Upgraded replacement headlights..
Old Jan 20, 2017 | 11:53 PM
  #391
agsmv1's Avatar
agsmv1
Dammit I think I may have to get on the horn and get me some ordered as well!
Old Jan 20, 2017 | 11:54 PM
  #392
Tcm glx's Avatar
Tcm glx
Beep beep!!
Old Jan 21, 2017 | 12:21 PM
  #393
Burgess090906's Avatar
Burgess090906
Donald or Tony,
Can you explain the adjustment rotational adjustment procedure?
Old Jan 21, 2017 | 12:30 PM
  #394
Tcm glx's Avatar
Tcm glx
Originally Posted by Burgess090906
Donald or Tony,
Yup.
I use what is known as a single nut method for mounting these. They sit in a thin silicon washer which will allow for minor rotational adjustments.
They em way to adjust is pull the bulb out of the projector and using a wide flat head screw driver, insert the screwdriver to where the bulb was and rotate either way as needed. Email me directly if you want to chat at length about it.
Old Jan 30, 2017 | 02:26 PM
  #395
lightflyer's Avatar
lightflyer
Got the light installed this weekend. But high beams and low are reversed for some reason. Got an email to Tony but does anyone else have any ideas what could be the issue. We tried swapping the wires for the high beam plugs, with no help.
Update:
Tony said to reverse the 2 outside wires in the blue plug if this happens. Will try Wed.
Old Jan 30, 2017 | 03:01 PM
  #396
seijirou's Avatar
seijirou
Are you positive you don't have the adapter harness plugged in to the factory harness upside-down? That would reverse high and low beams. The plugs should prevent this physically but it may be possible if the factory side isn't in great shape.
Old Jan 30, 2017 | 05:34 PM
  #397
Yahiko's Avatar
Yahiko
FTE Remembers
Update:
I was going to say you may have the ground on the wrong pin.
Here is the diagram for the 06~07 year.
Old Jan 30, 2017 | 05:38 PM
  #398
lightflyer's Avatar
lightflyer
I won't have time to look at it till Wednesday. I get home too late to check it.
Old Jan 30, 2017 | 05:55 PM
  #399
Yahiko's Avatar
Yahiko
FTE Remembers
That will give me time to get the 04 diagrams posted for you.
I'll try and post all the diagrams from 03 to 07.
That way there are here.
Old Jan 30, 2017 | 06:54 PM
  #400
lightflyer's Avatar
lightflyer
Tony has already said just to reverse the outside pins on the harness connection.
Old Jan 30, 2017 | 09:20 PM
  #401
Yahiko's Avatar
Yahiko
FTE Remembers
The reason I am going to post this is for others.
Old Feb 1, 2017 | 03:18 PM
  #402
ChetH's Avatar
ChetH
Did I miss the hid bulb type for these headlights? Are they d2s or a h13 base?
Anyone have a picture of the back of the headlight housing?
Old Feb 1, 2017 | 04:07 PM
  #403
Yahiko's Avatar
Yahiko
FTE Remembers
I think he has told me H1 or H3 but I can't recall for sure.
I know that it's not the D2S or the H13.
He can get the D2s but it costs more.
But I could be wrong.
Old Feb 1, 2017 | 04:34 PM
  #404
WatsonR's Avatar
WatsonR
Reverse the blue plug wires... mine had the same issue.
Old Feb 1, 2017 | 05:48 PM
  #405
Tcm glx's Avatar
Tcm glx
H1 bulbs, these are but,t using the Morimoto MH1 v7.0.
