Did you request them to send some? As far as I know they are only sending them to people who have had issues and and contacted beamtech about it. I know none of my sets came with them either fogs or headlight bulbs. Luckily I have had no issues.
I sent them an email and they replied the next day that when they got them in stock they would send them.
you can get to them just by removing the filler tube there but needing a little more leverage, I removed the battery. Which helped a ton
Use a step stool so you are higher then the lights. I actual had to face the back of the truck on the driver’s side and use my left hand to remove them. Did the same on the passenger side and used my right hand.
I did not remove the battery. I posted this info some pages back in the thread.
Yes I emailed them with my order #
They only sent enough to do my 2016 truck with me specifically telling them I’d bought TEN of their Bulbs to do a 16&19 Truck so I’ve re-emailed them again.
I tried this and it failed to work for me. It seems that Ford used a 1/2 inch drive impact wrench on my 2018 headlight bulb install. Joking aside, it should not require removal of batteries, coolant overflow tanks or fender liners to gain access to a simple expendable item on a truck.
I'll be trying again tomorrow to replace the battery side bulbs and the lower bulb on the driver's side. I wish there was a tool like a plumbing basin wrench that could grab the ears of the bulb and facilitate applying torque.
Yup, it was easy for me. Popped out the snorkle on passenger side for the quick change.
The drivers side was easy too. Used a step stool which helped me get better leverage on pulling out the stocks.
My beamtechs came with a red gasket on them. So I'm guessing I don't need to pull the stock red rings off and add them to the beamtechs.
no need for me to remove the grill.
It's not really possible. If you try to double up the gaskets that light is not going in. Do NOT add the stock gasket to the Beamtech gasket.
You can fit a bulb with either/or to see if one happens to fit a little better than the other if you like.
My BeamTechs didn’t fit near as tight as I’d like but I don’t think they’ll leak or vibrate loose.
I thought about adding a tiny o ring on them but I didn’t.
i really like them well so far ..... IF they’ll last ?
They are already in, no added gaskets, and don't feel like they will come out.
