Upgraded replacement headlights..
Old Apr 13, 2022 | 06:49 AM
  #511
Sullid01's Avatar
Sullid01
tfunk - could you post a link to them? I also need to make sure it is not my ballast that is the problem.
Old Apr 13, 2022 | 07:33 AM
  #512
tfunk88's Avatar
tfunk88
https://www.theretrofitsource.com/H1...ule?quantity=1
Old Apr 13, 2022 | 07:49 AM
  #513
Tcm glx's Avatar
Tcm glx
That’s them right there.
Old Apr 13, 2022 | 09:20 AM
  #514
Shiloh51933's Avatar
Shiloh51933
Tony offers upgraded ballast and xenon bulbs or you can pick whatever you want but whatever you bulb you decide to go with I personally prefer 6500k. In my opinion the 6500k seems to have the best coverage on the road and they look great aesthetically.
Old Apr 13, 2022 | 01:55 PM
  #515
Yahiko's Avatar
Yahiko
FTE Remembers
To check the ballast just swap the lamps from one side to the other.
Old Apr 18, 2022 | 09:51 PM
  #516
High_HP's Avatar
High_HP
BajaHID Retrofits
My experience has not been positive with the kit from BajaHID Retrofits. I am giving them a chance to make things right finally. We will see if they step up.
Old Apr 18, 2022 | 09:54 PM
  #517
Tcm glx's Avatar
Tcm glx
Happy to step up and help. Want to message me directly or post up here?
Old Apr 19, 2022 | 10:13 AM
  #518
Shiloh51933
I hear you...I have had some issues with the retrofit from Bajaretrofit.com myself but so far they have been working with me. I had an issue with 1 of the Hylux ballast not firing up most of the time, so I contacted Baja and they sent me a new ballast. I'm also having an issue with condensation on the inside of housing front lens, Baja said to send them back for new seals. Its really annoying to have to take everything apart, repackage everything, reinstall the old headlight assemblies and then wait to get everything back to do everything over again. But I understand the nature of retrofitting...they are tearing down a perfectly brand new headlight assembly to modify, then reseal it when the modifications are finished and sometimes the new seals might not seat perfectly. I still really like the headlight assemblies they made for me and it will be worth the wait in the end .
Old Apr 19, 2022 | 10:21 AM
  #519
Tcm glx's Avatar
Tcm glx
Appreciate your patience Shilo. Side note I sent you a label for shipping last week.
Old Apr 19, 2022 | 12:03 PM
  #520
Shiloh51933
Thank you. I must of missed it.
klinquist
32
Feb 5, 2017 07:21 PM
351Cleveland C4
Jun 16, 2015 07:19 AM
xc4jokestomper
Mar 27, 2011 07:41 PM
Spool&Go
30
Nov 17, 2010 03:42 PM
big kahuna
Nov 7, 2007 10:13 AM
