External fuel pump
Old Jul 18, 2016 | 12:10 AM
  #376
vjsimone's Avatar
vjsimone
Originally Posted by sgauvry
Got it. Thanks!!
With my Actron, I did KOEO fast and slow tests with engine off, as well as KOER tests with engine on. The KOEO Tests gave me an 11, while the KOER tests codes were 41, 34, and 12.
I found a vacuum leak and fixed that. I then did a re-test of CM codes using my Ford code reader. Now I show a 31, and that's it. I'm too tired to connect my Actron to see if it will still show the other codes under a KOER test, but will do that tomorrow.
Again, thanks for your efforts!
Steve, KOER Code 31 may mean your EVP is reporting that your ERG did not close all the way.
If you have a replacement EVP the rod length could be incorrect.
EGR could be holding vacuum keeping it open a small bit.
EGR Solenoid/valve could be sticking in the open position.
Your new EGR could be defective (last choice).
Old Jul 18, 2016 | 12:19 AM
  #377
vjsimone's Avatar
vjsimone
Originally Posted by ctubutis
All of that - 23 pages - because of two swapped wires.....
LOL, that's as crazy as his rainyday issues.... Who in the hell, swapped those wires?
We will have to tackle that rainyday issue after he recieves his 4th computer........
He did fix his lift pump issue..... and Code Reading....
Old Jul 18, 2016 | 06:09 AM
  #378
sgauvry's Avatar
sgauvry
I adjusted curb idle speed. That code disappeared.
What remains is code 34 and 41.
With regard to 34, I thought I should test the voltage. There are 3 pins. One pin registers voltage of 5.0. The other pins register nothing. It appears one pin goes back to the ECM and one pin is ground? So I'm assuming voltage is ok?
If voltage is OK, then it's either sticky or not working. With engine running, if I disconnect the electrical connector there is no change whatsoever in engine performance. Also, I cannot feel any vacuum whatsoever if I put my finger on the inlet for the vacuum hose. Is this normal?
I'd like to remove it all together, but there's that PA inspection issue.
I found this procedure:
Testing Procedure:
1. Disconnect the EVP sensor connector. With the ignition ON and the engine OFF, measure the voltage between VREF and SIGRTN terminals of the EVP sensor harness connector. If the voltage is 4vdc-6vdc, the power circuits to the sensor are OK...goto 2.....NOK?...check VREF to battery ground....OK?...SIGRTN wire needs to checked for open condition....NOK?...goto 3.
2. Reconnect the EVP sensor. With the ignition ON and the engine OFF, measure the voltage between EVP sensor terminals EVP and SIG RTN. If the voltage reading is between .25vdc - .67vdc the sensor is okay....goto 4......NOK?...replace EVP sensor.
3. Check VREF voltage at alternate sensor (TPS or BP), sensor disconnected, Ign On, voltage should be between 4vdc-6vdc....OK?...trace EVP VREF wire for open condition in harness....NOK?...rerun KOEO and confirm failure code presence of sensor used for this test.
4. Ign Off, ECM and EVP sensor disconnected, check continuity of the EVP signal wire pin from the sensor connector to pin 27 at the ECM connector, resistance reading should be less/equal to 5 ohms....NOK?...trace EVP signal wire for an open condition and repair.....OK?.....bad ECM.
I'm not sure how to do procedure 2 - which voltmeter probe to which connector?
Old Jul 18, 2016 | 06:51 AM
  #379
sgauvry's Avatar
sgauvry
I also took off the EGR valve. It's not sticky and the rod from the bottom of the valve pushes up easily without resistance except the spring.
Voltage seems to be ok. I get a reading of 5.0 between the VREF and sigrtn and a reading of .4 between sigrtn and EVP.
How do I know if the sensor rod is not the right length?
Testing Procedure:
Old Jul 18, 2016 | 07:15 AM
  #380
subford's Avatar
subford
Subford, I think the O2 signal is fed into an amplifier in the ECA via pin 29. Do you have a schematic of this?
Look at post #339 in this Thread. It is called EGO.
Old Jul 18, 2016 | 07:33 AM
  #381
sgauvry's Avatar
sgauvry
Yes. I found that. I see two connections to the ECM, one at pin 29 and one at pin 49. That confuse me because the O2 sensor has one wire coming from it that plugs into a white connector, and that has one wire running directly to the ECM. What am I to understand by looking at this? Am I to check the continuity? To pin 49?
Old Jul 18, 2016 | 07:56 AM
  #382
vjsimone's Avatar
vjsimone
That would not hurt. You could ground pin 29 using the paperclip method, then check the wire at the O2 to ground. Pos meter lead on O2 wire, neg meter lead on the "Y" pipe.
Old Jul 18, 2016 | 08:07 AM
  #383
subford's Avatar
subford
Note the diagram I used was for a 1986. A Truck 1985 may be different on the O2 sensor.
  #384
vjsimone's Avatar
vjsimone
Do you think the EVP is old or new?
Do you have a Code 34 or 31 ?
The EGR does not open at Idle, only during normal acceleration.
You should be able to feel vacuum during acceleration.
Do you have a vacuum gage?
After you clear the 30’s codes, you can make a gasket, and block the hole between the EGR and Intake.
Old Jul 18, 2016 | 08:08 AM
  #385
sgauvry's Avatar
sgauvry
I was planning to take off the O2 sensor and clean off the soot. Could I just connect the positive wire to the base of the O2 sensor and the negative to the pipe? Is that with battery disconnected?
That would not hurt. You could ground pin 29 using the paperclip method, then check the wire at the O2 to ground. Pos meter lead on O2 wire, neg meter led on the "Y" pipe.
Old Jul 18, 2016 | 08:20 AM
  #386
vjsimone's Avatar
vjsimone
Well that would check the ground between the base and the pipe, but not check the wire to the ECA.
Anytime you remove the ECA connector, it is a good idea to disconnect one side of the Battery, for continuity checks, I would remove the Pos batt terminal.
I would not spray any chemicals on the O2 sensor.
Old Jul 18, 2016 | 08:21 AM
  #387
subford's Avatar
subford
OK the only EEC diagram (EVTM) I have for 1985 is for the E-series with the 4.9L and the truck 5.0L may very well be the same. It looks like all 5.0L & 5.8L engines in vans had carburetors in 1985.
The van 1985 EVTM 4.9L shows the EGO sensor goes between pin #29 and the other end has the ground symbol on it.
Old Jul 18, 2016 | 08:39 AM
  #388
vjsimone's Avatar
vjsimone
What are the colors of the 3 wires going to your the EVP sensor?
Old Jul 18, 2016 | 08:41 AM
  #389
vjsimone's Avatar
vjsimone
5.0 vdc is good.
Old Jul 18, 2016 | 08:52 AM
  #390
sgauvry's Avatar
sgauvry
They appear to be light brown, and two black.
