Building a Shop
I need to square up my pad. So, I'm thinking running a line from corner to corner on the front side to get a straight baseline. Then another line on the side and square that up. Once I have those set I will measure my anchor bolts from there.
If anyone has suggestions as to a better way, I'm all ears.
Does that make sense? I could probably do it faster than it took to type this out.
Spelling mistakes are free today.
One bite at a time and it will be done in no time, or at least before the snow flies.
But, I also have another angle. A contractor called me back. He replaced a roof for us several years ago as he was just starting up his business. He didn't call me back, but he posted on facebook that he finished a project. Well my wife commented that we have a building on the ground ready to go up. So, he called me today and will be out this afternoon to take a look.
I've been sorting parts and looking to see how we can set things up to reduce labor time. I've got a template for the columns also to help in setting proper locations.
If my contractor will take the job, I will go with him to just get it done quickly. I wanted this up many months ago.
Of course the building company hasn't gotten back to me about insulation. Man they suck. I'm hoping the contractor can get the insulation. I would sure rather give him my money.
Having a plan b in case the contractor doesn’t come through is always a good idea. Snow probably isn’t too far off for you so any help you can get will help speed you along.
Before you know it your truck will be tucked safely inside and it looks like there should be room for a second truck.
The contractor came out and said he has never done a red iron building and isn't comfortable having his business doing the work without help. He helped is brother in law build a 60X90 shop, but he doesn't want to risk his business name on it. His brother in law does fencing and other metal work. He is super busy so he wouldn't be able to help. He said he would reach out to another guy that has done this work and check his availability.
Back to square one. My studies have gone well and I'm getting more comfortable with the thought of doing it myself. But, I want to get it done quickly.....
So, I have a crew and they will start the first of October. My son's friend, his foreman, and another co-worker will do the work on their own time. So, weekends and evenings. I think they are over charging me, but I need to get it up. I will be working along side of them.
I'm currently sorting all the materials so it will be quicker and easier when they start.
We were discussing insulation. The steel company has delayed so much on the insulation that it won't arrive in a timely manner. The foreman suggested spray foam insulation. He said it insulates better, getting all the cracks that wind might find a way through and can be done after the building is up so we don't have to wait. Any thoughts on spray foam insulation. I won't be covering the walls at first, hopefully sometime down the road, but a lift will be a higher priority.
Now to get insulation companies to get back with me. Dang!
It looks like wedge anchors are designed to be used without epoxy and they don't bother testing that setup. I would assume all company wedge anchors are similar. By the way, I sent that out this morning and they replied by noon. Nice! After all the delayed or no response from people it is good to have someone reply quickly.
Dear Joe,
Thank you for your email regarding wedge anchors and epoxy.
Simpson Strong-Tie wedge anchors are tested to determine their capacity based on physical contact with the base material without the use of epoxy. There is no test data to support the use of our wedge anchors with epoxy.
Thank you,
Christopher Rizer, E.I.
Simpson Strong-Tie Company Inc.
Your comment:
I'm installing wedge anchors on a 30X40X12 red iron building. Should I also use your epoxy for additional support?
One of my previous employers sent their employees to a seminar on business bargaining. The main lesson I took away from the seminar is never let your opposition know how bad you want what they have be it a product, service or their money. Funny thing is when I restarted my business they asked me to do some contract work for them. I gave them my price and my former boss tried to get me to lower the price, I could tell he was using what he was taught. The problem was, for him, is I knew they went to a couple of other places to have the work done and they got bad service that took time to repair and they were charged more by the other places. Secondly, I really didn't need or want their project. So I knew they needed me more than I needed them. I got the job and many more for my going price.
As for spray foam, be careful here. Some products are flammable, not cool when you want to weld or grind. There are also bonding issues to steel with some products. Not sure how much your building will move (most do) that might affect your insulation as well.
Marten
Good tips on the insulation. I will be sure to ask those questions.
It is worth a call to your homeowner insurance carrier and explain to them your plans, they may have a temporary policy that you can purchase for the time of construction. I concur with Marten on the spray foam, finding a water leak in the roof is a near impossibility.
Everyone is a friend or a buddy until they get hurt and a lawyer is involved. Then all bets are off. No such thing as a “good guy” in those situations.
In terms of coverage you should be able to get a workers comp policy as well as an umbrella and/or increase your limits. If it were me I would get the highest level of coverage I could. In the scheme of things the added cost is cheap compared to the total cost of the building and putting your financial future at risk….
FYI, ex insurance guy. Seen a lot…
As an aside, NEVER loan your ladder to anyone, even your best friend. 3rd party ladder injuries, Top 3 homeowner claim…
