What happened to him? He did another stunt like this and the shrapnel didn’t miss him this time?
One of the co-founders of FPS Russia was murdered and the crime was never solved, not that I heard about anyway. This took place near Carnsville GA, about 20 miles from my home.
Yes sir, I have been following your threads and hardships. I would love to help.
Heck... maybe even work with you guys on some stuff we have in the works. I honestly think what we plan to offer next year is going to blow peoples minds.
so its almost next year. Any update on what you have in the works?
Not the update we were hoping for... Thanks for keeping us in the loop and we all hope the new year brings you better luck and results with this build.
You could have bought the billet block from Hypermax with the number of blocks sourced and time spent.
Core blocks tend to go for around 400-500... 2,500 has probably been spent (not by me thankfully) on replacement blocks... accounting for the work hours might get to the 10 grand hypermax block lol.
Good news though:
Since last post the shop has sourced another core block, cleaned, pressure tested, bored/honed the cylinders, and drilled/tapped the main and pan bolt holes for the bedplate. Next steps will be to bring the pan rail and registers into tolerance for the bedplate, then line bore & hone, and finally kissing the decks.
