If it was me, I would do them in the tub of water. If they're still a little frozen in the center tomorrow, up the temp of the smoker by 25* or so. It's always tough when you have to have the meat ready to eat at certain time. I've started cooking way early and when it's done, double wrap in heavy foil, wrap in as many heavy towels as you can and still fit in a cooler. The meat will stay at or close to pull temp for hours. The better the cooler, the longer it will hold at pull temp.
Looks like a tun of water it is, ill pull them out the freezer tonight.
Plan is to have them on the grill by 8-8:30 and them be done by about 3 to be chopped and slid back on the grill in a tin foil tray and plan on eating in the 4-4:30 range.
If it was me and you didn't mind the extra cleaning. I'd un wrap them in that bath tub and throw in some pickling salt and quite a bit of molasses. The guys will tell you how well that works out.
Yes it does...
Numbers are:
2 qts water
12 oz pickling salt
8 oz molasses...
for an 8 lb butt... so for 71 lbs... I'd scale it up some...
I'll let Bob comment on how he cooked it, cuz that was great, though I believe he wrapped the whole butt after about 3 hours with 3 layers of foil.
I like smoking meat between 200* & 225* and I smoke for 3 to 4 hours. In that time, the meat has taken in all of the smoke it will. Then we wrapped everything at least twice, good and tight. Then back in the smoker, and I usually turn the heat up a bit, until finished. And we used good ol' Hickory wood!
A lot a food went through Bob's smoker that sat... Heck, a ton of food and spirits was consumed on Bob's site that weekend......
Yea I'll be cooking this all on gas, they will be wrapped in a couple layers of foil, and slow cooked at about 225-250. Then I've got a bit of home made vinegar base sauce to hit them with when it's chopped up.
