460 score
Old Sep 26, 2021 | 11:16 AM
  #526
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Originally Posted by ranger140892
I was gonna put flames and pinstriping on it, but I was told those casters couldn't handle that much torque.
Well get some chalk blocks for a Boeing 747 and you should be able to keep it in place. Or strap it like it is on a dyno run.
Hot Rod Ronnie does not need no stand.
Old Sep 26, 2021 | 11:18 AM
  #527
redroad's Avatar
redroad
Oh, and one of these for Scrappy
Back pressure
Old Sep 26, 2021 | 11:29 AM
  #528
ranger140892's Avatar
ranger140892
Grumpy goat
Back pressure
That welding helmet is awesome! I gotta get some kitty cat and unicorn decals for my helmets.
Not for back pressure exactly, though it does create some. I know it doesn't make a difference on the stand since there's no load on the engine, but I just don't want to risk a lean spike with those really short headers. And I want to set idle mixture and timing with conditions as near as in the truck conditions as possible.
Old Sep 26, 2021 | 11:32 AM
  #529
ranger140892
Grumpy goat
A friend asked why I built the stand to mount the engine so high. I told him that I want the engine at the same height as it will be in the truck, because altitude affects carburetor tuning.
Old Sep 28, 2021 | 05:55 PM
  #530
ranger140892
Grumpy goat
Ever since I assembled the valve train, I've been slightly off my rocker. Literally. I teetered back and forth about fixing it or leaving it be. Now that I'm ready to put the engine on the test stand, I couldn't just leave it alone.
Some of the rocker arms were not lining up dead center on top of their valve stems. I'm talking about "X" axis. Some were slightly off to the right, some to the left. The cylinder heads came with one piece pushrod guide plates, which were identical to the Manley guide plates I bought for the D0VE-C heads that I decided not to us. Anyway, I played musical guide plates until I just couldn't get anymore to line up properly. I thought about cutting them in half, lining up each rocker individually, then TIG welding the guide plate halves back together. So this morning I contacted a couple of builders. They both giggled and said "welcome to engine building." Turns out they both do this fairly often. It's too bad nobody makes two piece weld together guide plates for 460's like they do for SBC's and SBF's. Anyway, I had to cut and weld two guide plates on each bank. All the rocker arms are lined up properly now!
First pic is of the most misaligned one.
Here's a guide plate cut in half.
After getting the two halves of the guide plate lined up, you can see how much I had to shift them, in order to center the rocker arm.
I'm not a world class TIG welder, but those rocker arms are centered now!
Old Sep 28, 2021 | 07:03 PM
  #531
numba1killa's Avatar
numba1killa
Hey mike! this has been quite the journey! Please don't hesitate to make a video for us to gawk at your sweet 460... look forward to seeing it!
All the best.
Old Sep 28, 2021 | 07:08 PM
  #532
ranger140892
Grumpy goat
Thank you, Killa!
It has been a fun and educating ride for me. If I can figure out how to post video's to youtube, I'll do that when I run it (or destroy it) on the test stand.
Old Sep 28, 2021 | 08:05 PM
  #533
numba1killa
Congrats on 2000 posts! Always appreciated your input on others peoples issues. So Here's to another 2000 more!
Posting to YouTube is easy. As long as you have a newer smart phone. and an Email address. You can sign into YouTube, via email, and upload your video there!
Old Sep 28, 2021 | 09:35 PM
  #534
ranger140892
Grumpy goat
Thanks Brother.
I think I have an account on youtube. And I've got the last iphone muti-magnum gazillionite phone that was before this new earth encompassing megaloid calculus interpreting phone they just came out with.
Old Sep 28, 2021 | 11:21 PM
  #535
redroad's Avatar
redroad
It must be smart then.
Old Sep 30, 2021 | 10:18 PM
  #536
ranger140892
Grumpy goat
I got it on the test stand tonight. Working in that already overcrowded room with an engine hoist, engine stand, and engine test stand was a bit of a contortionist act. The lift points I put on the engine worked out great. I've got a lot of little detail items I have to take care of before I can fire it up. Make a throttle cable bracket, wire the ignition box, make a set of short exhaust pipes and attach mufflers, etc., etc..
Old Sep 30, 2021 | 10:26 PM
  #537
77&79F250's Avatar
77&79F250
Oh man that thing looks sexy setting there....oh wait a minute I just noticed the motor too. Looking fwd to the big reveal.
Old Sep 30, 2021 | 10:27 PM
  #538
ranger140892
Grumpy goat
I'll get you a disco ball pic later.
Old Oct 1, 2021 | 12:30 AM
  #539
redroad's Avatar
redroad
Hell Yeah Brother ! I'm excited for you I even offered tobacco
Old Oct 1, 2021 | 06:20 AM
  #540
ranger140892
Grumpy goat
Thanks Brother! I'll get my long turkey harvest pipe out. I have a tradition of smoking a pipe after a turkey kill. Seems appropriate to have a smoke if the engine build is successful.
