My "01" Excursion Thread
Old Mar 25, 2022 | 12:29 PM
  #181
01__Excursion's Avatar
01__Excursion
Originally Posted by JAck19
LOL your ride is as far from lipstick on a pig as any get in here. Stemming from my background in car audio and custom work when I was younger, my absolute favorite thing to see is something that's not OEM or original to the vehicle that is integrated in a way that nobody (or very few) would notice. I love each little add-on, customization, and fix you do, and how you make each piece of the puzzle look original to the vehicle. It's clean and not half-assed, and that's REALLY hard to find.
There is still a small birds nest behind the lower steering access cover from the previous owner for the remote start, and keyless entry. One day I'll see about getting that addressed.
But I try, being in the service industry for many years now, I prefer things to be integrated and serviceable.
Old Mar 26, 2022 | 07:24 PM
  #182
01__Excursion
Was able to pressure wash the Black 7.3 today, topside and underside, what a mess, but I should have less mud/sand falling on my face when I take things apart. Next batch of parts in line to install.
New OE CAC boot clamps, bumper sensors, sensor brackets, and bumper. Used complete bumper, and taillight harness. I forgot that my current bumper has the Ni-Light LED's cut into the bumper, I don't want to loose those, so I will address moving those over too. The new bumpers are coming with a protective coating on the backside, the same was applied to my front bumper.
Old Mar 28, 2022 | 12:05 PM
  #183
WI Dan's Avatar
WI Dan
It's must to be sooooo satisfying to accurately salvage an harness AND plug it all back in together with proper connectors!!
Old Mar 28, 2022 | 12:07 PM
  #184
WI Dan's Avatar
WI Dan
You do. There are also Weathertech mats in front, and either weathertech or OE in the rest. These are not my color, and will be listed when I clean them up.
I'm cheap too, nearly all of that wiring I pulled back through the way it went in. Good wire is always nice to have on hand.
I'll watch for your listing of the mats.
Yes - wire is expensive! When I hit up the salvage yards, I always take time to hunt and snag some extra lengths. Especially heavier stuff for battery bank building.
Automotive wiring is better quality too.
Old Mar 28, 2022 | 03:33 PM
  #185
01__Excursion
Lets hope. I deliberately pulled that harness from the 2001 junkyard rig a week ago, because the colors will match my 2001. The 2000 wire colors may not be a match. Proper color matches will help in the install, and diagnosing issues in the future.
Old Mar 28, 2022 | 03:35 PM
  #186
01__Excursion
I'm cheap, I save what I can. The BMW 7 series, and such are a good place to find good gauge battery wire. I grabbed a perfect main battery cable from the trunk to the engine which I used for my stereo amps, mentioned somewhere above on one of these pages.
Old Mar 29, 2022 | 01:23 PM
  #187
01__Excursion
Sourced 4 wedge trailer tires, and aftermarket Ford rims from a friend to put on the parts X so I can get the 18" OE ones off to have re-done. Had 2 of the tires mounted today.
Old Apr 7, 2022 | 06:55 PM
  #188
01__Excursion
Got the mis-matched lug nut situation handled today, 14x1.50's installed on the front.
Dropped the 18" OE rims off at the rim shop for polish and powder coat last Friday, they should be ready in another week.
Old Apr 7, 2022 | 10:04 PM
  #189
JAck19's Avatar
JAck19
Just one man's 2¢, I'm not big on spline lug nuts. I used to work for a tire shop and the adapter would crack all the time. I eventually replaced the splines that came with my truck with the fuller style, IIRC 13/16"
Before
Swapping
After
Regardless, cheers to progress You're making a lot more headway than me right now
Old Apr 8, 2022 | 05:03 AM
  #190
01__Excursion
I installed them by hand with a half inch ratchet. I bought them so I could have the junk rims installed on the junk X tight. The junk X does run, but came with no transmission, It needs to remain movable (pushable) as long as possible, and when the day comes for the tow truck to haul what ever is left away. When I start going to the lake soon, I will need to move it so I can get things out of the garage. I'm building a leantoo behind the garage for parts storage, the dingo, and all of it's attachments, I'll possibly roll it back there.
Old Apr 17, 2022 | 07:28 PM
  #191
01__Excursion
OE 18" rims are said to be finished this mid week. Motivated myself to tackle the rear bumper late this afternoon. I made a large miscalculation, I forgot all about the bumper lights from the previous owner. I thought no problem, I bought a small pneumatic sawzall, blades, and a smaller unibit. Having the bumper off today I now see that there is no other place in the bumper for them to install, moving out a little further in a space that looks good, is a no go. The bumper backing frame work is in the way. I really liked them there. I think I will mount them to the ends of the receiver after I fabricate some sort of bracket. Both my junk X bumper harness, and the one I pulled from the junkyard had broken sensor plugs on the drivers side, so I cut the bumper off the junk X, and transferred a good plug from it. It's looking that I may not need to replace all of the harnesses that I got, which is a plus. The bumper sensor plug was already there, had the 6 wires, and a jumper cap on the end. So if I have the reverse module plug inside, then I'm plug N play. For now all of the exterior connections are set.
Old Apr 19, 2022 | 07:49 PM
  #192
01__Excursion
A little more progress. My confusion at the junkyard has been put to rest. When I was pulling the bumper and rear HVAC harnesses from the 01 junk yard, I couldn't understand why the harnesses seemed to continue in a loop from the rear AC area through the pass taillight body area, down to the bumper, and across to the drivers side, and continue up the drivers frame, including branch offs to the fuel tank Etc. The PAM wiring is all part of the drivers frame harness, picking up signal from the tranny range selector and continuing to the rear behind the bumper at the main plug behind the license plate. I am pre-wired to that point, fortunately I pulled all the correct harnesses, there was a brief point I thought I would need the frame wiring too. So the rear AC harness with pass through body grommet, and connector are installed, I will have to remove the bumper again, and swap out part of the rear end harness that includes the tail light plugs. Once that is done, I should be able to connect the dash switch and try it out.
Original harness showing fully pre-wired on the left, and non PAM optioned on the right
Disassembly
Disassembly
Disassembly
Disassembly
Replacement PAM harness installed
Factory rubber plug for PAM wiring hole
PAM harness/plug pushed through pass body
Final taillight harness to be plugged into the PAM plug at pass tail light
Old Apr 22, 2022 | 04:50 PM
  #193
01__Excursion
All of the PAM system is hooked up, but it no worky..!! Well, it does have power, the bumper sensors are ticking, and I have 5 DTC's to parse through this weekend. I will need to check all of the added harnesses from end to end. I have the complete PAM system from the junk X, and another spare speaker, and module form a 04. Luckily the PAM is now on the ISO network, and can be read by FORScan.
Old Apr 23, 2022 | 12:02 AM
  #194
JAck19's Avatar
JAck19
I find it strange that it throws an error for all four sensors, though I have no prior experience with the system. I guess in my mind I feel like something should work. I guess I'm about to learn though; I have a faulty sensor to find and fix on my F250.
Thanks for sharing your progress
Old Apr 24, 2022 | 02:24 PM
  #195
01__Excursion
Tackled the diagnostics of the Park Assist this morning with a clear head. After pulling the codes, and studying their diagnostic procedure in the manual, I started with the module plug. I removed it from the PAM to test the speaker wires first, and found what I figured would be my issue. Corrosion on 3 of the most important pins. Not sure how since it's up so high, maybe the A/C lines dripping on the plug just right from the donor vehicle. I opened a spare scrap plug (from a 2004 I grabbed a few years ago) to see how it came apart. Easy enough, so I opened up mine, cleaned things up with electrical spray, then used Deoxit to coat the pins, and sockets. My spare 04 speaker, and the speaker I pulled a few weeks ago with the module and harnesses were both bad. No OHMS, the speaker from the black junk X tested good. Once I had a working system, I tried the 2000 module from the junk X, and the 2004 module in my 2001 set up, both modules work. The junk X module (2000), and the module I got from the junkyard (2001) a few weeks ago are both 4 W/D, the 2004 is not. So it won't be as accurate as it's intended for a vehicle closer to the ground.
Practice plug to experiment with. End cap slides off.
Molex slides out of housing.
Spades are removable if needed
My installed module plug un-plugged for inspection.
My installed harness plug with corrosion on 1,2,14,15
Original dash insert, with aftermarket wood trim
Obvious.
Will remove the wood-grain trim and transfer over to the new dash trim.
Spare 2000 Junk X module (top), 2004 Module (bottom)
PAM is error code free. The PCM , and Message center errors I created after running a test on the modules, the vehicle off created an error for each...
