Superchips 6.0 Microtuner Thread
Old May 25, 2005 | 12:25 AM
  #1891
MRKnight's Avatar
MRKnight
Customz - welcome to my mileage world That is my complaint as well, I have NEVER gotten more than 14.8 or 15 mpg in this truck even empty for 250 miles on a flat freeway with no load and cruise control the whole way (65) late at night. I've just learned to accept it - still better than teh 10 - 11 I got with my 2000 F150.
Old May 25, 2005 | 09:47 AM
  #1892
Customz's Avatar
Customz
I am not complaining, nor am I searching for mileage from a 3/4 ton CC 4x4. I am just extremely curious about the variations from 6.0 to 6.0.
In HP mode, based on the torque curves provided by SCMT, minus the driveline losses, it looks like 505 HP and 785 TQ at the fly wheel.
In comparison, I've driven a 1994 Nissan 4-banger, 4x4, single cab, manual that got 14-15mpg and couldn't get out of its own way!
Old May 25, 2005 | 09:49 AM
  #1893
Customz's Avatar
Customz
[QUOTE=Customz]I am not complaining, nor am I searching for mileage from a 3/4 ton CC 4x4. I am just extremely curious about the variations from 6.0 to 6.0.
In HP mode, based on the torque curves provided by SCMT, minus the driveline losses, it looks like 505 HP and 785 TQ at the fly wheel. If you use the power, your going to use the fuel!
Old May 25, 2005 | 10:57 AM
  #1894
MRKnight's Avatar
MRKnight
Couldn't agre with you more - use the power and use the gas. Maybe complaint was the wrong word - I should have used confused or baffled. I'm not expecting high mileage out of a 3/4 truck especially one that has an HP tune on it but I still can't get over the variations reported by other users on this site. Seems like I see between 11 - 22 mpg with the 6.0l reported here. In my case the mileage I get is what I have pretty much whether I use the SCMT or not. So if I don't get any worse mileage by leaving it on HP tune all the time, why not just leave it there?
Old May 25, 2005 | 12:15 PM
  #1895
Planecrazy's Avatar
Planecrazy
Have you considered the fact that those mileage figures represent several significantly different vehicles using the 6.0? For example, it seems to me that the Excursions do consistently better overall than most of the pickups. I presume that the aerodynamics are slightly better, although I think the X's weigh more.
Just a thought...
Steve
Old May 25, 2005 | 12:52 PM
  #1896
Vic_Ferrari's Avatar
Vic_Ferrari
These are just some of the variables that directly and indirectly affect fuel mileage (and whether or not or how much you will get a gain using a tuning device):
Gear ratio, tire size, driver habits, stock calibrations, tire pressure, whether or not it still has pilot injection, transmission type, trans gear ratio, altitude, modifications, fuel quality, fuel additives, vehicle weight, humidity, injector timing, vehicle height-frontal surface area (aerodynamics), oil temp, ambient temp, coolant temp, baro pressure, etc...
Whooo! Ric Flair sez that brick in the wind has a lot of variables!
Old May 30, 2005 | 11:14 AM
  #1897
amukia's Avatar
amukia
Thumbs up Just one more question
Ok, I'm almost ready to buy a Superchip to increase my mileage, but have one last concern.
What is the safest exhaust temps? cuz it seems that the superchips all increase it by quite a bit. Is there a long term effect that I should be worried about?
I'm pretty excited about the chip, the miss not so much. We're going to travel from CA to FL this summer and I'd like to have it in before then.
Any help is appreciatted.
Old May 30, 2005 | 11:28 AM
  #1898
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Any tuner will increase the EGT.... SC increases the least!
Are you buying the Tuner from http://www.motorhaven.com/home.php
GREAT sale right now
Old May 30, 2005 | 05:39 PM
  #1899
dahitman's Avatar
dahitman
the problem with the tuner is the restraint you have to have to not ruin you milage. increased milage is NOT going to happen. around town to use the 1800 to 2100 rpm range you have to practically gunn it from light to light, ruining mileage. good luck but your foot will be the milage killer. it has been so far with me.
i have the performance mode with no mods. no towing or hard driving so i'm not too worried about egt's.
Old May 30, 2005 | 07:11 PM
  #1900
amukia's Avatar
amukia
Ok, so will the increased EGT temps mess my EXC up in the long run? Or is this the risk we take?
So do your RPM's rise or go down or stay the same? Anyone know?
Thanks for your help guys
Old May 31, 2005 | 07:15 AM
  #1901
Vic_Ferrari
THis is something you can not say with any accuracy.
Some people get mileage gains, wven when getting throttle happy....as long as it isn't ALL THE TIME.
It also depends on how your mileage was stock. Trucks that get great mileage stock close the gap between stock and modified mileage.
Old May 31, 2005 | 08:32 PM
  #1902
Bigham's Avatar
Bigham
Pitch,
I get the same results with mine. In HP mode i get 18.3MPG and in economy I get 16.5.
Eddie
Old May 31, 2005 | 11:13 PM
  #1903
Daryl Hunter's Avatar
Daryl Hunter
My peak EGTs might be just a little higher than stock in tow safe, can't say for sure because I don't drive in stock mode anymore
But the average towing EGT is probably a bit lower. It seems that the tuning along with the shift profile allows the engine to run in a lower gear a bit longer before shifting to the next gear and I think that this lowers EGT and strain on the motor.
In the Economy and HP tunes the maximum EGTs are higher than stock but not all that much. I think I saw top temps in stock tune of around 1070 or so on my test hill. In Economy tune I've seen 1150 and in HP tune I've seen around 1230 or something like that.
Well within the safe range and to be expected given that there's more fuel being squirted into the motor.
Old Jun 1, 2005 | 09:48 AM
  #1904
Customz's Avatar
Customz
Anyone else experiencing driveline shock when using cruise control (HP Mode)? Specifically, when pushing the button to slow down or tapping the brake to disengage?
Old Jun 1, 2005 | 09:53 AM
  #1905
fordfast's Avatar
fordfast
Ya, mine does the same thing.
