External fuel pump
Old Jul 20, 2016 | 07:08 PM
  #481
sgauvry's Avatar
sgauvry
Yes, it is new. And I have a spare too. For my year, they didn't include the diode in the connector. I believe they started that in models after '88, although I am not certain of the year.
Originally Posted by vjsimone
Steve, do you have a new IAC? If so you need to check to see if it has a built in Diode.
Old Jul 20, 2016 | 07:11 PM
  #482
sgauvry's Avatar
sgauvry
More Information for STANDARD MOTOR PRODUCTS AC22
Old Jul 20, 2016 | 07:15 PM
  #483
vjsimone's Avatar
vjsimone
Still might want to check, I thought I read somewhere that the replacements came with a built-in diode.
Old Jul 20, 2016 | 07:17 PM
  #484
sgauvry's Avatar
sgauvry
OK. Here's my thousandth question. Since diodes allow current to flow in only one direction, suppose I installed a diode and there happens to be another diode in the IAC connector. Current is still flowing in one direction. Would it hurt anything?
Old Jul 20, 2016 | 07:31 PM
  #485
vjsimone's Avatar
vjsimone
I have read that it causes your idle to surge.
Check your IAC for a "D" stamped into the plastic part.
"IAC diode acts as a freewheeling, (or flyback), diode that helps quickly turn off the IAC solenoid. Since the solenoid cannot stop current instantly, the flyback diode provides an alternate path for excess current when the coil is switched off. In other words, the diode takes the energy stored in the solenoid's coil when you switch the current off. Without the diode, the energy has no place to go and will cause a significant voltage spike that will damage the EEC. Rapid switching is important to the IAC as it has only two modes (on/off) which constantly fluctuates as commanded by the EEC."
Old Jul 20, 2016 | 07:38 PM
  #486
sgauvry's Avatar
sgauvry
There is a "5D".
Check your IAC for a "D" stamped into the plactic part.
Old Jul 20, 2016 | 07:40 PM
  #487
sgauvry's Avatar
sgauvry
(5D) That's a switching diode. Crap!
There is a "5D".
Old Jul 20, 2016 | 07:52 PM
  #488
vjsimone's Avatar
vjsimone
So who put the new IAC on your truck?
Old Jul 20, 2016 | 08:07 PM
  #489
sgauvry's Avatar
sgauvry
I did. I rebuilt the engine and decided to replace all parts. Almost everything under the hood is new. The harness is original, but not much else is. The IAC is American made. Imagine that!
Old Jul 20, 2016 | 08:32 PM
  #490
vjsimone's Avatar
vjsimone
Well, someone replacing an IAC with one that has a diode built-in, would remove the original diode and cap off the additional red wire.
So, check your old AIC to see if there is a "D" stamped on it?
If so, then maybe that is a replacement IAC, and the modification was made prior to you acquiring the truck.
Old Jul 20, 2016 | 08:51 PM
  #491
vjsimone's Avatar
vjsimone
1989.....
Check your spare for a "D" code, and Part Number, when you get the chance.
What is the Part Number of your new IAC?
I'm leaning towards, nothing further to do.
Old Jul 20, 2016 | 09:48 PM
  #492
vjsimone's Avatar
vjsimone
Old Jul 20, 2016 | 09:57 PM
  #493
sgauvry's Avatar
sgauvry
I see. The code on the valve connector is 5D. The part number is ABV00031.
The diode actually did arrive this evening and I put it in (and ran the vehicle). I'll pull it tomorrow and connect the red wire directly to the white wire, along with the grey wire that comes from the ECM eliminating the new diode I purchased. Right?
Steve
1989.....
Old Jul 20, 2016 | 10:00 PM
  #494
Gary Lewis's Avatar
Gary Lewis
Why would having two diodes cause a problem?
Old Jul 20, 2016 | 10:08 PM
  #495
vjsimone's Avatar
vjsimone
I read in a few places that it could affect the idle. I would remove the diode.
