External fuel pump
Old Jul 17, 2016 | 09:41 PM
  #361
ctubutis's Avatar
ctubutis
Speaking in general, not specifically about Steve's case... so deciding to pull
Old Jul 17, 2016 | 09:46 PM
  #362
subford's Avatar
subford
There is not a KOEO code 13.
Code 13 is only a KOER code.
Service Code 13 indicates that during Engine Running Self-Test, engine rpm could not be controlled within the Self-Test lower limit band.
Possible causes:
-- Improper idle air flow set.
-- Vacuum leaks.
-- Throttle linkage binding.
-- Throttle plates open.
-- Improper ignition timing (TFI vehicles only).
-- Throttle body/ISC solenoid contamination.
-- ISC circuit short to ground.
-- Damaged ISC solenoid.
Old Jul 17, 2016 | 09:47 PM
  #363
vjsimone's Avatar
vjsimone
Steve, have you replaced your Oxygen Sensor? Is the wire attached to your O2 Sensor?
Old Jul 17, 2016 | 09:51 PM
  #364
vjsimone's Avatar
vjsimone
Possible causes:
-- Vacuum leaks.
Post 343, Steve reports Code 13 as a KOER Self-Test.
"KOER Coeds = 41 HO2S System Lean Bank 1
= 34 EVP Sensor Above Threshold
= 13 Cannot Control RPM During Self-Test Low RPM Check"
Old Jul 17, 2016 | 09:53 PM
  #365
subford's Avatar
subford
Originally Posted by ctubutis
I can tell you've got a lot of experience with the the 90s-gen stuff, Bill(?).
The first year of a CEL (MIL new name HA) connected to a computer is 1988, he doesn't have such a dash light to light up, so deciding to pull codes was on an as-needed basis as it started to run bad (or not start).
Yes I know but it was stated as as general information for others that might read this thread.
Old Jul 17, 2016 | 10:04 PM
  #366
vjsimone's Avatar
vjsimone
Steve, what is the status of your EGR Valve? Old?, New?
Old Jul 17, 2016 | 10:08 PM
  #367
sgauvry's Avatar
sgauvry
Hi Vincent!
You had sent those instructions to me before and I followed them. Since that time, the trucks never run better. However, After following the instructions I sent the idle speed at 650. The codes are telling me that's too high and I will readjust.
Have some other things to fix. I wonder if they are related to the IAC wiring problem. Wuill work on some of those things tomorrow, starting with the idle speed.
Beyond that, waiting for the diode to arrive so I can fix the wiring to the IAC. Will likely need some direction there. I'll let you know.
You've been great! Thanks for the help!!
Originally Posted by vjsimone
This story gets better and better every day….. Good job following that wire back….. We will make a Tech out of you by next year.
KOEO – Code 11 means you truck passed the KOEO Self-Test, this is required before moving on the KOER troubleshooting.
KOEO – Code 13; Follow this procedure to clear this code; (your idle is set to high)
5.0L V8: 1985 Truck and Van; To adjust idle speed: (Official Procedure)
1. Disconnect the battery for 3 minutes to erase the current idle control program from ECA memory. Turn the throttle stop screw in (clockwise) 1 turn.
2. Reconnect the battery, start the engine, and run it at 1800 rpm for 30 seconds.
3. Place the transmission in drive (AT) or neutral (MT) and let idle speed stabilize.
4. Back out the throttle stop screw, until idle speed is 600 ±20 (AT). Then back out the screw another 1/2 turn.
5. Stop the engine and disconnect the battery for at least 3 minutes.
6. To check curb idle speed, start the engine and run it at 1800 rpm for 30 seconds. Place the transmission in drive (AT) or neutral (MT) and let idle speed stabilize. Refer to the VECI decal for curb idle specifications.
So, I have done this 12 times, this is not easy, easier with 2 people.
Print these instructions out, 2 sets if you have 2 people. Easier to use a Diagnostic Tachometer, $30, unless you have one.
Easier to count the turns with a long straight slot screwdriver. You will need the stopwatch function on your phone to time the 30 seconds. It is challenging to keep your foot on the peddle steady @ 1800 rpm. Do not start the clock until you are steady @ 1800 rpm. (Practice this first before you follow the procedure).
If you only have one person, you will have to set your parking break, and block your wheels. I recommend you use reverse instead of drive (step 3), so you don’t get run over, works just as well.
Please ask questions. I have cleared code 13 using this procedure.
Ref; http://beta.askatech.com/AskATechLiv...Track/F050.pdf
Old Jul 17, 2016 | 10:11 PM
  #368
sgauvry's Avatar
sgauvry
New, but I want to check the voltage going to it, tomorrow.
Old Jul 17, 2016 | 10:12 PM
  #369
sgauvry's Avatar
sgauvry
Yes, but I'm sure it's fouled due to the poor running when the fuel pump issues come into play.
Old Jul 17, 2016 | 10:15 PM
  #370
sgauvry's Avatar
sgauvry
I did have a vacuum leak that is now fixed. I'll see if it will code a 13 tomorrow. I think it won't, but we'll see.
Possible causes:
-- Vacuum leaks.
Old Jul 17, 2016 | 10:26 PM
  #371
ctubutis's Avatar
ctubutis
OIC, thanks for explaining; ND Bill does the exact same thing sometimes.
Old Jul 17, 2016 | 10:34 PM
  #372
vjsimone's Avatar
vjsimone
How about the EVP on top of the EGR Valve? Old? New?
Old Jul 17, 2016 | 10:47 PM
  #373
vjsimone's Avatar
vjsimone
Well, these original O2 sensors are good for 30K miles, not sure about the replacements.
So, KOER Code 41 may mean that your O2 Sensor is reporting a Lean mixture, so less than about 0.4 vdc or less going to the ECA. When everything is perfect, the sensor sends about 0.5 vdc to the ECA. (Range is 0 to 1 vdc) 0 to 0.4 vdc=Lean mixture / 0.6 to 1.0 vdc=Rich mixture
This is a single wire Sensor. It uses the exhaust pipe as its ground path, so check continuity between the Exhaust Pipe and the body or engine ground. (Rx200) Record measurement. If you don’t get a good ground, add a wire strap from the Body or Engine to O2 side of the “Y” pipe. So, maybe the Nut side of the “Y” pipe before the Exhaust Manifold.
Check the wire and connection to the O2 sensor.
If everything above checks out, replace your O2 Sensor, (RockAuto has one with the connector attached, $9), Personally, I only use OEM or high quality sensors. (not sure about this since yours is newish)
If you decide to replace this O2, start spraying it with PB Blaster 6 days in a row before attempting to remove it. It might break off. Super hard to get to if yours is in the middle of the “Y” pipe.
Basically this lean condition causes your engine to run rich, because the computer is allowing more fuel into your intake than necessary. This can affect your idle as well.
Old Jul 17, 2016 | 11:03 PM
  #374
vjsimone's Avatar
vjsimone
Hi Vincent!
But you did not follow them if you set your idle to "650", so I cleaned them up and resent......
Set Idle to 600rpm in reverse or drive, Then back out the screw another 1/2 turn.
This will take your idle down to about 550rpm, thats ok.
Old Jul 17, 2016 | 11:39 PM
  #375
vjsimone's Avatar
vjsimone
Subford, I think the O2 signal is fed into an amplifier in the ECA via pin 29. Do you have a schematic of this?
