Tomahawk's Highboy Thread
Old Jan 27, 2016 | 08:34 AM
  #211
Salty Dog's Avatar
Salty Dog
Wow, that is one sweet rig.
Old Jan 27, 2016 | 08:46 AM
  #212
Tim Young's Avatar
Tim Young
Active Streak: 30 Days
Very nice Gavin! You do amazing work.
Old Jan 27, 2016 | 01:02 PM
  #213
JEFFFAFA's Avatar
JEFFFAFA
Originally Posted by Sailor_Roy
Quality Control Inspector has to stop by every once in awhile.........
Kinda like the ol' Maytag repair man commercials?
Old Jan 27, 2016 | 01:06 PM
  #214
SavageNFS's Avatar
SavageNFS
Yes, only Roy's more annoying
Old Jan 27, 2016 | 06:52 PM
  #215
Tomahawk's Avatar
Tomahawk
I hope I passed.
Thank you sir! I like your truck!
Thanks Tim!
Hi Jeff!
Old Jan 28, 2016 | 03:44 PM
  #216
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Comes from Shipboard duty.....Quality Control Inspector in the Aviation electronics shops.
.......Andre' hates me........
Old Jan 28, 2016 | 03:59 PM
  #217
JEFFFAFA's Avatar
JEFFFAFA
I meant in those old commercials Maytag referenced that there was Maytag repairmen, but they were "Never Needed". Like an inspector checking Gavin. Remember how they portrayed the repairman as being bored?
Old Jan 28, 2016 | 04:01 PM
  #218
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Now.......I got it........
Yes, Gavin is harder on himself than any inspector would be.....
Old Jan 28, 2016 | 05:39 PM
  #219
Tomahawk's Avatar
Tomahawk
Thanks for the kind words guys, I really appreciate that.
Old Jan 28, 2016 | 11:07 PM
  #220
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Not a problem......I told you I would say good stuff for $500..........The check cashed......
Old Jan 29, 2016 | 11:06 AM
  #221
SavageNFS's Avatar
SavageNFS
Andre doesn't hate you Roy You're my buddy and that's why I have to make fun of you ALL THE TIME.
Old Jan 29, 2016 | 03:18 PM
  #222
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Sure.....That makes sense........
Old Jan 29, 2016 | 04:26 PM
  #223
Tomahawk's Avatar
Tomahawk
At least it didn't bounce.
You don't make fun of him ALL the time......just MOST of the time.
Old Feb 4, 2016 | 09:55 PM
  #224
Tomahawk's Avatar
Tomahawk
Not much progress to report but I did get a lot of little details completed. I got all of the compressor lines run, bled the brakes and checked for leaks, added more cable ties to the wiring harnesses......
I made a blue lens out of screwdriver handle. I'm using the old brake warning light as an indicator light when I have the compressor switched on.
I wish it was a little darker blue but it will work.
I made some plugs for the axle vent hoses.
The instrument cluster is now completely hooked up.
The switch to the right of the steering column, where the choke was, is for the inverter. It's indicator is the red light on the vacuum gauge. The switch to the left of the steering column, where the wiper switch was, is now the air compressor toggle switch.
Now I need to get started on the exhaust. I may try to start it this weekend.
Old Feb 4, 2016 | 10:09 PM
  #225
SavageNFS's Avatar
SavageNFS
Great work Gavin! What a great solution
