Upgraded replacement headlights..
Old Apr 6, 2017 | 10:33 AM
  #406
gpsaxophone's Avatar
gpsaxophone
Sent an email out...interested in the headlight upgrade.
Old Apr 14, 2017 | 05:01 PM
  #407
Burgess090906's Avatar
Burgess090906
Tony,
Please give me a shot. I finished the install today and no lights. My fogs also quit working.
I have checked all fuses. Grounds are good. I have power to the lense, but no power to the light.
Old Apr 14, 2017 | 05:11 PM
  #408
Burgess090906
I got the headlights on.
My fogs are still out. Any ideas?
Old Apr 14, 2017 | 05:19 PM
  #409
Burgess090906
Never mind. I did not have the ignition on. Duh
I am 100%.
Old Apr 14, 2017 | 05:36 PM
  #410
Tcm glx's Avatar
Tcm glx
I am 100%.
Just saw this!!!
Old Apr 14, 2017 | 08:28 PM
  #411
Tideman's Avatar
Tideman
Burgess, you're ok in my book Takes a big man to admit that. Thanks buddy
Old Sep 26, 2017 | 11:48 PM
  #412
Yahiko's Avatar
Yahiko
FTE Remembers
Well after crunching the other truck that has nice brite headlights
I ordered a set from Tony today. Thexe should be very nice and brite
from what everyone is showing in there photos.
Old Oct 23, 2017 | 11:07 PM
  #413
Yahiko's Avatar
Yahiko
FTE Remembers
Well box from Tony showed up this last Saturday by way of the Fedex truck.
The rain was not being nice around here and I gave up and put the tarp up
and strapped it to the back of the truck so I would work under the hood.
The only thing I really had to change was the passenger side ground. I had
to add a but of wire to the ground cable. and attached the harness to it with a
nice clean bolt with str lock washers and covered that with mastic coated heat-shrink.
So it will stay nice and clean and dry. Other than that the biggest issue was
finding places to easy to work with places to put the ballast boxes and the
relay box. It helps to have some 6mm J-nut clips on hand and a bolt to go with
it the truck has a lot of unused clip holes that come in handy for this project.
I would say it only took about an hr not counting all the find nuts and bolts along
with picking out places to mount things.
When I rent to remove the passenger side headlight I found a 10mm wrench I
lost a while back wedged in between the lamp and header.. nice having tools back
that have gone MIA. The only thing left I have to do it adjustment of the low
bean cutoff on the wall.
Old Oct 23, 2017 | 11:11 PM
  #414
Bonanza35's Avatar
Bonanza35
Looks good, hope you like them.
Old Oct 24, 2017 | 12:11 AM
  #415
seijirou's Avatar
seijirou
Nice! I'm still really happy with mine.
Old Oct 25, 2017 | 05:33 PM
  #416
Monster-4's Avatar
Monster-4
What's the going rate for a '05-'07 set? I have to do something about replacing the crappy set that is on the truck now.
Old Oct 25, 2017 | 06:15 PM
  #417
Yahiko's Avatar
Yahiko
FTE Remembers
I'll see if I can get Tony to stop into the thread.
Old Oct 26, 2017 | 08:46 AM
  #418
Tcm glx's Avatar
Tcm glx
Hey guys, still doing these, same pricing as listed. Starting off at 425 a set.
Old Oct 26, 2017 | 04:44 PM
  #419
Monster-4's Avatar
Monster-4
Great! This may be a Christmas present to myself. Will PM you directly Tony when I get to that point.
Old Oct 31, 2017 | 01:51 PM
  #420
seijirou's Avatar
seijirou
Tony are you still able to get fog lights?
