Superchips 6.0 Microtuner Thread
Old Mar 8, 2005 | 12:13 AM
  #1681
Planecrazy's Avatar
Planecrazy
Ok, here's a new one for you, Vic...
I need to bring my diesel Excursion in to Ford for some warranty work, completely unrelated to my engine. However, there was an unusual coincidence that got me wondering ...
My auto climate control has been failing to redirect air to any ducts other than the defroster vents lately (even when I manually select other vents), although every once in a while it will mysteriously work. Lately those times have become extremely few and far between.
Tonight I retuned my truck to stock, and immediately after doing so I restarted the engine to make sure everything was operating "normally." First thing I noticed was that the climate control was working properly again. Now I'm VERY skeptical that reprogramming the engine management computer would affect the operation of the auto climate control, but I have to ask ... is there any part of the two systems that is interconnected? If so there may be a programming glitch to diagnose.
I fully expect your answer to be "no," but just in case the answer might be "yes" I'm throwing it out there.
Thanks in advance,
Steve
ps. I'm not looking forward to driving "un-tuned" for the next few days!
Old Mar 10, 2005 | 10:25 PM
  #1682
jim6liter's Avatar
jim6liter
Heres just a quick question.If someone needs to send their Super chip back for update.Do you need to put your truck back to stock?Or just leave it in performance mode.
Old Mar 10, 2005 | 10:51 PM
  #1683
Daryl Hunter's Avatar
Daryl Hunter
I would set it back to stock.
Old Mar 10, 2005 | 11:59 PM
  #1684
bnmccoy's Avatar
bnmccoy
My auto climate control has been failing to redirect air to any ducts other than the defroster vents lately (even when I manually select other vents), although every once in a while it will mysteriously work. ........... ... is there any part of the two systems that is interconnected? If so there may be a programming glitch to diagnose.
The fail safe mode by design is to go to defrost when something doesn't work correctly. Since all the modules are networked there is communications of some sort generally going on. IIRC the EATCM module is not CAN but the PCM interfaces any CAN scan tool communications to the SCP networked devices. The EATCM is also using data from the PCM.
It is possible to retrieve intermittant and continous EATCM, electronic automatic temperature control module, DTCs by pushing the front panel controls in various ways. PM me if you desire same.
Since everything is networked there is always the possibility for something else on the network to screw something up; but, more than likely restoring the program back to stock may have allowed some general reset.
Not likely anything in the tuner program is causing problems with the climate system.
I do wonder though; when the program is restored back to stock and codes are cleared.... Are all DTCs for all modules cleared?
Bob
Old Mar 11, 2005 | 12:17 PM
  #1685
Planecrazy's Avatar
Planecrazy
Thanks for the "411," Bob! I would definitely be interested in knowing how to self-diagnose the trouble codes if you care to share that info ... PM me on it, please!
I should mention that since last post the auto climate control has continued to sporadically malfunction, so I doubt that the tuning was responsible. Truck is due in to Ford on Monday morning for a variety of mostly minor issues, so we'll see what they find.
Regards,
Steve
Old Mar 11, 2005 | 09:03 PM
  #1686
jim6liter's Avatar
jim6liter
I don't know if this is in here someplace.What if you say that you have 450 or 550 when you only have a 250 on proram setup? Thanx for all the info.This is great.
Old Mar 11, 2005 | 09:05 PM
  #1687
Brian460's Avatar
Brian460
When posting a reply that is directly above …
THERE IS NO NEED TO USE THE QUOTE FUCTION..
Thanks
What are you trying to say here?
Old Mar 11, 2005 | 09:08 PM
  #1688
jim6liter's Avatar
jim6liter
When you are programming your pickup it asks if you have a 450 or 550.You know what i'm talking about?
Old Mar 11, 2005 | 09:14 PM
  #1689
Brian460's Avatar
Brian460
Thanks
I don't remember mine asking that.
Old Mar 11, 2005 | 09:18 PM
  #1690
jim6liter's Avatar
jim6liter
Thanks
I just checked my book.Maybe it only asks you if your setting performance mode.Is yours set to performance?
Old Mar 12, 2005 | 01:37 AM
  #1691
The Man's Avatar
The Man
Ok i have a Question, I have a '03 350 4wd Dually CrewCab. It has 130,000 Miles on it.. Today i bought a SC Programer and on the most agressive Setting i didnt notice a Huge difference.
I have Reset it for Economy for now to see if there was a Change but the only thing i notice is a Very hard Shift between 1 & 2 after that very smooth. So hard it feels like an Impact of some kind.
My question is this, Will this Motor wear out so much in only 130k mi that i wouldnt notice an Add on such as this? Or maby because most of the trucks it was tested on were not Dually's? Maby its not as Noticeable on a Bigger truck?
Im Newer to Diesels so please enlighten me!
Old Mar 12, 2005 | 05:03 AM
  #1692
Brian460's Avatar
Brian460
Mine has always been set to the HP tune.
Old Mar 12, 2005 | 02:40 PM
  #1693
Vic_Ferrari's Avatar
Vic_Ferrari
Is your 03 a 6.0 or 7.3?
It was tested on all trucks...
You should feel a huge difference, and your wot shift point should be around 4k instead of 3500-3600.
If you dont feel power, send it in for an update.
Have you floored it and held it on the floor yet?
Old Mar 12, 2005 | 02:41 PM
  #1694
Vic_Ferrari
Thanks
We like the quote function.
I think we'll continue to use it.
How do you know someone else hasn't replied while you are typing yours?
It happens a lot.
The quote function makes it easier to read.
Old Mar 12, 2005 | 02:43 PM
  #1695
Vic_Ferrari
Only the latest programmers will ask that question.
