I think the Alla fogs could be improved upon. Scroll through this thread, you'll see that some others are reporting good results with some other brands of fogs.
Update on my radio static problem after installing Beamtech headlights. I contacted Beamtech thru Amazon and they shipped out Canbus Decoders that plug in line to the headlight bulbs. After installing all 4 of them all the radio static is gone. Very good of them to follow up and just handle it. Also for anyone contemplating changing out their halogens, you do not need to pull your grill and headlight housings. I did that the 1st time and it took way too long for such a simple task. On our 2017 6.7 remove the drivers side battery and there is plenty of room to get at all the bulbs. On passenger side remove the upper intake snorkel by releasing just 1 push pin on top and 2 built-in snaps right in front of the passenger side battery. This will give plenty of room to change the bulbs.
These LED bulbs are excellent and provides a very clean and even beam pattern. It is a very bright light. Also it does not blind on coming traffic. No need for adjusting. It matches my LED fog lights perfectly which are another brand but still 6000k.
What about the side light on the headlights If I searched it properly it is a 2825 bulb is that correct? Any leads on a good LED for it? Should it be white like the OEM bulb or amber?
No need to, but you should check it just in case. My 2018 and a coworkers 2017 had our stock headlights pointed about 4-6" above where they should have been STOCK. Way out of adjustment. I adjusted mine down, much better now. I was flashed all the time stock, even worse after LED install due to brightness.
Check your owners manual, easy to do. Need flat surface, wall, 25', tape measure, and I think it is a Phillips screwdriver. Easy, super easy...
It's been quite some time, I wasn't aware that Alla switchbacks weren't available anymore. Here's a handy guide from SuperBright LED which tells which number bulbs work for each location. Just input your vehicle information. I've used their bulbs for my rear turn/brake lights and some other things along the way. I have no complaints with SuperBright. Unfortunately they don't show a switchback for front signals. But they can be found in many other places.
Thanks for the info & help on the LED headlights. But how do you feel the Fogs work? Does have them bright white matching the headlights help at all in Snow/Fog/Rain weather?
Im going to grab a set of these Beamtech for my 2016 F350 but on the fence for the Alla fog lights. Any more info would be great
I started out with Alla fogs and then switched to Beamtech, hoping to be uniform with the headlights for color. But in my opinion, the fogs don't do a whole lot (either brand) since going with Beamtech headlights. Yes, they might light up the roadsides a little more but not all that much.
I installed this Beamtech LED headlight bulbs in my 2015 F150/ On my way to work I got a headlight left and headlight right error message on my information display.
I'd have to add a load resistance to the circuit to correct this.
Neat product, interesting that you have to contact them for price. Rather just find a site that has a product that I can click "buy" and complete the order.
