6.2L V8 Discuss the 6.2L V8
6.2L longevity
Old Feb 18, 2020 | 02:11 AM
  #136
Cold Trigger Finget's Avatar
Cold Trigger Finget
Originally Posted by ytilibailer
THE DISPLAY IS IN KILOMETERS , in miles that is 178222
Get ford on the line , i think my truck is reliable.
Minus 40 C.
I know very well how that feels. I live at 64° N lat. 40 below is common enough here.
Anything special you do for the cold with the truck ?
Use a winter front ?
Oil pan and tranny pan pad heaters ?
What wattage ?
Factory block heater or more than factory ?
How does the power steering system hold up in the cold ?
By Cold, I expect you know what I mean.
Old Feb 18, 2020 | 06:03 AM
  #137
Lamoon78's Avatar
Lamoon78
Originally Posted by systems
Ed, any idea how many hours your first engine had on it?
I believe he told me in a pm somewhere in the high 400,000 mile area.
Old Feb 18, 2020 | 04:15 PM
  #138
tjc transport's Avatar
tjc transport
i ain't rite
first engine had cam issues at 418k miles if i remember correctly. but he asked how many HOURS were on it, not miles.
Old Feb 18, 2020 | 04:18 PM
  #139
Lamoon78's Avatar
Lamoon78
Excuse me not many people care about hours its miles but whatever.
Old Feb 18, 2020 | 07:40 PM
  #140
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
When you looking at used trucks that have no service records it's nice to know if it's been idled for hours on end, in the winter my work trucks used to get idled for long periods to keep the cab warm so I could get in and get warm and the life of my motors showed it.
Denny
Old Feb 19, 2020 | 03:48 AM
  #141
tjc transport
i ain't rite
yup. one truck i looked at had 60k miles, and 7000 hours...or 8.5 MPH average speed.
when i bought my 2014 it had 93,000 miles on it, and 4800 hours. for an average speed of 19.3 mph over the 19 mounts of it's life.
Old Feb 19, 2020 | 08:23 PM
  #142
Cold Trigger Finget
I wonder if there is an rpm stipulation thing in the idle hours. ALOT of work pickups on The Slope have a ( high idle ) switch that runs anywhere from 800 to 1200 rpm. It keeps the oil pressure up and the engine making more heat for the cab.
I wonder if that creates more or less realized wear because of it keeping the o.p. up and the engine making more heat.
Old Feb 20, 2020 | 03:47 AM
  #143
tjc transport
i ain't rite
the new trucks show both idle hours and total hours.
Old Feb 20, 2020 | 10:50 AM
  #144
Cold Trigger Finget
I was wondering if idling at 800-1200 rpm produces less wear than at the normal 600 rpm ?
Old Feb 20, 2020 | 02:55 PM
  #145
tjc transport
i ain't rite
good question. on the diesels if they are going to idle longer than 2-3 minutes the fast idle gets kicked on. i use 900 rpm fast idle.
Old Feb 20, 2020 | 05:33 PM
  #146
rvpuller's Avatar
rvpuller
I think the biggest problem with idling to long is carbon buildup because of low heat and cats getting plugged up for the same reason. Also if it's cold a lot of moisture will build up in the crankcase with low engine temps at idle, when I had my work trucks I changed oil often in the winter because they idled a lot.
Denny
Old Feb 20, 2020 | 08:03 PM
  #147
Cold Trigger Finget
Ok. Cool ! They do get loaded up with crap @ 600ish rpm plus they don't make much for heat. On The Slope a lot of the trucks would kick on the high idle. Then when ya stepped on the brake to put them in gear the idle would go back down to normal.
The reason we left them running is , at arctic temps and windchill they would need to be hauled back to the shop if shut down for more than 15 minutes. And on some jobs the pickup or drillers truck was also the job shack. Lunch and break shack.
Old Feb 20, 2020 | 09:22 PM
  #148
nikerret's Avatar
nikerret
I may be completely misremembering this, but I believe the higher RPM is better as it keeps oil splashed in the cylinders (the walls get washed by fuel at low RPM). The fuel will also not be completely burned off and start to seep into the oil, contaminating it. Running up from idle keeps things from building up, as stated.
I recently put the high idle on my truck. It's a two-step process. One switch kicks it up to around 900 RPM. The second switch activates a potentiometer that I can dial the RPM from 900 to 2,400.
Old Feb 21, 2020 | 09:40 AM
  #149
stephen.osborne1's Avatar
stephen.osborne1
I imagine the cold and idling is much less of an issue on these gassers than diesels... Although I would assume the high idle has a positive affect on oil getting up to the valve train, especially on an OHC motor.
Old Feb 21, 2020 | 11:26 AM
  #150
DSLTRK60's Avatar
DSLTRK60
Originally Posted by Flatbed Ed
lately the only thing I have done to it is front-end work like ball joints and tie rod ends wheel bearings things like that. I remember putting a fuel pump several months ago as well. that stopped my long crank problems I was having.
I'm still using the original transmission and rear end. And I also put some new shock absorbers on the front
So are you betting on getting to a million? That is an impressive amount of mileage Ed.
