Upgraded replacement headlights..
Old Dec 16, 2016 | 08:58 PM
  #346
Tcm glx's Avatar
Tcm glx
Originally Posted by Burgess090906
Are you using plain old car wax?
yes sir! Plain old wax.
Old Dec 17, 2016 | 04:31 PM
  #347
agsmv1's Avatar
agsmv1
Originally Posted by Tcm glx
Here is a pic I just finished up for Randall, however I'm holding off on doing an 99-04 right now. The vendor changed glue on the lenses and it's beyond horrible opening these up.
Anybody have any pics of these installed and light output? I'm torn between these and the 05. If I go to 05 I will have to do some work to trim my header panel, and I am not known for my delicacy or patience for a project like that!
Old Dec 17, 2016 | 04:43 PM
  #348
Tcm glx's Avatar
Tcm glx
Output is the same. Using the same projector for either of the two conversions.
Old Dec 17, 2016 | 04:58 PM
  #349
Yahiko's Avatar
Yahiko
FTE Remembers
You might try to PM run6.0run about how to do the conversion.
I know he has done at least one. Or try him at his shop.
Super Duty Service in Grain Valley, Mo
Sean
6.0L Tech Folder
Old Dec 17, 2016 | 06:04 PM
  #350
Burgess090906's Avatar
Burgess090906
From what I read, it is more than a trim. It is an all out demo project. Once you start, you can never go back.
Old Dec 17, 2016 | 10:29 PM
  #351
agsmv1's Avatar
agsmv1
That makes sense. I did not want to bother you too much so I figured I would ask here. Appreciate it.
Old Dec 18, 2016 | 11:26 AM
  #352
Kemicalburns's Avatar
Kemicalburns
Originally Posted by FordBlueHeart
Well, I got my foglights installed. Not without dropping one and putting a crack in it. Install was rather easy except for how the adjustment screw attaches at the bottom. It's a square peg trying to fit in a smaller round hole. I just used the threaded part behind the attachment instead of making it pop in. (I'm sure no one understands what I mean by that.)
Anyways, I adjusted them (I think) to where they are the same height. I measured this by standing a ways away and kneeling down until the brightness appeared at the same height for both lights. Then I took it for a drive. I parked near a building and the first thing I noticed was how much higher the light was cast on the wall versus the low beams from the headlight. I attempted to adjust the fogs down further but no matter how much I tightened the adjustment screw, nothing happened. In fact, it appeared to get worse. I gave up and called it a night. Rather discouraged, not at the foglights, but more at my ineptitude.
I will be doing my install today. how did the wires go into the plug for our 05-07 models? Looking at the install guide it says you must test for the correct polarity? electrical stuff haunts me and I tend to over think it. would I just match the wire color to what is already on the ford connector?
Fordblueheart, I am wondering if it would be an advantage to try and adjust the fogs down as much as possible before bolting the bracket to the bumper?
Old Dec 18, 2016 | 12:57 PM
  #353
FordBlueHeart's Avatar
FordBlueHeart
I can't remember exactly on the wiring, but the new fog has a red and a black. I looked at the stock wiring colors and matched them up. IIRC, one wire is red or has a red stripe and the other one is black or has a black stripe.
I don't think the bracket and fog bolted together will fit in the opening.
When it came time to install mine, I watched the video posted previously and read over the pdf that Yahiko posted.
EDIT: The video was very good at showing that ANYONE can do this.
Old Dec 20, 2016 | 12:04 PM
  #354
Medicpelle's Avatar
Medicpelle
I just got my headlamps and wiring kit from Tony. Can anyone help with install with pics or video? I'm installing on 2014 350 Platinum. I am having a hard time finding a location to mount the main wiring harness and ballasts. I installed the fogs with no issue and they look great now I want to get the head lamps on.
Old Dec 24, 2016 | 07:27 PM
  #355
Tcm glx's Avatar
Tcm glx
Did you get it sorted out?
Hapoy holidays fellas!
Old Dec 26, 2016 | 06:55 PM
  #356
montey2005's Avatar
montey2005
WOW.......got mine and finally installed a few adjustments and now I can drive legally without the rigid, non DOT certified, fog lamps. Tony was a class act and answered my calls. If you read this Toni come up with more stuff for our trucks
Old Dec 26, 2016 | 07:03 PM
  #357
Tcm glx's Avatar
Tcm glx
Right on Dax!
Old Dec 31, 2016 | 10:41 AM
  #358
Tcm glx's Avatar
Tcm glx
Bump, Happy New Year fellas!!!
Btw, I'm getting caught up, who else wants some retrofits?!
Old Dec 31, 2016 | 11:04 AM
  #359
seijirou's Avatar
seijirou
Damnit.
I do. Where do I send it?
Old Dec 31, 2016 | 11:08 AM
  #360
Tcm glx's Avatar
Tcm glx
Originally Posted by seijirou
Damnit.
email me and let's go!!
Marcoarojo@yahoo.com
