External fuel pump
Old Jul 14, 2016 | 12:44 PM
  #211
sgauvry's Avatar
sgauvry
OK, Vince -
After cleaning and greasing ALL connectors including those to sensors and fuel injectors (except the bank under the intake manifold), I hosed down the car and engine compartment. I gave it a good drenching and especially sprayed the connector to the fuel pump. Started right up. The true test will be if it rains overnight or I hose it down again tonight and let it sit and try to start it first thing tomorrow, if it starts then. But I think it will and what you offerred did the trick.
I ordered a new ECM (E5TF-12A650-S1B,101558,JRG) from some junk yard in Jersey. We'll see if that cures the inability to get codes. I'll let you know.
Thanks for hanging in there with me (the same to ctubutis and Gary)!
Steve
Originally Posted by vjsimone
Car-Part.com--Used Auto Parts Market
Used, Junk Yard ECA's; Car-Part.com--Used Auto Parts Market
Part Search; Select Part = "Engine Computer"
Search by year.
Suggest you order a xxx = "S1B".
E5TF-12A650-S1B
Old Jul 14, 2016 | 12:50 PM
  #212
Gary Lewis's Avatar
Gary Lewis
I have no clue. Where did you get them?
Old Jul 14, 2016 | 01:38 PM
  #213
subford's Avatar
subford
The catch (program) code should be GS1 and not JRG.
Old Jul 14, 2016 | 01:59 PM
  #214
sgauvry's Avatar
sgauvry
Oh crap! A place called AAA Management in New Jersey. $100.00 plus shipping.
Old Jul 14, 2016 | 06:03 PM
  #215
ctubutis's Avatar
ctubutis
Yeah, you really need to pay attention to all those details (program code revision, aka catch code) when you go buying a new computer; sometimes you can come across one that "might/could/should work" but they're not at all a generic, plug-n-play-type of item and easily swappable.
Your truck is a 1985 302 automatic trans 2wd and the eighth character in your VIN is the letter 'N' correct?
Old Jul 14, 2016 | 06:22 PM
  #216
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
I have 2 or 3 of those early EFI 5.0 EECs left over from Archion's debacle with his. He brought them and the spare harness set to me, since I had bought them when we were dealing with it. I think there were 8 or 10 changes between mid 85 and the end of production in 1986.
One thing on those to take a long hard look at, near the battery negative post, attached to it, is a plug with a black/light green wire (or pair) that grounds the entire EEC system. It is a common issue on these as the connector is not a weather proof one and any extra resistance will drive the EEC crazy.
Last edited by 85lebaront2; Jul 14, 2016 at 06:37 PM. Reason: Added note on ground connector
Old Jul 14, 2016 | 06:37 PM
  #217
Gary Lewis's Avatar
Gary Lewis
Was one of them to add code readout?
Old Jul 14, 2016 | 06:39 PM
  #218
85lebaront2
They had a test plug pair up by the MAP sensor and solenoids in the right front (see the 86 EVTM). One of the big problems was the adjacent ground connector.
Old Jul 14, 2016 | 06:47 PM
  #219
Gary Lewis's Avatar
Gary Lewis
Yes, the EVTM shows it, but did all of the computers support it?
Old Jul 14, 2016 | 07:41 PM
  #220
sgauvry's Avatar
sgauvry
Yes, the letter N.
Old Jul 14, 2016 | 08:40 PM
  #221
vjsimone's Avatar
vjsimone
I agree, should be a GS1.......
Old Jul 14, 2016 | 08:44 PM
  #222
vjsimone's Avatar
vjsimone
Originally Posted by sgauvry
OK, Vince -
Steve
The "JRG" listed may be meaningless.
Call them to verify the three digit code in that right hand block, if it is not GSI, then see if you can cancel your order. I agree, should be a GS1.
There are some at that site for about $50. `+ shipping. I saw a "SB" version as well.
I’m guessing the version progression is SA – S1A – S2A – SB –S1B – S2B
What is the date of build for your truck?
Old Jul 14, 2016 | 09:28 PM
  #223
vjsimone's Avatar
vjsimone
If not too late maybe this will help:
Nice......
Old Jul 14, 2016 | 09:38 PM
  #224
vjsimone's Avatar
vjsimone
OK. All connectors are cleaned and greased including connectors to sensors. I also saw that there's a boot (drain) that empty's directly onto a plug connector that connects to the external fuel pump. Don't know if that was the issue regarding the pump issues, but I cleaned that connector and greased it up as well. Will have to wait until another rain (probable today) to see if the fuel pump/injector engagement issue has been cleared up. Or, I could just hose everything down again and test it out, which I'll likely do.
Seems you're leaning to the ECM as the problem with regard to pulling codes. Since the 85 second half of the year was the first EFI for the F150, would you recommend I search by the year 1986, or doesn't it matter?
I would not recommend a 86', a few changes that year, the computer was programmed to run in a limp mode if a sensor fails.
I have seen a date code of Feb 85', VIN "N" with your same system. Mine is dated July 85 VIN 'N', and most likely the same model as yours.
Old Jul 14, 2016 | 10:08 PM
  #225
vjsimone's Avatar
vjsimone
I hope you redirected that "boot (drain)" away from your connector??
