Upgraded replacement headlights..
Old Oct 31, 2017 | 02:53 PM
  #421
Shiloh51933's Avatar
Shiloh51933
Originally Posted by Yahiko
Well box from Tony showed up this last Saturday by way of the Fedex truck.
The rain was not being nice around here and I gave up and put the tarp up
and strapped it to the back of the truck so I would work under the hood.
The only thing I really had to change was the passenger side ground. I had
to add a but of wire to the ground cable. and attached the harness to it with a
nice clean bolt with str lock washers and covered that with mastic coated heat-shrink.
So it will stay nice and clean and dry. Other than that the biggest issue was
finding places to easy to work with places to put the ballast boxes and the
relay box. It helps to have some 6mm J-nut clips on hand and a bolt to go with
it the truck has a lot of unused clip holes that come in handy for this project.
I would say it only took about an hr not counting all the find nuts and bolts along
with picking out places to mount things.
When I rent to remove the passenger side headlight I found a 10mm wrench I
lost a while back wedged in between the lamp and header.. nice having tools back
that have gone MIA. The only thing left I have to do it adjustment of the low
bean cutoff on the wall.
What kind of projector was retro-fitted into the low beam location?
What kind of Xenon bulb/ignitor/ballast are you using?
It looks clean...factory clean!!
Old Oct 31, 2017 | 07:23 PM
  #422
87crewdually's Avatar
87crewdually
See Post #40
Old Oct 31, 2017 | 11:29 PM
  #423
Yahiko's Avatar
Yahiko
I can say I really like them. Here are some photos and the one of the light all lit up
was done with a little exposure control so it was not all washed out.
Old Nov 3, 2017 | 05:32 PM
  #424
scexc17's Avatar
scexc17
Anyone got an email or # for him?
Old Nov 3, 2017 | 08:48 PM
  #425
FordBlueHeart's Avatar
FordBlueHeart
Looking good Sean. I still need to put in the set I got from Tony.
Old Nov 3, 2017 | 09:34 PM
  #426
Yahiko's Avatar
Yahiko
I was out late the other night and got a good look on a wall and see
that I will need to do a little rotational adjustment of the projector.
The two cutoff lines are not lining up that well. But it's not that much.
I just happen to be picky. I should of done it at the install but with the
wrecked truck taking up so much driveway space I can't get a good shot
at the garage door to align on.
The driveway is level but off to the side in the gravel not so much.
Old Nov 4, 2017 | 01:12 PM
  #427
Bonanza35's Avatar
Bonanza35
Tony
Message sent.
Old Nov 4, 2017 | 05:09 PM
  #428
Shiloh51933
Yahiko those retro fits look perfect, thank you for posting pics of the cut-off. I have to get a pair of these for my '07, are these available still or was it a one time run for the '03-'07 model F250/F350?
Old Nov 4, 2017 | 08:13 PM
  #429
Yahiko's Avatar
Yahiko
He builds from way back to current lights.
Tony is Tcm glx and I think he answers his PMs.
If he does not let me know and I can send him a message.
Old Nov 4, 2017 | 08:25 PM
  #430
Tcm glx's Avatar
Tcm glx
Thanks guys for all the positive comments.
Yes can do early trucks as well.
Yes can still get fogs.
Old Nov 4, 2017 | 09:05 PM
  #431
Yahiko's Avatar
Yahiko
Tony to align the right and left cutoff lines did read correctly you just have to
remove the lamps and use a large screwdriver blade to move the projector?
I got a chance to light up a wall the other night and could see that there is a little
bit off level between the two.
Old Nov 4, 2017 | 09:08 PM
  #432
Tcm glx's Avatar
Tcm glx
Yup. Small movements make a big difference.
Old Nov 4, 2017 | 09:48 PM
  #433
Yahiko's Avatar
Yahiko
Is the direction of rotation the same?
If I need the left to come up then I would turn
the screwdriver so it's left side would be coming up.
Old Nov 5, 2017 | 07:55 AM
  #434
Tcm glx's Avatar
Tcm glx
Yup. Same rotation.
Old Nov 5, 2017 | 04:51 PM
  #435
Yahiko's Avatar
Yahiko
Thanks.
Don't think I will be doing that tonight.
Snow on the ground really early this year.
