Upgraded replacement headlights..
Old Dec 1, 2016 | 01:42 PM
  #301
lightflyer's Avatar
lightflyer
They are supposed to be plug and play for the original wiring harness except for locating the ballast somewhere. Are yours not? Have you spoken to Tony?
Old Dec 1, 2016 | 02:57 PM
  #302
Tcm glx's Avatar
Tcm glx
Just connected with Carl....think we are good. Yes they are plug and play, the harness comes labeled.
Old Dec 1, 2016 | 02:58 PM
  #303
Tcm glx's Avatar
Tcm glx
Originally Posted by FordBlueHeart
Yeah, I can't wait for mine either. I've gone slightly different from what has been posted.
Gonna look sweet!
Old Dec 1, 2016 | 04:04 PM
  #304
FordBlueHeart's Avatar
FordBlueHeart
Originally Posted by Tcm glx
Gonna look sweet!
Can't wait!
Old Dec 3, 2016 | 09:17 PM
  #305
ErikWJ's Avatar
ErikWJ
It looks like I came late for the group buy. Hopefully there will be another round in the coming months.
Old Dec 3, 2016 | 09:55 PM
  #306
Burgess090906's Avatar
Burgess090906
Does anyone know if a bull bar will block our fog lights?
Old Dec 3, 2016 | 09:59 PM
  #307
FordBlueHeart
If I were you Erik, I would email Tony and see what he can do. No doubt he'll take care of you.
Old Dec 4, 2016 | 04:57 PM
  #308
BuddyB's Avatar
BuddyB
New headlights
Is it too late to get in on the headlights for a 2006 for the $400?
Buddy
Old Dec 4, 2016 | 05:00 PM
  #309
Tcm glx's Avatar
Tcm glx
Buddy
nope. Email me directly marcoarojo@yahoo.com
Old Dec 4, 2016 | 08:43 PM
  #310
carlhwv's Avatar
carlhwv
Had some help on my installs...I'm paranoid workimg on a new truck. Thanks for the for the info Tom. Headlights are in and they absolutely rock. I played with adjustment tonight and have them in a good place. They are as good as headlight can be. Absolutely amazing.
Im have a bit mor difficulty with the fogs. Not sure what I'm missing. They are aiming higher than my low beams. It does provide an interesting illumination package, but don't think they will do well when the cloud sets in on the mountain. Mine were a direct replacement for the stock lights that came with the Lariat. Not sure if something went sideways with the install...need to check on that tomorrow, but they sure will need a lot of downward adjustment to bring them anywhere near low as the stock light were. If someone with a good install can post a picture it might help. I'm sure we can get it figured out.
Old Dec 4, 2016 | 08:55 PM
  #311
FordBlueHeart
I'm having the same issue as you Carl. Fogs definitely shine much higher than the low beams. I think part of my issue is the adjustment screw with the stiff spring. I think I need to apply more force while tightening it in order for it to adjust.
By the way, tonight I was driving home and would turn on the fogs and I could barely see them. The other night, they were extremely easy to see. The only difference tonight was the snow on the ground and in the air. The slightly yellow light of the low beams cast a better light spread against the white background. It's going to be interesting once I get my new HID headlights to see the visibility difference.
Old Dec 4, 2016 | 09:08 PM
  #312
carlhwv's Avatar
carlhwv
My fogs are pointing 8" to foot above my low beams when shining on a wall 20 feet away.
Old Dec 4, 2016 | 09:48 PM
  #313
Yahiko's Avatar
Yahiko
FTE Remembers
That is why When I get HIDs I use the 4300K lamps vs the 6000K ones.
I would be tempted to try 3000K but that might be way too yellow.
Sean
6.0L Tech Folder
Old Dec 4, 2016 | 10:58 PM
  #314
Tcm glx's Avatar
Tcm glx
That's odd guys...can you guys email me some pics on a wall....I'll ask what's doing.
Old Dec 5, 2016 | 07:48 AM
  #315
carlhwv's Avatar
carlhwv
I'll post a pic tonight, however I think my issue is install related. Can someone who has these working post a closeup picture of their install? Im guessing to adjust, I need to get to to the back of the housing, which I don't seem to have easy access to. But before I tear it apart, should I see a nut on the front bottom of the light? There seems to be plenty of spring for adjustment, but it just seems like something is missing.
