AE vs IDS clone
Old Jan 19, 2020 | 02:12 PM
  #271
Yahiko's Avatar
Yahiko
Bummer can some one hit up Motohead911 for some positive Reputation as I seem to be in rep jail right now.
You must spread some Reputation around before giving it to Motohead911 again.
Old Jan 19, 2020 | 02:13 PM
  #272
Yahiko's Avatar
Yahiko
Originally Posted by namnguye
Very good video.
At 9:35
"If you are programming a 6.0L diesel, the FICM relay must be removed before programming."
You will also get that warning when doing any FICM programming with the PHP device for the Atlas tunes.
Old Jan 19, 2020 | 02:22 PM
  #273
namnguye's Avatar
namnguye
Done! Thanks Motohead911!
Old Jan 19, 2020 | 02:29 PM
  #274
Motohead911's Avatar
Motohead911
Thanks, Hopefully this works for Hartwig.
Old Jan 21, 2020 | 08:43 AM
  #275
Busterman's Avatar
Busterman
How much storage space ( hard drive) is required to run IDS and windows 10 pro ? I am thinking about purchasing a dedicated laptop to run only this software. The factory specs dont list minimum storage required.
The laptop they sell has 500 GB of storage , I wont be using this laptop for any other purpose other than diagnostics. I can purchase a used or reman laptop for less if I know the minimum specs.
Any recomendations would be appreciated.
Old Jan 21, 2020 | 12:57 PM
  #276
Yahiko's Avatar
Yahiko
A 250 Gb will give you more than enough. After all your only working on one truck.
Also I can say that clone IDS would even be happy on 80 GB of space. One thing
worth doing that is a bit extra is an SSD for two reasons. 1 they are fast booting and
2 you don't have to worry as much about crashing the hard drive's heads and killing it.
Oh there is a 3rd thing longer battery life.
Old Jan 21, 2020 | 02:33 PM
  #277
Busterman's Avatar
Busterman
Thanks Yahiko, I wasnt sure if the Toughbook CF-31 would accept an SSD but I will be looking into it It makes sense.
Old Jan 21, 2020 | 02:40 PM
  #278
SmackDaddy's Avatar
SmackDaddy
I have the Toughbook CF-31 with SSD
Old Jan 21, 2020 | 03:11 PM
  #279
Yahiko's Avatar
Yahiko
So long at you have SATA drive in the laptop it easy.
IDE is also an option. You can find laptop IDE SSD storage.
I just have not tried one out.
Old Jan 26, 2020 | 01:09 PM
  #280
Hartwig's Avatar
Hartwig
change fan clutch settings
is it possible zu change the settings of the fan clutch (earlier"come on") with IDS?
Old Jan 26, 2020 | 03:44 PM
  #281
Yahiko's Avatar
Yahiko
Not sure if IDS has that ability or not.
People that do tunes can sometimes change other things and this might be one of the other things.
Old Jan 26, 2020 | 03:51 PM
  #282
Motohead911
I haven't seen that function with IDS, but I do have it with my aftermarket tuning suite. So to answer your question NO with IDS I believe, but yes it is possible with different software. FYI I use HPTuners.
Old Jan 26, 2020 | 04:27 PM
  #283
Hartwig's Avatar
Hartwig
Thanks, will ask Gearhead. Running tow tune from him.
Old Jan 26, 2020 | 04:38 PM
  #284
Yahiko's Avatar
Yahiko
Did I post the video where the guy shows how to access the advanced features in IDS?
If I have not then here you go. Now I have not tried any of this as of yet. So please use caution.
Old Feb 4, 2020 | 11:37 PM
  #285
hanoverclarkegs's Avatar
hanoverclarkegs
I posted this in another thread and am repeating it here hoping someone can help.
"Trying to do find HP oil leak. How do u control the IPR valve with IDS? On the datalogger tab I selected the FP# mode, but can't control it."
I can manually actuate it, but would like to use the IDS clone. Here's what I observed when trying to use the active command for #IPR, the #IPR changes to a !IPR after a few seconds and no change in the IPR commanded position. Does the !FP indicate a lack of response from the PCM to the command from IDS?
