Odometer Blackout Problem Fixed!!!
Old Sep 14, 2010 | 07:11 PM
  #226
Mikel_NY's Avatar
Mikel_NY
Hello All,
Are ya all talking about your odometer "blacking out" making it non readable at all or can you read the numbers in daylight and the "back light" is out making it not readable at night?
(I read the 1st 2 pages and starting skimming the rest of the 15 pages)
Old Sep 14, 2010 | 07:46 PM
  #227
alloro's Avatar
alloro
Yes, that is exactly what this thread is addressing.
Old Sep 15, 2010 | 08:51 AM
  #228
jmmec's Avatar
jmmec
Before I found this forum, the local Ford dealership "fixed" my odometer blackout problem -- the fix only lasted 7999 miles and it is starting to intermittently go out again.
I'll try the fix in this thread...
Old Sep 15, 2010 | 11:26 AM
  #229
Leader's Avatar
Leader
I think you'll find our fix lasts longer and is CHEAPER !!!!
Old Sep 16, 2010 | 11:41 AM
  #230
LAikens's Avatar
LAikens
Mine's fixed! Took a couple of hours but could probably do it in 30 minutes if I ever have to again! Thanks everyone for the great info!
One thing I will note. Watch the little gray rubber piece that goes into the odometer reset. Mine fell on the floor and once I put everything back together I realized it was missing. Luckily it was right by my feet.
Old Sep 24, 2010 | 09:16 AM
  #231
ottawaguy's Avatar
ottawaguy
Add one more to the list.
Props to Dakota_Viking for the thread and also to sloberdog for the great pics!
One more thing off the "To Fix" list.
Old Oct 27, 2010 | 07:52 PM
  #232
paltauf's Avatar
paltauf
Will this work for my 1997 for f350 diesel? Display is out all the time? If it will work for me, I will do this tomorrow.
Old Oct 27, 2010 | 08:24 PM
  #233
Leader's Avatar
Leader
It should, doesn't cost anything to try.
Old Oct 27, 2010 | 08:44 PM
  #234
ottawaguy's Avatar
ottawaguy
I agree....
If your odometer is out...chances are it is the same problem.
Old Oct 28, 2010 | 04:25 AM
  #235
Leader's Avatar
Leader
Nope... I forgot, the 97 F350 is the old body style and has a different dash.
You could take it out & look but I don't think the directions here will work EXACTALY.
Old Oct 28, 2010 | 05:59 AM
  #236
paltauf's Avatar
paltauf
odometer
Does that mean that I can;t fix the problem? Instrument clusters.com says they can do it 230.00. No bad but I don't want the 4 day turn around time. If that's what I have to do that's what I have to do. Let me know.
Old Oct 28, 2010 | 06:31 AM
  #237
Leader's Avatar
Leader
That means "I don't know" .
You can take it apart & try, that won't cost anything or hurt anything if it doesn't work now.
Other then that, I would check with your local scrap yard for a price before sending it off for 4 days.
Old Oct 28, 2010 | 08:34 AM
  #238
ottawaguy's Avatar
ottawaguy
Leader is right... I forgot as well.
The 97 F-250 & F-350 kept the 92-96 body style.
The clusters are not the same and therefore not prone to the same problems; certainly not the blackout problem.
Here is the cluster from the 97-03 F-150's that we are referring to.
Originally Posted by dakota_viking
<img src="https://www.ford-trucks.com/user_gallery/sizeimage.php?&amp;photoid=33177&amp;.jpg" alt="" border="0">
<img src="https://www.ford-trucks.com/user_gallery/sizeimage.php?&amp;photoid=33178&amp;.jpg" alt="" border="0">
Here are a couple pics showing your cluster and the reverse side of the odometer panel from the 92-96 models( & 97 f-250 & f-350).
Not even close....
I would also suggest looking around scrapyards.
I will mention thought that it may be worth a look to see if perhaps a connection is loose on the back of the odometer panel
Old Oct 28, 2010 | 02:14 PM
  #239
crabjoe's Avatar
crabjoe
THANK YOU!!
I haven't known what my mileage was for the last 4 years, on my '01 Epxy. As of today, I now know I'm just under 95K miles! Now I just need to figure out how to get the sucker started. It's been sitting for the last 2 years because of fuel prices, but now that I have a new born and I live in the boonies, I have to get it back on the road b4 it starts to snow.
BTW, I couldn't do the **** trick to pull the light switch out. I had to push a small screwdriver into the slot on the face plate and pry it out.
Thanks again!!
Old Oct 28, 2010 | 03:50 PM
  #240
paltauf's Avatar
paltauf
That display is exactly what I have. My friend has the speedometer/mileage cluster that your showing. It's from a gas. Can't I use that and keep the gauge and tach cluster stock from my diesel? I'd like to do this this weekend.
Thanks
