Entering Nvk4 , php prompted me to use vnaaas3 no tunes for that came up in modified injector tunes, not sure if there is a different strategy that would work instead.
Wonder if Cody is on here, he would know. I believe he worked for PHP at one point. I think it is DP tunes also. What was your boost? i didn't see that gauge.
That’s strange. Dad’s is NVK5 and when I did his burn years ago with the PHP FU burner it recommended VRAA6S3, same as my PMT2.
So just now I checked in the Hydraflash software and see both NVK4&5 call for VRAAAS3. I’m thinking the VRAA6S3 would also work. I’m almost certain this is the strategy I used on his NVK5 truck.
The information below is from a "draft" spreadsheet that I and a couple of other FTE'rs are working on in creating a thread. So, it may not be 100% accurate, but should be pretty close. In addition, I don't think the PHP Titan Unlock allows for modified automatic transmissions and FTN has a BTS 4R100.
This is what I have listed as possible Hex Codes for the NVKX Box Code.
