Odometer Blackout Problem Fixed!!!
Old Aug 6, 2007 | 09:04 PM
  #136
Mark62's Avatar
Mark62
My Odometer LIVES!!!
and I did not have to pay FORD...
THANKS
Old Aug 12, 2007 | 05:36 AM
  #137
Leader's Avatar
Leader
Well... I tried it.
Took more then 15 min to get it apart ...the first time.
Second time went faster even though I put more parts back.
Third time I went & found some more screws to replace the ones I have ridding around inside my dash now.
I'm getting good at putting this back togeather. Hope it keeps working after all that.
Old Aug 13, 2007 | 01:00 PM
  #138
Hawk3104's Avatar
Hawk3104
did mine over the weekend and it works....just reheated each one...to make a better contact....so far after driving for 2 days it works...thanks
Old Aug 17, 2007 | 06:39 PM
  #139
award70's Avatar
award70
really late to the party
Ok, I'm hoping that this thread is still being checked. I followed the instructions above and my instrument cluster looks completely different. My odometer is completely blacked out and only works in the winter months. Being in text that means it only works 2 months out of the year. I am trying to trade my car in however with the blacked out odometer they really want to screw me on the trade in.
It's a 2002 Ford Explorer XLT... can anyone help?
thanks
Old Aug 26, 2007 | 08:28 PM
  #140
turckproxman's Avatar
turckproxman
Same problem on my 2002 Explorer. It looks like there might be a bad solder joint on one of the resistors just about the odometer display ribbon connection on the main odometer board.
Just finished soldering the 4 resistors above the ribbon pin and made a quick check. It works perfect again. Hope this helps any of those with a newer instrument cluster.
Old Sep 13, 2007 | 10:37 AM
  #141
artmoss3's Avatar
artmoss3
Thumbs up
Sweet!! I have this problem and am going for it. Thanks for the pictures- very helpful. ( F-150 4.6l Triton V-8 )
Originally Posted by dakota_viking
OK campers, I think I figured it out! (Sorry if this gets long...)
I took out my instrument cluster to install my Nu-Image Flame gauges. Since my odometer has been plagued with the famous blackout syndrome, I decided to dive in and see if it could be fixed without giving Ford $375 for a new cluster.
What I found was a cold solder joint. With a couple of minutes using a solder pencil, problem solved! No need to fork over any money to Ford.
Here's how it goes: .
Using a service manual or CD, remove your instrument cluster
If you find a cold solder joint, simply touch it with a hot soldering pencil (NOT A GUN...It's TOO Hot!) and add just a touch of solder.
If all goes well, reverse the process to put it back together.
****IMPORTANT****
If you are not comfortable soldering or getting into electronic boards, you may want to consider finding someone in your area that is. (Maybe a stereo shop) I have been in electronics for several years and was willing to go for it rather than shell out the cash.
Good luck and remember to TAKE YOUR TIME!!!
If you have any questions, just shoot me an e-mail, I may be able to help out.
Old Sep 15, 2007 | 01:15 PM
  #142
Stevegud1's Avatar
Stevegud1
Three cheers for Viking!!! I bought my '99 F-150 Supercab a few thousand miles ago, and one of the few problems the seller identified to me was that "the odometer works when it wants to". I read this thread, mustered up the testicular fortitude to attempt it, and within an hour and with no cursing what-so-ever (other than when I dropped the socket into the dash when replacing the bezzel screw), it's all fixed! My odometer holds it's illumination with no flickering at all...even on the bumpiest of roads! It was the exact same pin that Viking shows in the post.
Nearly 4 years after the fact, Viking is still helping ppl fix thier odometer problem. Virtual-high-five to Viking!
Old Sep 15, 2007 | 04:58 PM
  #143
Bulldozer's Avatar
Bulldozer
“Way to go Viking”, this fix was “dead bang on”; the exact same pin was jack up on my 2000 Expedition. It took 30 minutes to complete the repairs and now the odometer works like a champ. Thanks
Old Sep 16, 2007 | 06:42 PM
  #144
ericnj75's Avatar
ericnj75
hey viking i did what you showed us this weekend. let me tell u something u r the man.I did everything u said and problem is fixed now i can pass inspection thats why i failed so thank you again.
Old Sep 17, 2007 | 05:18 PM
  #145
Stevegud1's Avatar
Stevegud1
Ugh! What state do you live in? That's a weak reason to fail a vehicle...but yeah, great fix. It does feel good to get into the truck and not fist-fight with the dash.
Old Sep 17, 2007 | 06:59 PM
  #146
ericnj75's Avatar
ericnj75
i live in new jersey
Old Sep 19, 2007 | 04:32 PM
  #147
wilkinda's Avatar
wilkinda
Damn am I glad I joined this website!! So far it has been 3 for 3 with issues that I had and has saved me ALOT of money.
I had the same issue with the odometer going blank and performed the fix as described above and SUCCESS!!!.
Only issue I encountered was that the dashboad parts as so brittle that they broke in several spots where the screws go in so now i cannot get the pieces tightened back down. Anyone know where to get replacements besides a junkyard?
Regards,
David
'99 Expy Eddie Bauer 5.4L
Custom 20" wheels & tires, custom exhaust, and K&N Filter
Old Sep 23, 2007 | 06:52 PM
  #148
99green's Avatar
99green
The original post was Sep 2003, It is now Sep 2007! 4 years have gone by and people are still learning from this post. I stumbled on this post and just fixed my truck odometer. I have never touched a soldering gun, can barely pronounce it and have never had my dash apart and did it in less than two hours. My dash is very thankful that I never have to bash it again.
Old Oct 7, 2007 | 10:41 PM
  #149
Sloberdog's Avatar
Sloberdog
Trailering
Thumbs up Pics and instructions
I put together some pictures and instructions on removing the dash and cluster. I wish I had something like this when I first attempted to remove the dash about 1 year ago, unsucessfully.
These were from my 99 Expedition built in 12/1998.
You will need 9/32 or 7mm sockets. If you have one that is magnetized, that would help not loose any of the screws.
15-Torqx bit or a tiny socket may even work.
Here is the link
The odometer is now working perfect!!!! This site rules!
Old Jan 11, 2008 | 06:10 PM
  #150
Gage2502's Avatar
Gage2502
I think im going to try this when it gets a litter warmer out.
Thanks ~Gage~
