get TEC2 from a dealer. They only flash with the current flask. I am satisfied with 387 HP/ 728 Ft lb.
What is so specfic about TEC2? The revision date?
Old Jun 13, 2004 | 09:49 AM
  #655
Choctaw Bob
It is an identification number. Ford is continually updating flashes. Whatever the current one is, is what you will get if you have your truck reflashed.
Mine has a 5/03 flash DAXO which from what I have seen, makes more power than later flashes. The Predator I have removed all the problems with the flash, hard smoky start, ect.
Old Jun 13, 2004 | 10:05 AM
  #656
Daryl Hunter's Avatar
Daryl Hunter
Just filled up today for the first time on the Economy Tune and got 13.7 mpg in all city driving.
The previous two tanks were on the Hi Perf tune with moderate lead foot action trying out the new gadget so after getting that out of my system it was time to try out the Econo tune and see how it performs.
Definitely more get up and go than the stock tune but not the holy cow performance of the Hi Perf. Shifts were firm on this tune just like the HP tune, and as some other users have noted, they can seem a bit abrupt under light throttle sometimes. The shift in the high 30s mph range under light throttle doesn't happen as early as it seems that it should when rolling along on flat ground and not accelerating. I think that this might be hurting fuel mileage a tad.
But overall, my impression of the Econo tune is that driveability is good with the truck unloaded. I think that it would seem better actually pulling a load. EGTs are low with a max recorded value being around 950 at full throttle acceleration up the 10%+ grade near my house. Max boost was about 27 psi.
The mileage is a bit better than what I had been seeing stock for a tank of city only driving forth and back to work. I only live 4 miles from work and have to climb up and down a couple of hills each way, one of them being the 10%+ hill mentioned above. I expect that highway mileage will be at least as good as the 18+ MPG that I was seeing in the stock tune.
Looking forward to pulling my trailer with the SC. I'm going to try pulling in the Econo tune even though my trailer is above the weight limit for that tune. I'll keep a close eye on the Pyro and see what happens.
Daryl
(edit) I should have noted that my pyro probe is located preturbo on the exhaust manifold.
Old Jun 13, 2004 | 11:08 AM
  #657
IB Tim's Avatar
IB Tim
Isn’t the numbering system, not sequential for the 6.0, i.e. the next number in line could be for a Focus and then ten later could be for a 6.0????
Old Jun 13, 2004 | 12:26 PM
  #658
fmtrvt's Avatar
fmtrvt
I should have mentioned that's the original, unflashed code on my truck.
Old Jun 13, 2004 | 12:55 PM
  #659
Choctaw Bob
Then the flash was the flash revision that they were using at the time they buiilt your truck. These really are fantastic, tunable trucks. I hope someday that we will be able to control all the preminters like the Predator does for some of the cars. There is potential for 550 HP and 850 Ft Lb torque with the stock injectors. Slightly more with alcohol/water and propane injection.
Old Jun 13, 2004 | 05:33 PM
  #660
Vic_Ferrari
Flashes.
It's not "tech 1" or "tech 2", it's TEC1 or TEC2.
The letters just happend to sound like the word. "tech".
It could have been ABC, DEF, or any three letters and a number in nomenclature (like DAX0)
The 1704 will give back whatever stock file was in the truck when you tuned it with the 1704. If you set it back to stock and go to Ford....if they install a new flash, the 1704 will save th new flash as your new stock program and tune accordingly. If you truck runs fine now...just let it be...no need for unnecessary updates =o)
I'm not getting into any more flash discussions in here because it opens up 1,000 questions about "Is my flash supported" and the subject has become agonizingly redundant. I have already answered most of these questions.
Flashes before 9-29-03 are not supported. DAX0 is not supported.
If you have any other questions regarding flash, call superchips directly.
If you have DAX0, make sure Ford updates your PCM before installing your tuner. If not, the tuner will currently tell you to call superchips for an update.
When you call us with the hex codes that the tuner gives you, superchips will tell you to have Ford update your truck before attempting to reinstall the tuner.
The tuner will not tune your truck (it will tell you to go to Ford for an update, or to call superchips for an update) if it does not see an acceptable flash in it....so don't worry.
Please, in this thread, no more questions as to which flash is better than others or if the tuner will work on your truck.
If you have any more questions about what flashes are supported, call superchips directly. They have a list of which flashes are supported (and this list contains proprietary information with it, so it can not be released, but they can verbally tell you if your flash is supported and what to do if it is not.)
If you have your hex code, box code, or calibration code and call superchips directly, they will tell you if it's supported.
