Tomahawk's Highboy Thread
Old Apr 22, 2016 | 10:29 PM
  #361
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
Originally Posted by bajafishnut
Wow ! They are proud of that one.. I think that the EZ kit I got, was around $200 to $250, and came with everything, built for the '68 . The wire was also tinned copper, which is used on marine applications, because tin does not corrode like copper. ?? I am not a chemist, but when you go to the marine store, and pay Jewelry prices for stuff, the wire is classed as "Tinned", or tin coated, and supposed to be better for wet conditions...
Baja
You are correct. The copper with corrode. Tinning the copper wire protects it from corrosion. Salt air environment is really bad for unprotected copper.
Old Apr 25, 2016 | 08:07 AM
  #362
67nukeford's Avatar
67nukeford
Veteran: Navy
Baja
Yeah, I know. I think the difference is, it's exactly like the 79, with all of the correct connectors, and includes all the switches. Still not sure which way I'll go with this.....
Old Apr 25, 2016 | 10:20 AM
  #363
Freightrain's Avatar
Freightrain
I used both the American Autowire and an EZ kit to build the *****'s harness. The only thing I don't like about the EZ kit was the lack of markings on the fuse panel. 21 mini fuses and not one marked to what it does? WTH? Nothing in the instructions either? I've been wanting to call and ask if they have something that shows what is what? If a fuse blows, it will be a real PITA to figure out which one is toast in that little box. Don't recall copper being "tinned". Maybe since this is universal kit it isn't?
The American harness, I basically cut off all the GM connectors to use on the EZ harness. The guy bought both kits(not sure why), but I used what I had in front of me. The EZ fuse panel was already installed when I was brought into the project and was told.."here ya go, make it work".
Little update on the Mack project: It is roadworthy.
Hooked to the trailer and went for a ride yesterday. All seems well, and ready for my road trip the end of this week.
..............and now back to our regularly scheduled program................
Old Apr 25, 2016 | 11:01 AM
  #364
bajafishnut's Avatar
bajafishnut
That's peculiar, my fuse block was all labeled, as was each wire, every 6" to 8" or so, identifying exactly where the wire was intended to go.. No guessing in the future.. Also, when I first stripped insulation, I thought that they had given me aluminum wire.. but when I cut the wire, and looked at the cut endwise, I could see the copper color under the tinned outside...
Baja
Old Apr 25, 2016 | 11:08 AM
  #365
Freightrain
The wires were, like any other kit. Just the panel was so small there was no room for any markings. Unlike the Painless kit with the typical big car style fuse panel.
Old Apr 25, 2016 | 01:00 PM
  #366
highntight's Avatar
highntight
I love this truck, Gavin your an artist for sure...
Old Apr 26, 2016 | 10:14 PM
  #367
Tomahawk's Avatar
Tomahawk
I hate green copper wires.
Ready for a road trip - YouTube
Thanks for posting the video FT. I love that truck!
Thanks Zack, I appreciate that!
I need to do a little tuning on the carb. and it will be ready for a test drive.
Old Apr 27, 2016 | 04:34 PM
  #368
highntight's Avatar
highntight
Ill stay off the sidewalks then...
Old Apr 27, 2016 | 09:44 PM
  #369
Tomahawk's Avatar
Tomahawk
I don't drive that bad.
Old May 5, 2016 | 10:05 PM
  #370
Tomahawk's Avatar
Tomahawk
I got a chance to test drive the truck Tuesday night.
I was going to take the wifey for a ride tonight but when she opened the passenger side door she asked me, "why is there water on the floor"? I walked around the truck and looked at the floor and then looked under the dash and told her "it's a leaky heater core, no ride tonight".
Old May 5, 2016 | 10:07 PM
  #371
SavageNFS's Avatar
SavageNFS
I saw that on YT and was really EXCITED for you!!! Bummer about the heater core...I'm sure you'll get that taken care of!
Old May 5, 2016 | 10:30 PM
  #372
Tomahawk's Avatar
Tomahawk
I'm going to snag the one out of the F100, pressure test it, and put it in.
Old May 5, 2016 | 11:23 PM
  #373
Randle's Avatar
Randle
Congratulations on the long waited drive Gavin, It's a shame about your heater coil.
Old May 6, 2016 | 01:29 AM
  #374
GaryKip's Avatar
GaryKip
Sounds and looks good in the video, congrats on the good work. Heater core is a minor setback.
Old May 6, 2016 | 05:55 AM
  #375
Jigger2020's Avatar
Jigger2020
WOW congrats Gavin, wish I was there
