My '87 has 1156/1157 bayonet base bulbs.
Maybe that change came with the retirement of the Bricknose style in '91?
Jim, it may have started in 1990 when a number of other changes were made, like high pressure in-tank pumps instead of the frame mounted pump, changing the oil pressure gauge to an oil pressure indicator, relocation of the TFI module from the distributor to the inner fender.
Bill - You may have been typing when I responded, but I think the light change was in '88.
Big Blue went on a 172.3 mile trip today. We ran mostly 60 - 65 MPH on main highways around central OK, and it took 14.061 gallons to fill it completely Full when we got home. That's 12.3 MPG.
Having said that, I wasn't sure it was going to take any gas. You see, when we pulled in to fill up on our way out of town the gauge showed we had about 1/8 tank. I put 16.9 gallons in, which put the gauge right square on Full. It stayed there for the first 50 mikes or so and then started dropping. But after a few more miles it started going up and ended up at about 1 1/8, meaning past Full. So, I assumed we were making gas.
Anyway, the truck performed flawlessly. It never once failed to crank, although I know that problem is still lurking. And the fuel lines didn't leak where the rear tank would connect. Yes, it still has the wiring problem with the left turn & dash lights. And there's serious wind noise on the passenger's side due to a lack of a window run. But, the steering is the best of any 80's truck I've driven in a long, long time. And the engine pulls like a locomotive. So, what's not to love.
Glad to hear that Gary. Mine is very strong (4.9) and a similar problem with the gauge , I put in 5 gals. and it reads full, I drive a short distance and put it away, the next day it reads empty so I run it a few miles and it reads near 1/2 tank. I carry a can with 1-1/2 gallons in it. My left turn signal stopped working but if I lift up slightly on the handle it starts working again. I hate the thought of replacing that switch so I'll live with it for now.
Barry B. (86 flareside 6 light blue and cream inserts)
You need to put one of your electronic voltage regulators on the gauges. Not bad for a standard length MT 460, Darth has gotten 12.5 on a nice long run to WV and seems to do better at higher speeds, like 65-70, probably a factor of the rear gear and OD 4th in the E4OD 55 mph = 1500 rpm.
I don't think it is the ICVR. The oil pressure gauge is working, and is quite steady and moves perfectly with the mechanical oil pressure gauge. So, I think it is the sender. However, I suppose it could be the gauge itself. Anyway, I'll take some readings with my DVM at different levels of fuel and see if I can determine where the problem is.
But, I agree with you that it isn't bad MPG. In fact, I'm pleased with it. Dad's truck got 10.3 when I got it, and it is lighter and didn't have nearly the power. But with Rusty's engine and the ZF5 it got almost 15 in conditions like yesterday. And I think Big Blue can get 14 with the ZF in those conditions.
So, BB is now in "useful" mode. (Maybe I should have named him Onesimous. ) So I'll be driving him and, once I get the shop cleaned, turn my attentions to Dad's truck. Yes, I'm sure there will be things I need to do to BB along the way, but for now I want to see if the oil leaks dry up.
I knew there was that certain "something" about you that I liked!
There really is Nothing Special about me. Any "something" I have is just a gift (right now I wish that was where I got the idea for my screen name, but it wasn't, it just fits here too)
